Mikado V-BAR Control Mikado V-Stabi/V-BAR Control Flybarless System Software and Hardware Support |
#1 (permalink) |
![]() I am fairly new to the VControl. I am going to setup my Diabolo 550 (550mm blades). Do I start with the 500 heli setup program ?
Diabolo 700 BE, 600, Synergy-696, E5SS, Logo 600, 200, Goblin Raw 700, VCT, VBar, Egodrift, Scorpion, Kontronik, MKS, XPert, KST Last edited by Freeskiken; 02-14-2017 at 07:15 AM.. |
#2 (permalink) |
![]() I setup my Goblin 570 under Other 600..
OptiFuel TEAM PILOT
#3 (permalink) |
![]() Join Date: Jun 2009
![]() Thank you. That's what I am not sure about for a 550 do you use 500 or 600 ?
Diabolo 700 BE, 600, Synergy-696, E5SS, Logo 600, 200, Goblin Raw 700, VCT, VBar, Egodrift, Scorpion, Kontronik, MKS, XPert, KST |
#4 (permalink) |
![]() Never set up a 550 on vcontrol. But, I've flown plenty. My feeling is they are closer to a 600 feel than a 500 feel. So I'd start with 600 setup if it were mine to do. I redid my 600se once from the 600 preset by accident and honestly couldn't tell the difference in the air. I think once you go through the tweak guide you'll dial it in perfectly either way.
˙ʇı ʞɐǝɹq 'ǝʞoɹq ʇ,uıɐ ʇı ɟı |
#5 (permalink) |
![]() I think if it was me I would compare the data then make the call. Here is some basics for align helis.
500 935mm Main blade 470mm Tail blade 78mm Weight 1450g 550 1163mm main blade 550 tail blade 90mm weight 2590 600 1160mm main blade 600mm tail blade 95mm weight 2900 http://www.aligntrexstore.com/T-REX-...7X_p_4773.html http://www.aligntrexstore.com/T-REX-...X-_p_4587.html http://www.aligntrexstore.com/-T-REX...4A_p_4365.html |
#6 (permalink) |
![]() I setup my Diabolo 550 using the 500 on the VBC. I only needed to adjust the tail gain on the maiden, the rest was spot on
Henseleit TDR2 - TDF - TDSF - Glogo - L690sx - Strike 7 - Agile 7.2 Gasser - KDS A7
3DME Alloy Vtouch Design Team www.inverteddownunder.podbean.com |
#7 (permalink) |
![]() Not sure of your setup...
Diablo 550 1060mm Blades 550mm Tail 80mm Weight 2100 grams http://minicopter.de/en/diabolo550 Last edited by Shawn550; 02-17-2017 at 07:45 AM.. |
#8 (permalink) |
![]() I asked the same question on Vstabi.info and the answer was to start with the 500 setup. And change the heli size value a few points "in between" ;-)
#9 (permalink) |
![]() Good to know this.
- Michalis |OXY Heli|XNova Motors| ...let the flying be second nature! |
#10 (permalink) |
![]() I think that may make sense as the diabblo tail blades are 80mm and the align 500 tail blades are 78mm.
#11 (permalink) |
![]() You can use 85mm as well, which i will install on my setup.
#12 (permalink) |
![]() Heli size value in between???
DIABOLO 550, DIABOLO 800 (ORDERED) SAB: KRAKEN VCONTROL*NEO*TRIBUNUS*MKS*TORQ*VTX*DPL8 W/BUMP CONTROL*MEANWELL |
#13 (permalink) |
![]() Heli size selection is not that critical to get it exactly as it merely is a function to let the control loops have a starting point for mass distribution. Normally use the size value closest to your helicopter size and all will work perfectly.
Gaui R5, Henseleit TDR, TDR2, TDF, TDS, TDSF Kontronik, Scorpion ESC, iChargers, VBar, VControl Old hand at Planks ![]() |
