Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 130S
Old 11-24-2016, 10:46 AM   #1 (permalink)
Default 130S
Most people probably saw this on the main forum, but just in case not:
https://www.helifreak.com/showthread.php?t=765289
Protos Max V2 (build), Synergy 516 (build) Logo 480xx (build), Gaui NX4 (build), Protos 380 (build), Oxy2 215 Sport (build)
ultrataco is offline        Reply With Quote Quick reply to this message
Old 11-24-2016, 11:41 AM   #2 (permalink)
Interested for sure, no other micro I have ever flown has come close to flying as well as the 130x so I'm certainly watching this one. Even without piro comp it did everything else so well and I could fly it in just about the same space as a nano because it was so predictable.
Gaui X5-MiniVbar | Gaui X3-MiniVbar | Gaui X2 SK-540 | 250 Pro DFC |130X 3S GY280 | 300X-Ikon | DX8 | Real Flight 6.5
bmc76 is offline        Reply With Quote Quick reply to this message
Old 11-24-2016, 03:22 PM   #3 (permalink)
I'm interested as well, the 230s is awesome, I recommend that heli to anyone starting
TX: Fr-Sky Taranis
P.I.Engineer is offline        Reply With Quote Quick reply to this message
Old 11-24-2016, 03:28 PM   #4 (permalink)
I'm very interested as well...odd that no info at all is available
nCPX(2)*mCPX(30)*HCP100S*130X(4)*130X-L(6)*180CFX(3)*300X/CFX(4)
450X(8)*470L*GauiX3*nanoQX*180QX*DX9*HF180060*AMA 988253
Old 11-24-2016, 03:29 PM   #5 (permalink)
Awesome!
Brandon Chew aka ~INDO~
Team Lynx / Oxy Heli
Team Bavarian Demon
Indokast is offline        Reply With Quote Quick reply to this message
Old 11-24-2016, 04:00 PM   #6 (permalink)
This new model certainly seems to qualify for a new sub-forum...
Especially since it renews life in a size we all have had serious tail issues with !
Old 11-24-2016, 06:55 PM   #7 (permalink)
Why linear servos?!
Meanwhile one russian guy designed a line of micros which I consider the most advanced micros in 60/100/120 size - http://forum.rcdesign.ru/f59/thread4...ml#post6645176 Blade should really consider working with that guy.
Buzzing Around is offline        Reply With Quote Quick reply to this message
Old 11-24-2016, 07:13 PM   #8 (permalink)
The linear servos in my 120sr took a hit extremely well and lasted forever without any twitching at all.
Hope this heli is fairly cheap and robust with decent power, wouldn't mind having a backyard basher.
Being a Blade I'll certainly wait for plenty of user feedback before buying it, but this one just might get me to buy a brand I swore off a while ago
Mini Protos 6s stretch/Rochobby Nemesis NXT/RareBear funfighter620mm
~Problem Child~
learnedthehardway is offline        Reply With Quote Quick reply to this message
Old 11-24-2016, 07:24 PM   #9 (permalink)
I wonder if it will use the same linear servos that are in the newer 120S. I've not had a real problem with them except for overdriving one once. It was my bad on that when I was really new.
Do I see one of those little green circuit boards they use on that picture ???
Look right below (or above being inverted) the canopy grommet.
BrokeDad is offline        Reply With Quote Quick reply to this message
Old 11-25-2016, 09:25 PM   #10 (permalink)
gtr
Improved 130X. I'm in. Still have my old one and that thing is a tank. Just the tail was difficult. Balance blades, cracked boom, no straight tail shaft T shape and etc... Hope this one will be a great 3d trainer if it's crashes pretty good.
gtr is offline        Reply With Quote Quick reply to this message
Old 11-28-2016, 01:30 AM   #11 (permalink)
Im down to try a 130 sized double brushless heli. Id prefer it to be mcpx sized but a 130 would be good enough.
Kory
130S, Oxy Qube Carbon, Protos 380 Evo, 250 FPV Coyote Chaser - All on Frsky Taranis Plus w/ multi module & m9 gimbals
kpod is offline        Reply With Quote Quick reply to this message
Old 12-06-2016, 01:12 PM   #12 (permalink)
Originally Posted by Buzzing Around View Post
Why linear servos?!
I see it has a gear driven tail, but How do you change the pitch, or does it engage and disenguage as needed?
stevespirosezgoin81 is offline        Reply With Quote Quick reply to this message
Old 12-06-2016, 02:16 PM   #13 (permalink)
Looks like it is variable speed, just has the tail motor up front with a shaft/gearset transmission. The increased rotational inertia relative to direct drive would dampen the tail response, effectively lowering mechanical gain. The outrunner should have extra torque to overcome that inertia, so it may still work well. Would like to see a flying video!
Ric66 is offline        Reply With Quote Quick reply to this message
Old 12-06-2016, 07:49 PM   #14 (permalink)
No, the tail motor is right back at the end of the boom and the tail prop is bolted directly to the motor shaft via a prop hub type adapter. The only thing running through the boom is three wires for the brushless motor. It's the same exact setup as the 230S and 250CFX. The only gear mesh on the heli outside of the servo cases is the main motor pinion and main gear.
Mike680 is offline        Reply With Quote Quick reply to this message
Old 12-06-2016, 08:18 PM   #15 (permalink)
Are you talking about the Russian micro? If so, the tail motor is in the frame next to the rear servo. There is a drive shaft connected to it that runs through the boom. Then there are bevel gears like the one's that sucked on the 130x in the tail case that turn the power 90 degrees to the tail prop.
Kory
Old 12-06-2016, 11:01 PM   #16 (permalink)
Since you quoted me, no, I was talking about the 130S. And, how it relates to the 230S and 250CFX of the same design with NO gear driven tail on any kind. Only wires in the boom.
Old 12-07-2016, 01:17 PM   #17 (permalink)
Looks like there is a placeholder for it now too:
http://www.bladehelis.com/130S/
yakky is offline        Reply With Quote Quick reply to this message
Old 12-07-2016, 02:02 PM   #18 (permalink)
Oh, I understand. I just saw you quoted a guy that quoted a guy that was talking about the russian micro.
Kory
Old 12-07-2016, 05:14 PM   #19 (permalink)
FWIW, I was talking about the Russian micro in the earlier link. I realize the elusive 130s will likely have a direct drive tail motor.
Old 12-15-2016, 10:41 AM   #20 (permalink)
I really wish they would post more info on this before I buy an Align 150X
C
Blade 230S, Nano cpx, nano qx/3dqx/fpv, 200qx MCPX V2, Align Trex 250, 250 DFCplus, Trex 450 plus,Trex 500, JR Forza 450, and more I retired
Cman is offline        Reply With Quote Quick reply to this message
Human Verification
