Old 11-03-2016, 10:26 PM   #1 (permalink)
Default FBL unit on Flybar head
Ok, so I just got a flybar head for a 700 to play around with and might get another 700 and use the flybar on it. The question is, can I take a FBL unit that I already have, put cyclic gain to zero, and use it with the flybar head? This would allow me to take advantage of the smart FBL governor and good tail and let me just use two satellites instead of going out and buying a $100 receiver. As well as making FBL conversion super easy if I decided to do it. Would that work with gain at zero? Talking MSH Brain or Vbar.
Keith - XLPower Factory Pilot | KST | Egodrift | BuddyRC
Protos 800X Evoluzione | Specter 700 | Protos Nitro | XLPower 550 Nitro | XLPower 550 | Protos 380
KC3D LLC - 3D Printing on Demand and RC Heli Upgrades, Tools, Accessories, and More
Number is online now        Reply With Quote Quick reply to this message
Old 11-03-2016, 10:35 PM   #2 (permalink)
I don't see a reason it wouldn't work.
Gaui X7 w/Vbar, Miniature Aircraft Tempest w/ YS 91, Gaui X5 w/ Vbar, JR Vigor w/ YS 61, Gaui X3 w/ Vbar, Blade 180 CFX, Spektrum DX9
19trax95 is offline        Reply With Quote Quick reply to this message
Old 11-03-2016, 10:41 PM   #3 (permalink)
The Vbar cyclic gain set to 0 does turn off the gyro. Tested and confirmed that on the NEO.
dcope17 is offline        Reply With Quote Quick reply to this message
Old 11-03-2016, 11:41 PM   #4 (permalink)
On NEO, you should also zero paddle sim and elev precomp
http://www.vstabi.info/forum/read.php?44,154188
And if you have rescue, it will work too.
Logo 480, 550 SX (YGE/Xnova), 690 SX (Tribunus/Scorpion), Savox/MKS, NEO, VBC
GregCA is offline        Reply With Quote Quick reply to this message
Old 11-04-2016, 12:03 AM   #5 (permalink)
Legacy VBar does NOT support flybarred heads, ONLY the Neo does.
Brain I think have a specific setting for flybarred heads.
Gaui R5, Henseleit TDR, TDR2, TDF, TDS, TDSF
VControl
Old hand at Planks
Old 11-04-2016, 12:07 AM   #6 (permalink)
In principle you cannot. FBL perform a feedback loop while the servos hooked to a standard rx act as pure feed forward, being the stabilisation embedded in the mechanics of the head.
Vbar NEO is the only FBL that really switches off the gyro setting the gain to zero. Thus it will let direct control from your thumbs.
Turning the gain to zero on others might not be the same thing.
Perhaps Brain come with a similar feature
Riccardo
Synergy E5 / Protos Max V2 / Goblin Black Nitro 700 / Vbar Control
Airbass is offline        Reply With Quote Quick reply to this message
Old 11-04-2016, 02:03 AM   #7 (permalink)
NEO isn't the only one, the Spartan Vortex can be used on a flybarred heli too.
With any FBL you could always just connect the rudder servo to the FBL, and the swash servos to your receiver and run the swash the traditional way with mixing in your radio.
Electronics: Spartan Vortex, MSH Brain, Jeti DS-14
Sims: RealFlight & AccuRC
Other: Team rep for Lynx/Oxy, working on NightWave Systems
myxiplx is online now        Reply With Quote Quick reply to this message
Old 11-04-2016, 04:29 AM   #8 (permalink)
On the MSH Brain/ Ikon you can set the Forward Feed Gain to 100. From the software description, "This parameter sets the part of the command that goes directly to the head, without gyro filtering." Setting this to 100 will remove all the gyro filtering, there is a separate setting for aileron and elevator in each setup bank.
www.facebook.com/rotorhedz
Jeti DS-14: Align 700E/700L/700N/600N/550L/500E
Raptor 90 G4.1 / Goblin 700-KSE
Train Fixer is offline        Reply With Quote Quick reply to this message
Old 11-04-2016, 07:10 AM   #9 (permalink)
I have set up a demon 3sx with rescue mode enabled on a fb Heli. This setup worked great very stable
Brendan
Helifreak #262-Past helis-Shuttle, Hawk, MA Fury, Ma Fury Extreme, Ma Stratus, Trex450,Trex700 nitro
Current helis- WhiplashG, 7HV, Chase360, 180cfx, KDS Agile 7.2
goof2 is offline        Reply With Quote Quick reply to this message
Old 11-04-2016, 07:18 AM   #10 (permalink)
Bavarian Demon 3sx also works for flybar helis. There is an explicit selection in the setup software to specify that it is on a flybar machine and it configures itself properly. FBL stabilization is off but you retain the option to use the self leveling and rescue.
MA Whiplash Gas v2, HelixHeli T700 Gas conversion, T450 Sport FBL
jharkin is offline        Reply With Quote Quick reply to this message
Old 11-04-2016, 07:44 AM   #11 (permalink)
I own several Beast x controllers they can be used as a gyro only,setup is right in the manual.
flyswatter40 is offline        Reply With Quote Quick reply to this message
Old 11-04-2016, 08:37 AM   #12 (permalink)
You could just get a regular receiver, run the cyclic servos to it, and run the tail and gov off the FBL unit.
bgymr is offline        Reply With Quote Quick reply to this message
Old 11-04-2016, 08:54 AM   #13 (permalink)
The goal is to not have to buy another receiver. Full range receivers that have sufficient power buses are expensive. And just more wires and mess and complications.
Old 11-04-2016, 10:53 AM   #14 (permalink)
From what Train Fixer said that sounds like it would definitely be one choice you have. The bottom line is just being able to get a direct connection from the stick movements to the swash.
Back when F3C regs still required a flybar some guys were experimenting with FBL units on flybarred helis and some were able to work as a bit of a hybrid where the FBL unit was actually working as well. But surely if the swash gain is at or near zero AND it gives you a direct feed of the stick inputs then you should be able to use it like an RX and still have the tail gyro, gov etc.
2009 TDR, Kasama Dune and Faifa, Minicopter Triabolo 700, RMJ Raptor gasser,
Beam E4 and Avantgarde, JR E8 leggero, Suzi Laos, Shape S8, TDRex 800, Rave 450, Trex 500.
trillian is online now        Reply With Quote Quick reply to this message
Old 11-04-2016, 06:57 PM   #15 (permalink)
You don't have to turn off the cyclic gain, the idea that a flybar and an FBL unit will "fight" is a disproven myth. What actually happens is that they stack to create a super stable helicopter.
Atomic Skull is online now        Reply With Quote Quick reply to this message
Old 11-04-2016, 09:30 PM   #16 (permalink)
yeah I never understood why they would "fight" each other but I had no way to test or prove one way or the other. I could think of no actual reason they would fight each other and result in a crash.
Old 11-04-2016, 10:31 PM   #17 (permalink)
I always wondered what would happen if you used 2 fbl units?
I think the issue with using a flybar would be the servos getting more of a work load ?
Plus how would you tune it ? on both questions??
Spending time, Paying attention
Bladefx is offline        Reply With Quote Quick reply to this message
Old 11-04-2016, 11:12 PM   #18 (permalink)
Servos get less of a workout with a flybar as a lot of cyclic control is done by the flybar. That's why when FBL started coming out people realized their 10Kg servos on a 700 weren't gonna cut it.
Old 11-05-2016, 03:04 AM   #19 (permalink)
Also Spirit has specific settings for flybar mechanics which allow you using the other features like Governor and Rescue.
Oxy 2X-VertWarp 360Blade 450XBlade 450X NightflyerGoblin 500 ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8 G1
Coco66 is offline        Reply With Quote Quick reply to this message
Old 11-05-2016, 07:03 AM   #20 (permalink)
Wouldn't a "disproven myth" result in a fact? I guess you meant to say a "proven myth" or "disproven theory".
eBlade is offline        Reply With Quote Quick reply to this message
