Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > NX4
NX4 Discussion and support of the Gaui NX4 Nitro Helicopter
Old 03-07-2017, 07:03 PM   #1 (permalink)
Default G10 Gasser reviews
I'm thinking of trying the G10 motor set up. I love this heli on nitro the smell the sound with a hatori pipe the power just love this heli I have two and 3 os 37 and two hatori pipes...hoooooowever 50 cents per flight ....I just can't help being g curious...it's been about three years now so what it the verdict on the nz4 gasser should I do it is it worth it?? How long does this gasser motor last with proper break in 5 tanks or whatever. ...
Allincrazyforit is offline        Reply With Quote Quick reply to this message
Old 03-08-2017, 05:57 AM   #2 (permalink)
Will let you know after I can get it to run flight rpm for over 2 minutes
Will sit and idle all day
Drive safe, Play safe, Fly safe.
Agile 7.2,forza 450, 600N.
GauiX3,X3L,X4II,X4IINF,X4IIS,GX4,X5,X6,X7.
Synergy E5,516,N5C,N556,OhOh +766
thebirdman is offline        Reply With Quote Quick reply to this message
Old 03-08-2017, 10:55 AM   #3 (permalink)
I had one for a while. It was great. Much more powerful than the 37, but you feel the weight.
The reason I sold it was it was too smelly. I keep my nx4 in the trunk, and with the gas in the trunk my car always smelled like a gas station.
It was a pain to break-in, but just do it. I would let mine run in the yard while I was controlling it from my house with no blades or anything on. You have to keep blipping the throttle. And to idle a tank on a gasser takes hours. I did it watching the NFL draft. Just be patient.
The other thing I wouldn't run an aluminum case tail servo. The tail servo is right next to the fan draft for cooling the motor. The aluminum case is suppose to be a heat sink. But if the ambient temp is higher than the servo, it acts as a heater. I had a kst go bad on me like that. Just something to watch out for. Or if you must use an aluminum servo, I'd try to insulate it somehow.
bgymr is offline        Reply With Quote Quick reply to this message
Old 03-09-2017, 02:25 PM   #4 (permalink)
T10 in my experience is bad for me.
Long Break-in and hard to setup.
Do not perform well in 3D, kind a slow or has no power due to its weight.
JR Vibe 50 NEX FBL - HC3-SX
Gaui NX4 - HC3-SX
JR 450 Forza - Spirit Pro
Rave 450 FBL - Spirit FBL
nard712136 is offline        Reply With Quote Quick reply to this message
Old 03-14-2017, 08:35 PM   #5 (permalink)
My experience has been really positive. I took the time to break it in very gently, and now it runs stronger than the 37, for double the flight time.
Breakin isn't that painful, I wired up AC/DC adapters for the CDI, throttle servo and RX (used failsafe so I could shut off my TX). It was so easy I did 15 min heat cycles. I ran Lawn Boy ashless for breakin, now running Redline, both at 10:1.
Converting to gasser is all up to you. I love the flight time, but I certainly understand that you have an investment in nitro engines/pipes. I did as well, but for me, it was worth it. But then again, I'm terrible at not spending money on this hobby. If you have other nitro birds, carrying 2 fuel cans might be a consideration for you.
I've been using racing gas without Ethanol, so no smell!
How do you make a small fortune in this hobby?
Start with a large one!
HelisRock is offline        Reply With Quote Quick reply to this message
Old 03-15-2017, 09:47 PM   #6 (permalink)
Ya I just bought another hatori pipe and I love the smell of nitro. .but I think I'm gunna try the gasser set up ..I'll just call it an early bay and Christmas present to my slf . Just forr the experience. ..I figure 500 bucks to get all set up.?? Does that sound right?? Also I think I'm gunna set the motor up on a board with a prop. To break it in.. and idea what size prop to use?.. any experience with this break in method? Is it safe for the motor. ..Ps thanks for the replys precieat the information
Old 03-15-2017, 09:57 PM   #7 (permalink)
Check out the build thread over in the Gas Powered Thoughts forum.
Here's the break-in video using a test stand and props.
T10 Breakin Procedure (5 min 36 sec)
Gaui X3, X4II, NX4 - Vbar / 14SG
guinness221 is offline        Reply With Quote Quick reply to this message
Old 03-31-2017, 07:55 PM   #8 (permalink)
how's this engine doing on a hot summer day? Is it over heating?
joecass2 is online now        Reply With Quote Quick reply to this message
Human Verification
