Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Compass 7HV, 7HVU and Chronos
Compass 7HV, 7HVU and Chronos Compass Compass 7HV, 7HVU and Chronos Model Helicopter Discussion
Like Tree13Likes
Old 01-06-2017, 03:31 PM   #41 (permalink)
Got it yesterday and put it back together....Need to do the wiring this weekend.
Protos Max 800 | Goblin 500 | Gaui X3 | Goblin 280 | Oxy 2
MXP 150 | CM Stigg
FrSky Horus | Spirit FBL | CC and HW ESCs
MyRCode is offline        Reply With Quote Quick reply to this message
Old 01-06-2017, 08:46 PM   #42 (permalink)
Nice! Check out the chronos picture thread. Theres some pics of mine with the canopy off for wiring ideas but im not too picky about wiring
dominator is offline        Reply With Quote Quick reply to this message
Old 01-06-2017, 08:49 PM   #43 (permalink)
Quick question about the battery tray pin...Is it normally hard to remove? I have to pull quite a bit even if I lift the battery tray to relieve some of the weight.
MXP 150 | CM Stigg
Old 01-06-2017, 08:55 PM   #44 (permalink)
Also, check out the Chronos build thread for more wiring ideas!
Scott
Team Rage-RC USA--Team Pilot
KBDD Team Pilot ):>
dunkonu23 is online now        Reply With Quote Quick reply to this message
Old 01-06-2017, 09:00 PM   #45 (permalink)
Scott
Already read it before the heli showed up .
Thanks for putting that together...it's very comprehensive.
I've also gone through the Chronos picture thread and I've got a pretty good idea of how I'm going to do it.
MXP 150 | CM Stigg
Old 01-06-2017, 09:53 PM   #46 (permalink)
Yes. Newer battery trays have a very tight fit and can be hard to insert or remove the pin. Over time it gets easier or you can take a drill bit the same size and open the hole a little
Old 01-06-2017, 10:30 PM   #47 (permalink)
Thanks for the tip!
MXP 150 | CM Stigg
Old 01-07-2017, 01:39 AM   #48 (permalink)
Drilled out the battery tray hole a little....It's much smoother now
Sent from my Pixel using Tapatalk
Old 01-07-2017, 10:22 AM   #49 (permalink)
If you come across anything else just let us know.
Old 01-07-2017, 02:16 PM   #50 (permalink)
Alright Gents, started my build today and first look she looks great! I got all the CF edges sanded and then per the manual started with the head! Couple issues I'm a bit miffed with because it will hold up building these particular parts!
- one of the inside bearing washers between the thrust and radial bearing is all chewed up on the surface against the bearings. Not sure it that will make a difference or not? Looking at it, it might work if I put the smooth side against the Radial bearing and the chewed up side against the thrust bearing.
- and lastly, thrust bearing washers are supposed to have one small ID and one large ID correct? well I have one small ID and 3 large ID! How important is the ID? think it will work ok with 2 large ID washers?
Not off to a good start! LOL I figured I would get a hold of Experience Monday and see if I can get these parts replaced. But until then kinda stuck with the head I think?
Any thoughts?
Also I just noticed there is another set of Thrust bearings behind the inside radial bearing as well! Not in the manual I'm so confused! LOL
TSA 700E Platiunm-----Compass 550U-----Gaui X4II-----BX-----Castle Creations-----Savox-----RJX-----Pulse Ultra-----DX9-----And other flying things!
FlyBri3 is offline        Reply With Quote Quick reply to this message
Old 01-07-2017, 03:59 PM   #51 (permalink)
Not sure about the other questions, but the new grips have two sets of thrust bearings in the head. Maybe the manual is an older version?
See the build thread here for some good photos.
https://www.helifreak.com/showthread...=739362&page=2
MXP 150 | CM Stigg
Old 01-07-2017, 04:36 PM   #52 (permalink)
Definitely get the correct thrust bearing. Contact experience rc they will take care of you. Let them know about the washers as well.
Old 01-07-2017, 10:10 PM   #53 (permalink)
My guess as well on the manual. Great thread for sure, I have been scrolling through it as I have been building for reference! LOL
I will definitely Give them a call monday, and I have no doubt they will take care of the issue! Just a bummer I have to wait to get one Bearing to finish my Chronos! LOL
Old 01-07-2017, 10:40 PM   #54 (permalink)
I feel your pain. I hate waiting. I should be building an exo tonight but im not. Fedex said it would be delivered today but it was delayed so now I wont get it until monday
Old 01-09-2017, 11:14 AM   #55 (permalink)
I called Experience and Steve their Compass guy was not in. So they had me email him with pics, So hopefully I will have a response sometime today!
Also will the Swash plate loosen up and break in on its own? I took the advise from Dunkonu23 to disassemble and clean it really well then put it back together. Slightly looser, but the screws holding the brass insert are just shy of snug with loctight. Just worried they will come loose in flight?
Old 01-09-2017, 01:05 PM   #56 (permalink)
No worries my swash is the same way. I did use high strength loctight. I tightened the screws until the swash started to get tight then backed off just a hair. Ive been beating the crap out of mine every week and nothing has come lose. Also add some oil to the swash to help keep it loose.
If you fly in really low temps you may need to adjust the swash so its not too tight when you go fly.
Old 01-09-2017, 06:52 PM   #57 (permalink)
As you can guess, I take apart everything! I think if you follow the suggestion to use high strength thread lock, you'll be fine. Thanks, Dominator!
Scott
KBDD Team Pilot ):>
Old 01-10-2017, 05:26 PM   #58 (permalink)
Regarding the Battery Tray Pin-I chamferred the end that is inserted into the frame/battery tray slightly.
It made all the difference in getting it installed easily!
KBDD-Team Captain/Compass Team Manager/Experience R/C/ Western Robotics Field Representative
Old 01-10-2017, 09:12 PM   #59 (permalink)
I talked to Steve at Experience RC today and my thrust bearings and washer will be shipped tomorrow! Happy about that.
How are you guys setting your head dampening on the Chronos for the first flights? I know it comes down to feel, but where to start?
Old 01-10-2017, 09:29 PM   #60 (permalink)
I adjusted mine to about 2mm short of max hard.
Scott
KBDD Team Pilot ):>
Human Verification
