Go Back   HeliFreak > R/C Electronics Support > Mikado V-BAR Control
Mikado V-BAR Control Mikado V-Stabi/V-BAR Control Flybarless System Software and Hardware Support
Like Tree1Likes
Old 07-23-2017, 05:12 PM   #21 (permalink)
Thx for the feeback guys! Much appreciate it. Really, the problem for me is just getting the neo to see the sensor. I was having a similar problem with the UI sensor , but after going into the macrocell config screen and changing the input and output to none(AUX1), the UI sensor icon showed up and I was able to use it. I tried changing settings there for this also but to no avail. I will reach out to Mikado usa tomorrow, maybe I'm missing something or I have a bad sensor. Keep the suggestion s coming, thx again
Sent from my Nexus 6P using Tapatalk
fergy20003 is online now        Reply With Quote Quick reply to this message
Old 07-23-2017, 05:16 PM   #22 (permalink)
I'm just not seeing the temp icon on the main Page and there is no TEL1 showing up in the extensions page. I do see the temp switch in that page though
Old 03-04-2018, 08:28 AM   #23 (permalink)
will this work on older v5 vbar hardware that has been updated to v6?
Here's Ron Stancil and his amazing fleet of dirt torpedoes!
450L IKON,G570 V-Control, Logo 480 V-Control, 600N V-Control, G630 V-Control, Goblin NItro V-Control, Goblin 700 V-Control
ronstancil is offline        Reply With Quote Quick reply to this message
Old 03-04-2018, 10:11 PM   #24 (permalink)
Temp sensor does not work with legacy VBars.
Gaui R5, Henseleit TDR, TDR2, TDF, TDS, TDSF
VControl
Old hand at Planks
Old 03-08-2018, 01:18 PM   #25 (permalink)
Where to put the sensor on a 96srx, it doesn't fit between the fins? Any pics?
chrillew is offline        Reply With Quote Quick reply to this message
Old 10-08-2018, 06:33 PM   #26 (permalink)
I'm thinking the same , it doesn't fit between the fins?
help please
Align 800e PRO DFC // KRAKEN Yellow // Align 700N DFC, 105HZ-R HV // RAW Yellow // 2x Goblin 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo
msallua is offline        Reply With Quote Quick reply to this message
Old 10-14-2018, 05:54 AM   #27 (permalink)
Canít you just shave it down a bit I donít think the plastic coating means anything just donít cut into the wire
jsbach#1 is online now        Reply With Quote Quick reply to this message
Old 12-20-2020, 12:46 AM   #28 (permalink)
I’m hoping this location works.. does anybody have advice setting this up with Vr control?
ID:	895763   Click image for larger version
ID:	895765   Click image for larger version
Bebobang is offline        Reply With Quote Quick reply to this message
Old 12-20-2020, 01:00 AM   #29 (permalink)
Is Permatex ultra copper sensor friendly?
Old 01-09-2021, 03:16 PM   #30 (permalink)
Originally Posted by Bebobang View Post
Iím hoping this location works.. does anybody have advice setting this up with Vr control?
How did this location work for you and what did you use to fasten or hold in place ?
Laurie_Benjamin is offline        Reply With Quote Quick reply to this message
Old 01-10-2021, 11:39 PM   #31 (permalink)
Still waiting on parts from SAB to Maiden. I’m hoping it will work great! If not I will move it closer to the header however it’s pretty close right now LOL (I did actually move it closer to the header since these photos I think I moved it one hole over LOL ) I’m hoping the Permatex copper will hold strong and transfer heat.
Old 03-18-2021, 12:04 AM   #32 (permalink)
I used a similar location but closer to the exhaust port. It seems to work perfect! Copper RTV works great! Temperatures range from 180įF to 212įF so far. I have the sensor pressing directly against the metal and held in place for 24 hours under tension. It seems to give accurate and responsive temperature readings. The key is having the correct amount of RTV strategically placed to give maximum adhesion and still allow the cooling fins to do their job. If you use too much you will reduce the ability of the engine to properly cool itself, If you use too little it will not hold the sensor. So it must be strategic.
