Align t-rex 150 and 150x parts compatibility - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > 150 Class Electric Helicopters
150 Class Electric Helicopters 150 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 01-13-2017, 06:58 PM   #1 (permalink)
Default Align t-rex 150 and 150x parts compatibility
I'm starting a thread that lists parts compatibility. Please add to this list if you can. I think at this point, we can only assume that most mechanical parts are compatible. So the list of parts that aren't comp. would probably be shorter. These are parts that I have ordered and replaced on my 150X that only have a 150 DFC listing title. I'm hoping that stores will update soon.
Main blades: have used lynx 125mm and align 120mm without issue
Align swash leveler works
Landing gears
Feathering spindles
Main drive gear still 78 teeth
Main shaft works, although this is a downgrade unless going with carbon shaft, old 150 DFC is aluminum and bends easily. New one is steel, but have yet to see part available.
Tail boom and fin have been reported to be the same
cont...
Helyfreak is offline        Reply With Quote Quick reply to this message
Old 01-15-2017, 01:26 PM   #2 (permalink)
Align has a very handy parts finder to help identify the correct parts for your model. It is pretty good for the most part.
The link is in my signature.
dchekas is online now        Reply With Quote Quick reply to this message
Old 01-15-2017, 11:55 PM   #3 (permalink)
That part finder is quite useful. But those are parts direct from Taiwan. Im trying to come up with a resourceful list so someone can hop on their favorite parts supplier site and nab NOS parts on the cheap, or something like that.
Old 01-18-2017, 01:16 AM   #4 (permalink)
Has anyone tried the Microheli fiberglass canopy and how does it fit compared to the Align fiberglass one?
DX8 GEN 1, Phoenix R/C 5.5 ,Hyperion 720i DUO w/ MW 600 PS,Trex 250 se, Trex 150X, mCPXv1, mSRX, mSR, Walkera 4G#6S , Blade SR, Trex 470LM
prairie ville is offline        Reply With Quote Quick reply to this message
Old 01-22-2017, 01:08 AM   #5 (permalink)
I seen someone else posting about the 250dfc arm bearings are the same as the 150 dfc blade grip bearings.
The 250 dfc arm bearings are a suitable replacement for the blade grips on 150X.
cduuuub is offline        Reply With Quote Quick reply to this message
Old 01-23-2017, 06:56 PM   #6 (permalink)
I have the orange microheli canopy and it fits just like stock, which isn't really a good thing lol because of the battery issue, in fact, it makes it even harder because of how stiff the canopy is compared to the paper thin plastic one. I may modify instead of having to take canopy off, insert battery, reinstall canopy. but it was $20 and its very nice quality, I hate to have to cut it up, or dremel on it..
Old 01-23-2017, 10:38 PM   #7 (permalink)
I did cut the Align fiberglass canopy and the stock one for that matter. Cut the bottom to be able to slide the battery in and out without removing the canopy. But even after I did the trimming, the fiberglass canopy was still too tight width wise to get it on the frame posts very easily.
Old 02-22-2017, 05:53 AM   #8 (permalink)
Anyone knows if the new GRS board can plug directly into the original T-Rex 150?
Skickat från min Nexus 6 via Tapatalk
Dan_N is online now        Reply With Quote Quick reply to this message
Old 02-22-2017, 03:09 PM   #9 (permalink)
Default 150x GRS. FFF
Yes
I have 4 old 150s and just got a new 150x GRS. FFF of the new 150x GRS is identical to the old 150 part.
Align also improved the GRS gyro mounting tape. Align now use a gel gyro mounting tape which is a big improvement when compared with the old 150 gyro mounting tape.
Correction
On that FFF
Function of the new 150x GRS changed
Align added bail out with a 6 axis gyro added BT added better ESC provided easier setup and made improvements in repairablity .
Last edited by Memphis3; 02-23-2017 at 09:18 AM.. Reason: add Grs 6 axes w BailOut function
Memphis3 is offline        Reply With Quote Quick reply to this message
Old 02-23-2017, 03:27 AM   #10 (permalink)
Originally Posted by Memphis3 View Post
Yes
Correction
On that FFF the function of the new 150x GRS added bail out with a 6 axis gyro added BT a better ESC easier setup and repairablity improvement.
TNX
Old 03-08-2017, 10:19 AM   #11 (permalink)
Yes
Correction
On that FFF
Hi Menphis3.
Do you know if the new 150x "RX Board" works with the old 150 ESC ?
Tks
pvsat is offline        Reply With Quote Quick reply to this message
Old 03-08-2017, 12:14 PM   #12 (permalink)
My old T150 burned 2 RX board.
Anyone knows if the new 150X RX is compatible with old T150 ESC?
Old 03-08-2017, 07:21 PM   #13 (permalink)
Default New Old
Yes
I have a few old damaged 150 Fbl controllers.
Old damaged 150 Fbl controllers no one repairs them Super expensive +110$ to replace.
New 68$ 150x Fbl controllers can be repaired by swaping out a top or bottom boards.Expensive (28-46$) but repairable
No
Old 150 lower board and New 150x lower board are not compatible. Due to the FET chg and ESC chg
Again
New 150x Fbl controller can be installed in the old 150
Old 03-09-2017, 06:51 AM   #14 (permalink)
Yes
I have a few old 150 damaged Fbl contorlers.
Old 150 board damage
Fets burned or connection circuit board track torn. circuit board trace is a easy fix. Fets burned is not a easy fix.
Old 150 boards no one repairs them and IMO not repairable.Super expensive to replace.
New 150x board repair swap out top or bottom boards.Expensive but repairable
New 150x has a motor that is higher power.
so
Old 150 lower board and new lower board are not compatible
but Again
New 150x Fbl controller will work on a old 150
Thank you Memphis.
Old 03-11-2017, 03:17 PM   #15 (permalink)
Default Does the Align HOT00010 Blade Balancer work with the 150X?
Title says it all … from videos I’ve seen it looks like it relies on a press fit to keep the blades aligned horizontally with each other - I could imagine that that wouldn’t work with the newer 150X blades, due to the metal reinforcement. Anyone tried?
Thanks in advance,
Tim
tshead is offline        Reply With Quote Quick reply to this message
Old 03-12-2017, 03:57 AM   #16 (permalink)
Yes, I own one and works with no problem.
ALZRC TRex 450 Pro DFC
ALIGN TRex 500 ESP DFC
ALIGN TRex 600E PRO DFC (Power booster)
Goblin 500
joanpeca is offline        Reply With Quote Quick reply to this message
Old 03-12-2017, 03:52 PM   #17 (permalink)
Excellent, many thanks!
Cheers,
Tim
Old 03-12-2017, 06:55 PM   #18 (permalink)
Has anyone reading this thread linked a Trex 150X GRS to a Futaba T6K?
ESKY 150x, K110, Trex-150DFC, Trex-150X, Trex-250, Trex-450L, T-rex 450 SEV2, Trex-500X, Trex-550X, T-rex-700. Spirit FBL
ic-racer is offline        Reply With Quote Quick reply to this message
Old 08-08-2017, 07:49 AM   #19 (permalink)
Are you sure the main shaft from the two models are interchangeable? The design and dimensions look different.
abit late is online now        Reply With Quote Quick reply to this message
Old 08-09-2017, 02:51 AM   #20 (permalink)
DPW
Default Long n Tooth
I would not think extra 1.5mm in shaft length would make any difference in flight. The upgrade or increase in rotor arm length should make a improvement but again long or short shaft should not affect flight.
New Long Shaft
150 Main Shaft H15H014XX $6.99
Stainless steel Main Shaft 52.6mm
Old Short Shaft
150 Main Shaft H15H012XX $6.99
6061-T6 Aluminum Main Shaft 51.1mm
Upgrade Kit
New Long Shaft + Long Rotor
150 Main Rotor Holder Upgrade Set H15H013XX $17.99
6061-T6 Aluminum Main Shaft 52.6mm
Upgrade Rotor
150 Main Rotor Holder H15H015XX $16.99
and
It looks like if you want to do it right forget the upgrade kit and just spend the extra $6 and go with the 2 Stainless steel Main Shafts and the new rotors. H15H014XX + H15H015XX
Align450L / 470/150 DFC/Blade stuff
DJI/AR Drone
DPW is offline        Reply With Quote Quick reply to this message
Human Verification
