Go Back   HeliFreak > R/C Electronics Support > Mikado V-BAR Control
Mikado V-BAR Control Mikado V-Stabi/V-BAR Control Flybarless System Software and Hardware Support
Like Tree1Likes
Old 11-23-2016, 10:48 PM   #1 (permalink)
Default Nitro Temp Sensor Installation
I ordered the VBar Temperature Sensor for nitro motor.
Where is the best place to install it on the motor?
How to attach it, same high temp silicon gasket like used for the exhaust pipe?
What temperature to set the alarm?
Thanks,
Team Synergy
Codepox is offline        Reply With Quote Quick reply to this message
Old 11-23-2016, 10:55 PM   #2 (permalink)
I was about to post on what temp im looking to get on nitro, whats too much etc
Luis Murillo is offline        Reply With Quote Quick reply to this message
Old 11-24-2016, 05:33 AM   #3 (permalink)
Hopefully I can help.
I have been BETA testing this sensor for around 6 month now and can confirm safe settings.
Max temp 120 degrees is as far as I want to go, The alarm has sounded on hot days and I immediately back the engine speed off and cool it down with some gentle stuff.
On average temperature days here in the UK it has never sounded at 120 so hopefully I found a safe sweet spot.
This is where I have the actual sensor mounted between the cylinder and the head.
And any high temperature silicone from your local hardware store does the job fine.
And here I was bench testing it with a heat gun before I flew it.
Vcontrol temperature test (0 min 54 sec)
OptiFuel TEAM PILOT
busterboy is offline        Reply With Quote Quick reply to this message
Old 11-24-2016, 08:53 AM   #4 (permalink)
Thanks busterboy, this is the info I was looking for.
Do you know if the high temp RTV silicone gasket we use for mounting the pipe works also for installing the temperature sensor?
Team Synergy
Old 11-24-2016, 10:29 AM   #5 (permalink)
Should work fine mate so long as is sets hard enough to hold it in place..
OptiFuel TEAM PILOT
Old 11-24-2016, 12:11 PM   #6 (permalink)
Good point, the RTV silicon gasket might take a long time to set.
Team Synergy
Old 11-24-2016, 12:12 PM   #7 (permalink)
It also has to be sensor friendly RTV
Keith - XLPower Factory Pilot | KST | Egodrift | BuddyRC
Protos 800X Evoluzione | Specter 700 | Protos Nitro | XLPower 550 Nitro | XLPower 550 | Protos 380
KC3D LLC - 3D Printing on Demand and RC Heli Upgrades, Tools, Accessories, and More
Number is online now        Reply With Quote Quick reply to this message
Old 11-25-2016, 09:22 PM   #8 (permalink)
I slid the sensor between the fins on the head. I pushed it in until it made contact with the head. I put some rtf to keep it from sliding out. I left my original temp sensor in place to see how they read in comparison. I set it to warn at 215f. I run at around 180-210 with my temp sensor right now. I will fly this weekend. I am super exited to use it.
---DIABOLO 700 UL---
---MSH PROTOS EVO LEGGERO 700---
---MIKADO LOGO 550 2017---
---MSH PROTOS EVO 380---
JANtoolMAN is offline        Reply With Quote Quick reply to this message
Old 11-25-2016, 09:30 PM   #9 (permalink)
What is "rtf"?
Team Synergy
Old 11-25-2016, 11:46 PM   #10 (permalink)
Oops rtv
Old 12-07-2016, 01:45 PM   #11 (permalink)
Here's a pic of my install. The probe has a little tension against the engine. Will see how it works. I may need to put a little dab of silicon adhesive if it doesn't remain in direct contact.
GAUI R5 V2,Logo 700, GLOGO690, Gaui X5 Formula Stretch, all VBAR
VControl, DX9, DX7s
Accurc and RealFlight 8
C #773
Heli$ is offline        Reply With Quote Quick reply to this message
Old 12-07-2016, 01:51 PM   #12 (permalink)
I know this is a Vbar forum, but how are guys installing the Futaba style sensors? Or how would you?
Old 12-28-2016, 08:11 AM   #13 (permalink)
i tried putting the probe in the fins of my YS 60 and it wont fit if I just put it against the fins and not inside the fins will I still get an accurate temp read?
Team Synergy / Team YS Engines / Team Scorpion / Team Lynx/Oxy / Team Jersey Modeler Fuel Jugs / Team I crash a lot and cry about it
lycokayaker is offline        Reply With Quote Quick reply to this message
Old 01-18-2017, 08:21 PM   #14 (permalink)
Is it OK to shorten the sensor wire length between the thermocouple and the resistor?
Citizen 61
Glenn Goodlett is online now        Reply With Quote Quick reply to this message
Old 07-22-2017, 04:41 PM   #15 (permalink)
Hello all. I bought one of these sensors from Mikado a week ago and installed in my 550se on the esc. The problem I'm having is I'm not getting the sensor icon showing up on my vcontrol, hence I'm not able to set anything up. I've installed the app on the tx a couple of times now and it is enabled, but for whatever reason I can't figure out why it's not being picked up. I followed the instructions provided and have it connected to TEL1 on the neo. Is there something I'm missing here? Does it sound like a bad sensor? I used that same port for other sensors prior to this and it worked fine. I appreciate your feedback, thx.
Sent from my Nexus 6P using Tapatalk
fergy20003 is offline        Reply With Quote Quick reply to this message
Old 07-23-2017, 01:14 AM   #16 (permalink)
Make sure your VControl is fully up to date via the control manager
Mine is plugged into Tele1
So long as it is enabled it should be there to setup.
OptiFuel TEAM PILOT
Old 07-23-2017, 01:37 AM   #17 (permalink)
On the esc?
I haven't installed one yet but it might need the nitro setup in order to work..
- Michalis |OXY Heli|XNova Motors|
...let the flying be second nature!
acidla is online now        Reply With Quote Quick reply to this message
Old 07-23-2017, 06:51 AM   #18 (permalink)
Originally Posted by acidla View Post
On the esc?
Nitro setup not needed.
fergy200003 I put this video together for you my friend.
This was a brand new sensor in the packet and using my SAB Goblin 570 for this particular demonstration.
I choose a random number of 40 degrees Max temp for this quick demo so hope you can learn something from it.
Setup the software and applied some heat to show it working.
Any questions just ask.
Temperature sensor VBar NEO electric (2 min 3 sec)
PauloG likes this.
OptiFuel TEAM PILOT
Old 07-23-2017, 08:20 AM   #19 (permalink)
Isn't there a temp sensor app? Temperature monitor or something.
mc20piece is offline        Reply With Quote Quick reply to this message
Old 07-23-2017, 12:16 PM   #20 (permalink)
Neo updated as well as it needs 6.3 or later firmware.
Gaui R5, Henseleit TDR, TDR2, TDF, TDS, TDSF
VControl
Old hand at Planks
