Very, Very NOT Happy with T6K!! - HeliFreak
Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > 2.4G Futaba Radios
2.4G Futaba Radios Futaba 2.4G Radio Help and support forum
Old 12-18-2016, 03:53 PM   #1 (permalink)
Default Very, Very NOT Happy with T6K!!
Today at the field I called up a model in the MDL SEL menu and pressed on the button. It responded with the little animation of the button being pressed and I pressed the button again and it seemed to skip to a different model without a name. Ok, scroll through the models to find the model I want to use.
Where is it???? The model is gone!
Turns out that pressing the button to confirm model change occasionally will executed the "RES" function. What the heck it that. Had to look it up.
RES erases the entire model, even the name.
HiSky HCP80 & HCP60, Trex-100, Trex-150DFC, Trex-150X, Trex-250, Trex-450L, T-rex 450 SEV2, Trex-500X, Trex-550X. Spirit FBL
ic-racer is online now        Reply With Quote Quick reply to this message
Old 12-18-2016, 03:56 PM   #2 (permalink)
My FBL unit uses the transmitter sub-trims for zeroing, so these have all been set to "0" so I need to go through the entire swash leveling FBL setup, in addition to trying to recreate all the switch assignments and throttle curves.
Of my remaining models, I'm going to make backup copies of all of them farther up in the memory.
Old 12-18-2016, 04:21 PM   #3 (permalink)
Ouch, that blows, but ya, with anything containing data you don't want to lose, always have backups.
HAL9KPCM is offline        Reply With Quote Quick reply to this message
Old 12-18-2016, 04:34 PM   #4 (permalink)
Interesting. I have had mine since July and have not ran into the issue. Granted mine is for buddy boxing and sims.
Futaba 18SZ TRex 450l, Synergy N556 (soon), Synergy E7se x 2, Synergy N7 (iKON)
colemn615 is offline        Reply With Quote Quick reply to this message
Old 12-18-2016, 07:57 PM   #5 (permalink)
Ok, so I have been trying to figure this out. Turns out that when you go to press the button IN, your finger might toggle the button UP. That would activate the LAST menu item, which happens to be RES!
Now when you get the "Sure?" confirmation, thinking you are confirming a model change, you are actually confirming a complete erase.
The window in my winter muff obscures the bottom of the screen. Add it all up and it leads to tears.
The radio has a 30 model memory, so I'll use the higher memory positions to duplicate backups of my models.
Otherwise this is a great radio. Small and light-weight. I pack some batteries, and this transmitter in a bag around my neck and one or two helis in my hand. This winter I'm using a use a local field, a few minutes from the house. Very simple setup that works well.
Old 12-18-2016, 08:08 PM   #6 (permalink)
Not the first time the transmitter erased a model without warning...
https://www.helifreak.com/showpost.p...86&postcount=7
Old 12-19-2016, 08:33 PM   #7 (permalink)
Ok, what a pain reprogramming it. Of course, after work I'm in the dark trying to fly it. Turns out the rudder needs to be reversed, So I do that at the field which I can do because the screen on the transmitter has a light. (Who benefits from a time change that makes it dark when people get home from work?? Is it to make people watch TV?)
Wound up doing three packs before it got so dark I could only see the little green LED on the receiver. Sees to work fine again.
Old 03-06-2017, 06:12 PM   #8 (permalink)
Happier with the T6K after the Futaba V2 upgrade.
Best thing is the vibration when the timer is done. That works great when the transmitter is in a muff for winter flying.
The two extra channels are nice for FBL tweaking but my 450L files great with Spirit FBL, nothing needs to be changed.
My 250 needs lots of tweaking but won't work with the s-bus receiver for some reason. So I don't have access to the extra channels at this time.
Human Verification
