Old 03-09-2017, 07:43 PM   #1 (permalink)
Default Recovering Firmware in Bump Controller
So just got my iOS app and loved that it automatically updated firmware straight from the app. Updated the firmware on the bump controller. Great. Then tried updating the firmware on my PL8. It failed. I had to disconnect, connect to my laptop and update firmware through my laptop. All set. Except ... the bump controller can't figure out that the firmware is all set. Even if I disconnect the charger altogether. Message is attached. Thoughts?
Compass 7HV (SK720BE w/GPS1)
Oxy4 (SK720BE) / Oxy3 (SK720 Blue)
JR 11X
Shabill is offline        Reply With Quote Quick reply to this message
Old 03-09-2017, 07:59 PM   #2 (permalink)
Never mind; I figured it out. I turned off channel 1 in the bump controller settings and then turned it back on and that seemed to do the trick.
JR 11X
Old 03-09-2017, 08:52 PM   #3 (permalink)
After the PL8 firmware upgrade failed, did you attempt to retry (after power cycling) ?
Our testing has shown that it will indeed fail occassionally on the first attempt, but has always succeeded on the 2nd attempt ... so curious to see if if everyone else experiences the same.
RevoKelly is offline        Reply With Quote Quick reply to this message
Old 03-10-2017, 11:28 AM   #4 (permalink)
No, I wasn't able to get it to restart through iOS after it failed. I tried, and when that didn't work, went in through my laptop.
And as an update, as it turns out, now whenever I power on the charger, the same message shows up on the bump controller and I have to go into the bump controller and disable and then re-enable that charger.
JR 11X
Old 03-10-2017, 02:42 PM   #5 (permalink)
Strange. Ill see if i can recreate it.
Old 03-17-2017, 11:23 AM   #6 (permalink)
No luck recreating? I can't make it stop.
Well, there is one solution (for me) ... since I only have 3 chargers, think instead of using 1,2,3, will use 2,3,4.
JR 11X
Old 03-17-2017, 02:01 PM   #7 (permalink)
I cant recreate yet, but will add a feature to next release that workaround it by resetting that upgrade state anytime the port is enabled/disabled.
If you dont want to wait for that release, just go i to settings -> Factory Reset. That should clear the problem, but youll need to do setup again on the Bump - power supply settings, wiring mode, etc., will revert back to default values.
Old 03-17-2017, 04:20 PM   #8 (permalink)
I can wait for the update. Thanks!
JR 11X
Old 04-25-2017, 02:56 AM   #9 (permalink)
I've just had exactly the same issue and even after multiple power cycles, the PL8 firmware will still not update. I just hope I can find my USB cable and update the firmware via my PC
Kasama UK | Bavarian Demon
wadders248 is online now        Reply With Quote Quick reply to this message
Human Verification
