Like Tree5Likes
  • 1 Post By Memphis3
  • 1 Post By ov10mech
  • 1 Post By tommytt1
  • 1 Post By Vrooooom
Old 02-11-2017, 01:18 PM   #1 (permalink)
Question Bluetooth vrs USB
BEASTX BXA76015 BLE2SYS Bluetooth Smart Interface for MISCROBEAST Plus
I have a Beastx plus
Question
What is the advantage or disadvantage of BT vrs Usb?
the old
BTXA76007 BeastX Microbeast USB Interface
ID:	693813   Click image for larger version
Memphis3 is offline        Reply With Quote Quick reply to this message
Old 02-11-2017, 03:09 PM   #2 (permalink)
bluetooth interface no software update.... only settings to phone or laptop..
poli27 is offline        Reply With Quote Quick reply to this message
Old 02-15-2017, 12:39 PM   #3 (permalink)
Question BT & Laptop
thx
Can not find any documentation on BeastX Bluetooth. I guess that info comes with the StudioXm App download
Questions?
With BeastX Bluetooth..installed can you do the complete BeastX setup?
Can BeastX Bluetooth. be run from a laptop?
Vrooooom likes this.
Old 02-16-2017, 10:11 AM   #4 (permalink)
Hello,
the bluetooth LE interface is only working with smartphones at the moment. Unfortunately the API we use currently does not support bluetooth LE on Microsoft Windows.
Similar as with StudioX PC software this is only used for creating additional custom parameter setups. The initial setup procedure has to be done at the device and can't be performed from the smartphone (this may change with future firmware releases).
best regards from Germany
Stefan
BEASTX r&d Team
freakware.com
Frenchdress is offline        Reply With Quote Quick reply to this message
Old 12-27-2017, 08:23 PM   #5 (permalink)
Still looking for any instructions for using this BLE2SYS sitting in my hands. Can I fly with it installed or do I need to unplug it from the Microbeast Plus SYS port and put the ESC power in it's place? If I can fly with it do I need to put an ESC's BEC to some Y adapter to BLE2SYS to Microbeast SYS port so that I can power up the Microbeast as well? I'm using an Android BTW.
Thanks for any help!
Daddyodel is offline        Reply With Quote Quick reply to this message
Old 12-30-2017, 01:27 AM   #6 (permalink)
I found buried deep in the microbeast wiki never to fly with the Bluetooth interface due to RF interference... Hopefully nobody else is doing this.
Old 12-19-2020, 08:13 AM   #7 (permalink)
I ran across this thread and wondering if the Bluetooth interface can support updates and if its feature parity with the USB one.
tommytt1 likes this.
ov10mech is offline        Reply With Quote Quick reply to this message
Old 12-23-2020, 09:50 PM   #8 (permalink)
I use the Bluetooth and StudioX on my iPhone, and did the update to V5.2 pro as well as the new setup afterwords. Works great
Sent from my iPhone using Tapatalk Pro
tommytt1 is offline        Reply With Quote Quick reply to this message
Old 12-25-2020, 10:59 AM   #9 (permalink)
I have both bt and usb. The ease of setup either at the device or on StudioX with usb is easier than the current bt programmer. However, no better replacement than Bluetooth at the field. Last weekend at a fun fly a friend recommended some governor changes (turn off the Beastx gov).
It was simple to check everything and also make some minor parameter adjustments. I also have an esc programmer.
A fellow pilot was spooling up his Kraken 700 on itís maiden flight. It went wrong because the flight controller response was reversed. The Studio X has programming procedures to prevent this tragedy. So thoroughly setup the heli on the bench, motor disconnected and do a maiden without worrying about the parameters. And always check your swash and tail response!
Merry Christmas and Happy Helidays!
Fusion 360 M2V2 Trex 500X
Goblin 580, 12s
MicroBeast Plus Pro.
DX8 g2
Vrooooom is offline        Reply With Quote Quick reply to this message
Old 06-06-2021, 03:27 PM   #10 (permalink)
It sounds like you need to set-up the FBL using the transmitter or StudioX USB on the PC. However, is there functionality lost using the Bluetooth and corresponding phone app?
For example, I like to play w/ the custom roll rates on Parameter Menu B (Control Style). Would I be able to change the custom roll rate there from 320 deg/sec to 360 deg/sec while at the field using the bluetooth?
Thanks!
Gaui X3, X5, Protos 700
heychas is offline        Reply With Quote Quick reply to this message
Old 06-08-2021, 08:20 AM   #11 (permalink)
Yes, however I think the BT programmer is discontinued.
heychas likes this.
Goblin 580, 12s
DX8 g2
Old 06-08-2021, 04:22 PM   #12 (permalink)
Thanks Vroom! It seems like there are some non-labelled Chinese ones available on ebay. I may try one of those.
Old 06-20-2021, 02:48 PM   #13 (permalink)
Default Purchasing a BLE2SYS
I purchased a "white" non-labelled BLE2SYS from China. It arrived fairly quickly (2 weeks), at a good price ($35), and it works great! I'm pleased with it. It is nice to be able to modify things at the field.
In case anyone was wondering what the phone app for the BLE2SYS from StudioXm looks like, it is identical to the StudioX software used on the PC.
