Main Forum - Helicopter Talk R/C Helicopters and the people who fly them. VENDOR TOPICS DO NOT GO HERE. Full Scale Heli threads go in OT please |
#1 (permalink) |
![]() There's been a space in the market for a reasonably priced high amp gendered connector for a while now, looks like the market finally responded.
From what I can figure out somebody in china made these, right now they sell for around $4-$5 per set but I'm sure HK will have them cheaper soon enough. |
#2 (permalink) |
![]() whats the amp ratings on this ones , looks as you have the housing throw the wire before soldering , and maybe the hole is for easier soldering
| Kraken 700 : Neo | Atom 6HV : Neo | vbct : | |
#3 (permalink) |
![]() Looks like a few places sell EC8.. In the US, you can get 2 pair at LowerHeil for $9!
http://www.lowerheli.com/lower-rc-ec...ctors-2-pairs/ ![]()
Walkera 4#3B, 4G6 Align 250SE, Gaui 200 Tarot 450PRO Align 550L Dominator |
#4 (permalink) |
![]() I like EC style connectors, I have not had and trouble with them. I have been going back and forth on which connector to use for super high current application. I want idiot-proof, like EC5.
I have now ordered Castle 6.5mm connectors, hopefully I will like them. 8mm even sound a bit to much, but it's very nice we now have an 8mm fully keyed connector.
Trex 700X - Logo 600 - Logo 690SX - Gaui R5 - V-Bar Control V-Bar Control flight analyzer (Win/OSX/Linux) - Latest release v5.0.0 July 5 - 2017 Sleipnir timing system - How fast can you fly? Only the ground is the limit! |
#5 (permalink) | |
![]() Join Date: Dec 2011
![]() Quote:
EC8's have the females on one side and the males on the other and have specific ESC and battery side housings that are keyed so they can only be inserted one way. |
#6 (permalink) | |
![]() Quote:
#7 (permalink) |
![]() I personally can't abide the Castle 6.5 connectors. I love their ESCs but the connectors suck. you have to spend way to much time fiddling with the "procedure" they suggest to snug them in, connect disconnect them....I mean don't we have enough to think about without dicking around with a connector. Not to mention the leads are far to close together for my comfort. I don't care about your terms for conductivity and you used to use wax paper between your wires and you never had any problems....If you look at one of those connectors the metal between the two leads is so close you'd need a micrometer to measure it. As opposed to EC 5s where there is a logical distance between conductivity. XT 90s are fairly decent. Just stay away from the Castles. Unless you like to waste time bending tiny metal connectors back and forth. EC 5s should work for most apps.
#8 (permalink) |
![]() I can't imagine many users requiring 8mm bullet connectors.
#9 (permalink) |
![]() I think an ec4 sized between the 3 and 5 would be a good seller.
#11 (permalink) | |
![]() Quote:
#12 (permalink) | |
![]() Quote:
#13 (permalink) |
![]() Yeah, of course I have checked them out too. But there isn't a way too build them 100% bullet proof, is there?
#14 (permalink) |
![]() Stuck with the same problem as Linus, speed helicopters and minimum space on the inside of fuselages, so I went with bullets. RCProplus 8mm bullets fit the bill perfectly. Easy to solder and super easy to wire up so that they fit inside the tight fuselages.
http://www.rcproplus.com/webe/html/p...num=54&kind=53
Gaui R5, Henseleit TDR, TDR2, TDF, TDS, TDSF Kontronik, Scorpion ESC, iChargers, VBar, VControl Old hand at Planks ![]() |
#15 (permalink) |
![]() I've been using them for years w/o issue. Just build the adjustment tool and use a lubricant on the contacts. Once properly adjusted they do not require frequent readjustment.
#17 (permalink) |
![]() You'd think that Amass or sombody would have seen the demand for a reasonably priced "foolproof" 6mm connector and filled that space in the market. It seems like such an obvious thing, just scale up the EC5 to 6mm and yet nobody has done it yet.
#18 (permalink) |
![]() Yay, scale up EC5, then they'll be an even bigger pain
Keith - XLPower Factory Pilot | KST Servos USA | Egodrift Motors USA | BuddyRC Flight Team Specter 700 | Protos Nitro | XL550 | Protos 380 KC3D LLC - 3D Printing on Demand and RC Heli Upgrades, Tools, Accessories, and More |
#20 (permalink) |
![]() Just can't stand EC.
