Go Back   HeliFreak > R/C Helicopter Support > OXY HELI > Oxy2
Like Tree1Likes
Old 03-20-2017, 12:37 PM   #1 (permalink)
Default OXY 2 build tips and tricks
Tail Bell crank.
Do not force it in from the end. This will risk bending these small parts. Once everything is mounted they are a lot stronger.
What I found.
Lay it in close to/on the boom between mount arms. Then slide it out and into position. This will keep from bending parts trying to force it in from the end.
Lynx/OXY HELI Team Manager,
AMA card holder.
Horus X12S for my TX, FAA number: FA34W9YLXT
RichKnapp is offline        Reply With Quote Quick reply to this message
Old 03-20-2017, 12:42 PM   #2 (permalink)
Servo leads.
If you run them over the top on the upper bearing block.
IF you run them on underside of the upper block. You will have more clearance between the shaft and leads than on the top side of the block and the leads to shaft collar clearance.
AMA card holder.
Old 03-20-2017, 03:34 PM   #3 (permalink)
Default Oxy 2
I used a little hot glue to hold the servo lead in place.
Lynx team pilot Oxy 4 ,3 ,2 , Pulse Batteries, BK &Kst servos and Castle creations
Carder is offline        Reply With Quote Quick reply to this message
Old 03-20-2017, 03:48 PM   #4 (permalink)
Yes that shaft collar is huge!!!
Oxy 2 FE x 2, 180cfx full Rakon uBrain v2 BA-8-1 cyclic H0988UHS tail, 180cfx spartan lynx pro tail, 130 full rotary bx, 130 Xtreme build, 130x stock, nano cpx dbl bl, nano cpx wild bl, DX8, Phoenix sim for practice. For fpv Phantom 3 pro.
Bhujang is online now        Reply With Quote Quick reply to this message
Old 03-20-2017, 08:34 PM   #5 (permalink)
formerly koi-fish
Wow, am a little amazed at the size of size of these things. A big help that some assemblies are predone from the factory.
I'm a little paranoid about not putting loctite on myself in places where the manual says it's already done, but I'll trust Lynx on this
About got the tail assembly done
Needbiggerheli likes this.
/ 180cfx, 300x, X3,X4-II, Protos 380, Chase 360, x5, Logo 480, Gob 380, Gob 500, Gob 570, Warp 360, 450x, forza 450/450ex, T-Rex 600 Dom, Logo 600, DX18, 07 Harley Road King, 1973 Ford f100, Traxxas Summit/X-Maxx
"Everyone wanted his soul, all he gave them was a smile" - Steve Marriott
Diogenes is offline        Reply With Quote Quick reply to this message
Old 03-20-2017, 08:41 PM   #6 (permalink)
You should check it all . If it dose not come apart easy then its good
Align T rex 550 E DFC
Oxy3 ,Oxy4
super bad is offline        Reply With Quote Quick reply to this message
Old 03-20-2017, 09:20 PM   #7 (permalink)
formerly koi-fish
Ya it seems ok, ne thing pitch slider seems a little tight. Anyone else run into this? How did u resolve?
I have it narrowed down to the pitch slider links. Do they go on only one way? Testing this next
Old 03-20-2017, 09:24 PM   #8 (permalink)
^^^^^ https://www.helifreak.com/showthread...=775247&page=6
Might need to read last 2 pages
LYNX/OXY Team Field Rep [Oxy 2][230s][Trex 450L~6s][Trex 500][Hirobo 550 Nitro][Phantom 3 pro] And others that don't deserve to be listed!
adjday is offline        Reply With Quote Quick reply to this message
Old 03-20-2017, 10:13 PM   #9 (permalink)
I use the purple.
AMA card holder.
Old 03-20-2017, 11:36 PM   #10 (permalink)
Would a mini Vbar fit in this heli?
salrica is online now        Reply With Quote Quick reply to this message
Old 03-21-2017, 02:31 AM   #11 (permalink)
The pitch slider links do need loctite and are not factory complete.
Old 03-21-2017, 04:33 AM   #12 (permalink)
I have this problem also . It looks like the pins are too wide , when i turn the slider wheel i can feel them grind and sometimes stop the wheel from turning and its not allowing the pitch slider to move freely. I put washers on both pins and its a little bit better , i might try to file the pins on the sides to get them thinner but these things are so small ^^
Edit: the inside of the pitch slider i also filed (as described) and movement is alot better
Align 470LP, ALZRC 450Rigid ,ALZRC D380,Oxy2FE,Blade 230s,Blade 180cfx,XK-K110
Spazztl is offline        Reply With Quote Quick reply to this message
Old 03-21-2017, 04:33 AM   #13 (permalink)
deleted
Old 03-21-2017, 02:09 PM   #14 (permalink)
formerly koi-fish
Ok I'm,gonna ask a stupid question, the front boom insert, is it permanent or temporary piece during assembly?
Old 03-21-2017, 02:11 PM   #15 (permalink)
Well I wouldn't want to try and take mine out man that was hard to get in flush
Also the new belts will be sold with them. So yes I think permanent
Old 03-21-2017, 02:20 PM   #16 (permalink)
Permanent.
You will need to spread the Boom clamp box a little wider than you do with a OXY 3, but it is there to prevent the boom from crushing when you clamp down on the boom.
Unintended use I found. Keeps the belt from twisting. IT CAN still be rolled.
AMA card holder.
Old 03-21-2017, 02:23 PM   #17 (permalink)
Remove:
Remove the tail end block.
Pull belt through to front.
Pull it out using the belt.
DONE
AMA card holder.
Old 03-21-2017, 02:31 PM   #18 (permalink)
Originally Posted by RichKnapp View Post
Remove:
DONE
that might work. Mines in so tight the belt might snap
But hey I'm not intending to take it out as this won't be a beater heli for me. I will only be doing what I'm capable of so no crashes
Thanks for the tip though one day maybe hey
Old 03-21-2017, 08:21 PM   #19 (permalink)
Quick question on the tail. Mine is binding throughout the range of motion with no increase or decrease anywhere in the range. I pulled everything apart individually and built everything one by one again checking after each piece is assembled. I have isolated it to the ball links. They are a little too tight. One at a time is not bad but when you combine all 3 at the back of the tail and the one for the servo it adds up quick.
What are you guys using to ream these little guys a little? I definitely don't have a reamer this small and I don't have an extra ball to crimp for a diy reamer.
brewer00psd is offline        Reply With Quote Quick reply to this message
Old 03-21-2017, 08:25 PM   #20 (permalink)
Been posted earlier they are using the spare ball in the parts bag. Cutting a groove in it. Use a 1.3mm driver to turn it.
AMA card holder.
Human Verification
