Go Back   HeliFreak > R/C Electronics Support > EZNOV
EZNOV EZNOV Vendor Sponsored Support Forum
Old 11-15-2016, 09:59 AM   #1 (permalink)
Default cyclic compensation
can anyone tell me how to reverse the cyclic compensation? the cyclic move in the right direction but the when the hell compensates it does it in the wrong direction. i.e: same direction as stick input. it says it should counteract each input. i know i need to reverse something but what?
jewfiler is offline        Reply With Quote Quick reply to this message
Old 11-15-2016, 11:08 AM   #2 (permalink)
The units placement is set correctly?
Airagitator is offline        Reply With Quote Quick reply to this message
Old 11-15-2016, 06:36 PM   #3 (permalink)
sorry?
Old 11-15-2016, 06:39 PM   #4 (permalink)
are referring to the unit itself?
Old 11-15-2016, 06:55 PM   #5 (permalink)
In the setup where you choose how the unit itself is physically oriented on the helicopter. There is no way to "reverse the cyclic compensation" other than choosing the correct orientation. If all of your stick movements move the swash correctly, but tilting the heli moves the swash incorrectly, then you haven't selected the correct orientation.
jarhart is offline        Reply With Quote Quick reply to this message
Old 11-15-2016, 10:22 PM   #6 (permalink)
thanks will look into it
Old 11-16-2016, 03:47 PM   #7 (permalink)
Ok. So I changed the unit placement and it works fine on the bench. Thanks. Took it out for a test hover and as soon as I took of it went hard left tail facing me into the ground. The swashplate looks level. Re leveled it and will try agin. Have to wait on new blades. Thanks guys.
Old 11-17-2016, 01:39 AM   #8 (permalink)
Unit placement is part of the very basics of the setup. Maybe theres another major fault in your setup.
I strongly recommend to check everything (including radio setup, channels, rescue). Never try to start in rescue mode. Test the swash behaviour extensively. Check the servo throws and so on...
You should avoid shredding another pair of blades
Old 01-08-2017, 04:48 AM   #9 (permalink)
It sounds very possible that the tail could have been reversed here too. That would explain the hard left rudder. It's good to double check all those correction directions for the swash and tail for the gyro by moving the heli and double checking that all stick inputs function correctly... lol I know this from past experience.
TSA 700n, Goblin 700 Comp, Trex 700x, Oxy 2, Oxy 3, Oxy 4, Synergy E5s, Synergy N7, Logo 800 Xxtreme
Vbar Neo, VControl
Team Oxy Heli
Mark.a is offline        Reply With Quote Quick reply to this message
Human Verification
