Go Back   HeliFreak > R/C Electronics Support > R/C Related Electronics DIY
R/C Related Electronics DIY DIY R/C Electronics for tinkerers and the budget minded
Old 12-28-2016, 02:36 AM   #1 (permalink)
Default Getting 12V from two psu I need series
I was hoping some one could help me here
I have put together 2x HP DPS 1200FB A PSU to get a 24V system but would like to know what I have to do to run 12V fans and maybe a charger just on 12V
Is this possible ?
muzz22 is offline        Reply With Quote Quick reply to this message
Old 12-29-2016, 03:33 AM   #2 (permalink)
Default 12v from 2x 12v PSU
Ok so,plenty of reading just want to confirm if I have it right
I pull the 12v from the floated PSU?
Can some one please confirm this
Old 12-29-2016, 11:08 AM   #3 (permalink)
Yes, you need to tap off the charger that you did not float. Of course you need to be aware of load limits of the PSU. The fans or no issue but if you want to run a 12v charger, the load can be significant.
aziz76 is online now        Reply With Quote Quick reply to this message
Old 12-29-2016, 12:47 PM   #4 (permalink)
Default 12v supply
Ok thanks
As for load these are 1200w 100amp PSU
I don't plan on charging anything over 2C and will
Be running one only 406Duo
So should be ok?
Old 01-02-2017, 09:58 AM   #5 (permalink)
The 406 duo will be fine. My setup uses the same PSUs powering a pair of PL8s on 24V. The Bump Controller, all fans and the USB charging port are all powered from the 12V side of the non-floated PSU.
Paul
Agile 5.5 - Q 4125-1100, YEP 120, Brain2 HD FBL / Outrage 550 - HK4020-1390, Edge 120, Brain2 HD
Rave Ballistic FSO - Q 4530-500, Edge 160HV, Brain2 HD / Protos Max V2 - MSH 4530-500, Edge 160HV, Brain2 HD
pctomlin is offline        Reply With Quote Quick reply to this message
Old 01-02-2017, 02:01 PM   #6 (permalink)
Default 12v
Thank s for the info Paul
I am going with an ice meter from coolice and his psu connectors
Old 01-02-2017, 06:13 PM   #7 (permalink)
Good choice, Ian is a great guy and has a good product.
Paul
Old 01-25-2017, 04:28 AM   #8 (permalink)
Thanks for the compliment buddy, it's appreciated.
Ian
Ian Contessa
Coolice Charge Cases & Power Supplies
Facebook Page
Coolice is offline        Reply With Quote Quick reply to this message
Old 01-25-2017, 04:39 AM   #9 (permalink)
Well I have my ice meter, psu connectors ( make the job of connecting the two psu so easy )base plate, 3D mounts for the 406 charger and laser cut deck from Coolice and all I can say is perfection
Every piece is so precise and Ian even supplied me with templates for the bottom of the case to make sure alignment was perfect
Truly amazing work he does!
Old 01-25-2017, 06:10 AM   #10 (permalink)
Brilliant so glad you're happy with your kit of parts to build your own case and thank you for the compliment on the finish and quality of them to. It's appreciated.
Myself I am so pleased I purchased the laser cutter as it makes creating custom case's and parts so much easier going from PC screen to finished product.
Ian Contessa
Ian Contessa
Facebook Page
