Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters
Other Makes and Models Helicopters Other makes and model Helicopters
Like Tree6Likes
Old 02-08-2017, 04:02 AM   #41 (permalink)
Default ALZRC Servo Specs
Originally Posted by cruzroy View Post
is way bigger than the 450,s i have, i will take a shot with my blade 300, and its pretty heavy, and i may be wrong, and did not search, but i couldn't find a suitable servo and size to go in this bird, they seem to be very good quality and fit with no issue just sometime china clone have lack of specs
i mean BK's are 64 plus a piece
I have done a lot of research on the ALZRC servos. They are OK. I have opted for the rebadged ALZRC DEKO's. So they are a very good spec. I dont think I have seen better for a 450 / 470 / 480. The BLS521MG. And the D1102 Cyclic. (both metal with heat sink cases)
0.025s for Tail and 0.058s Cyclic. (limited to 7.4V System operation)
BLS521MG
●Operating VoltageC4.8V-8.4V
●Speed and torque:
- 5.8Kg.cm/0.02sec/60°@8.4V
- 5.0Kg.cm/0.025sec/60°@7.4V
- 4.0Kg.cm/0.03sec/60°@6.0V
●Dimensions:35.9mm x 15mm x 31.9mm
●Weight:47g
●Motor:Brushless/1715m
●Wire Length:220mm
●Plug:FUT:JR Propo
D1102
●Operating Voltage: DC4.8V-7.4V
●Speed And Torque:
- 3.9Kg.cm/0.058sec/60°@7.4V
- 3.2Kg.cm/0.070sec/60°@6.0V
- 2.6Kg.cm/0.088sec/60°@4.8V
●Dimensions: 28(H) x 12(W) x 23(L)mm
●Weight: 18g
●Motor: Coreless
●Gear: Full Metal
●Dead Band Wigth: 0.8us
●Working Frequency: 1520us / 333Hz
●Case: All CNC Aluminum
●Bearing: 2BB
●Overload Protection: Yes
●Resolution: 4096
●Spilne: 25T
●Connector Wire: 28AWG
●Connector Wire Length: 230mm
●Plug: FUT;JR Propo
I have 2 x 380s in the build Queue a 2 blade and a 3 blade.
They are also getting.
Scorpion HK-2520-1580KV motors.
Hobbywing Platinum V4 60A ESCs
Beast or a DJI Naza-H. haven't decided yet.
I will be operating at 7.4 Volts and using one of my Futabas 18MZH / 18SZH or FrSky Horus X12. Haven't decided that yet either.
Thanks for doing the Build thread. I always like to pick up good build tips.
Cheers Brian
Here are the specs for the standard Servos if you don't have them already.
DS452MG Cyclic
●Name: Coreless Servo
●Brand: ALZRC
●Model: DS452MG
●Operating Voltage: DC4.8V-7.2V
●Working frequency:1520us/333Hz
●Speed and torque:
- 4.8Kg.cm/0.065sec/60°@7.4V
- 4.1Kg.cm/0.072sec/60°@6.0V
- 3.6Kg.cm/0.084sec/60°@4.8V
●Dimensions: 23mm x 12mm x 26.3mm
●Weight: 20g
●Motor: coreless/1215m
●Wire Length: 220mm
●Plug: FUT, JR Propo
●Usage: For 450-480 rc helicopter.
DS501MG Tail
●Operating VoltageC6.0V-8.4V
●Working frequency:1520us/333Hz 800us-2200us
●Speed and torque:
- 6.5Kg.cm/0.05sec/60°@8.4V
- 5.5Kg.cm/0.06sec/60°@7.4V
- 4.6Kg.cm/0.07sec/60°@6.0V
●Dimensions:35.5mm x 15mm x 28.3mm
●Weight:35g
●Motor:Coreless/1515m
●Wire Length:220mm
●Plug:FUT;JR Propo
BJR981S is offline        Reply With Quote Quick reply to this message
Old 02-08-2017, 07:38 AM   #42 (permalink)
Default project on hold
big north easter coming and moms is coming home from rehab.......so busy busy busy but i promise to come back
cruzroy is offline        Reply With Quote Quick reply to this message
Old 02-08-2017, 10:19 AM   #43 (permalink)
gotta take care of mom first, after all she brought you into this world....no matter how messed up it is.....
gassprint1 is offline        Reply With Quote Quick reply to this message
Old 02-08-2017, 01:53 PM   #44 (permalink)
these things happen, I too have had my fair share of set backs, take it easy.
Keeping It Simple, Slow and Steady FTW.
gimbleguy is offline        Reply With Quote Quick reply to this message
Old 02-08-2017, 10:23 PM   #45 (permalink)
Default OK part 4........the saga continues
a few things.......watch your motor and esc, might need to add wire, and some servo extensions, and i shortened my sat wire, i didnt want it 10 feet long, and 1 more thing
YES just put in 2 front screws for tail servo plate , so you can tilt out of way to squeeze tail boom in there, i think i should buy tail idler pullys
ID:	693362   Click image for larger version
ID:	693363   Click image for larger version
ID:	693364   Click image for larger version
ID:	693365   Click image for larger version
ID:	693367   Click image for larger version
ID:	693368   Click image for larger version
ID:	693369   Click image for larger version
ID:	693370   Click image for larger version
ID:	693372   Click image for larger version
ID:	693373   Click image for larger version
ID:	693374   Click image for larger version
ID:	693375   Click image for larger version
ID:	693377   Click image for larger version
ID:	693378   Click image for larger version
ID:	693379   Click image for larger version
ID:	693380   Click image for larger version
ID:	693382   Click image for larger version
ID:	693383   Click image for larger version
ID:	693384   Click image for larger version
ID:	693385   Click image for larger version
ID:	693387   Click image for larger version
ID:	693388   Click image for larger version
ID:	693389   Click image for larger version
ID:	693390   Click image for larger version
ID:	693392   Click image for larger version
ID:	693393   Click image for larger version
ID:	693394   Click image for larger version
ID:	693396   Click image for larger version
ID:	693398   Click image for larger version
ID:	693399   Click image for larger version
ID:	693400   Click image for larger version
ID:	693401   Click image for larger version
ID:	693403   Click image for larger version
ID:	693404   Click image for larger version
ID:	693406   Click image for larger version
ID:	693407   Click image for larger version
ID:	693409   Click image for larger version
ID:	693410   Click image for larger version
ID:	693411   Click image for larger version
ID:	693412   Click image for larger version
ID:	693414   Click image for larger version
ID:	693415   Click image for larger version
ID:	693416   Click image for larger version
ID:	693417   Click image for larger version
ID:	693419   Click image for larger version
ID:	693420   Click image for larger version
ID:	693422   Click image for larger version
Old 02-09-2017, 06:49 AM   #46 (permalink)
I bought the pulleys, the belt looked too close to the boom for comfort.
Added more clearance.
Align 450Pro 3GX, 500ESP/DFC 3GX, 500L, 550 DFC MicroBeast , Velocity 50 Vbar OS55 HZ-R, D380 DFC D420, G500 Sport Microbeast, All HW V4,
X5 stretch 220 Flame Emax Bullet Force V2 VTX
bad007 is offline        Reply With Quote Quick reply to this message
Old 02-09-2017, 08:43 AM   #47 (permalink)
Default are those SAB's pulleys
they fit good, i have Local Hobby that has, 3 times the money, alzrc are 20 days out
Old 02-09-2017, 11:32 AM   #48 (permalink)
Yup, got SAB parts. Didn't want to wait, what the heck it will turn into a GOB 1 part a time.
Also I didn't like the swash followers, the tiny flanged bearings got sloppy so I got a Gob head, Grips and Lynx Hybid DFC links so all matched silver
Old 02-09-2017, 12:53 PM   #49 (permalink)
Default cool that parts fit
cool that parts fit, i got 2 of these lipos coming,,,,they are cheap and i got ec5 i dont like deans ever since i lose my big gasser to a disconnect
Old 02-09-2017, 12:57 PM   #50 (permalink)
Default i got 2 of these lipos coming
GFORCE 40C 1500MAH 6S 22.2V LIPO (T CONNECTOR)
Be the first to review this product
SKU: LYB-LP-4582
Availability: In stock
$23.30
ID:	693549   Click image for larger version
Old 02-09-2017, 02:28 PM   #51 (permalink)
Default Between snow shoveling today
mom cant come home, no ambulance service caz dang snow, well cleaning up and made a 3d printed wall hanger for 380
if you want one, show me a picture of you ALZRC 380 and ill send you the file......those SAB guys can bite me.......LOL
ID:	693573   Click image for larger version
ID:	693574   Click image for larger version
ID:	693575   Click image for larger version
Old 02-09-2017, 03:43 PM   #52 (permalink)
You need min of 1800mah and then the tail is heavy. 1800 is good when you want it light to smack around
Ya, Deans are junk, had the same problem.
I ended up with PULSE 2200mAh 6S 22.2V 45C .
SAB Guys can bite me, LOL, now that's funny.
Nice hangers.
https://www.helidirect.com/batteries...o-battery.html
Old 02-09-2017, 08:25 PM   #53 (permalink)
Default wow twins
wow twins..............NOT!!!
Old 02-11-2017, 05:02 PM   #54 (permalink)
nice hangers and remote hanger. like it, very tidy on the wall....i'm guna get those same batteries when i finally get my 470LP kit.
Old 02-19-2017, 07:07 AM   #55 (permalink)
I see that the 60 amp speed controller is discribed as a HW 60amp V4.
Will it update to the HW FW and can the Hobby Wing wifi link be used?
If I buy one of these kits I may go with a HW 80 amp V4 for the telementary.
How is the motor and bearings, would I be better to change out bearings as a precautionor have there been no issues?
Are there any components that peopel are changing out to Sabb original during the build process?
I have seen a few threads regarding this heli and have been on the fence about weather or not to buy one.
Bob1 6s with Spirit Pro.
Bob 2 with Spirit Pro.
Bob 3 waiting on Spirit Pro.
Jeti DS-16. Whovian.
Necroscope is offline        Reply With Quote Quick reply to this message
Old 02-19-2017, 11:48 AM   #56 (permalink)
The ESC HW cone works with the LCD program box and the wires are long, no need to splice. The first time I tried to link to the PC I got a update and haven't tried since. I did notice the soft start comes on slow and then a slight uptick in speed and continues soft start just like the HW 60 V4. Your not going to use the HW 80 V4, it's huge and uses the same case as it's big brother. So far my motor bearings are holding up and run 3500 head speed @ 85 store gov with a 1 tooth over stock gear. Timing at 18 the motor and ESC are just warm. When the bearings crap I'm putting a Scorpion on it.
As for SAb parts lots are going to the tail assy and changing it out for the dampened, I did have to fight some tail vibes during the test spool on the bench with the control rod disconnected. I put KDBBs on and you could see them pitch off at 60% throttle. Flipping the hub fixed it and it's smooth and quit. I like
Anther thing is blades. The Alzrc ones I got had a bow to them and went to Switch since they have a safety strap and they work great.
I have 2 1800 and 2 2200 batteries, the 2200's set the COG just right.
Old 02-19-2017, 12:21 PM   #57 (permalink)
I think I'll build one of these as well, have everything to drop into an airframe... Has anyone done a vibe log on this bird? I'll be putting sk720 on it and they're sensitive...
Écureuil AS355n.50 600mm - Lynx 450xl ntm1700kv 350mm- KDS Chase 360mm Scorpion 1880kv SK720be/Ikon
Waxxingibbous is offline        Reply With Quote Quick reply to this message
Old 02-19-2017, 12:46 PM   #58 (permalink)
I run mine up on the bench to feel around for vibes, thought about putting the BX on the side but found the gyro place had next to 0 vibes felt when checking. Sides did.
Old 02-20-2017, 01:57 AM   #59 (permalink)
With the main and tail being belt driven, I would say you will be fine with an SK720BE. Is it a blue or black 720? I have 3 SK-720's, 2 black and 1 blue on Aligns and as long as you take your time to mechanical setup the heli propperly, as you would with any heli, you should have no issues. If I get one of these, I will probably put a SK-720 BE in it. Also the vibes will only effect the bail out function.
Old 02-20-2017, 06:39 AM   #60 (permalink)
The tail has been the only problem with vibes.. Also balance the entire head assy. I measured the thrust bearings stacked and found them to be uneven but swapping the brass spacer that goes under the outer radial bearing made them perfect.
Human Verification
