Like Tree3Likes
  • 1 Post By AlastairC
  • 1 Post By Puttputt maru
Old 03-24-2017, 01:03 AM   #1 (permalink)
Default Tribunus / Jeti Telemetry RPM reading
I install the Jeti to the Tribunus and everything is great my only problem is when it reads the RPM I have no clue were to put the pole of the motor and the gear ratio for a correct read on the Jeti is reason 5-6k... is it on the software or on the Jeti tx.... can't find in either, only on the Scorpion software but work on standard reading and not for Jeti
Diabolo 550 / Diabolo 700BE /Triabolo 700 / Srimok 90N
Goblin-700/700C/KSE/BlackNitro/380/Logo700/Trex600NSP
Jeti DS-14 Edition
Grittner is offline        Reply With Quote Quick reply to this message
Old 03-24-2017, 01:34 AM   #2 (permalink)
Scorpion software, Help -> Preferences.
A bit unusual place to do it.
RC-Thoughts.com - TeroS formerly known as CP-Geek
TeroS is offline        Reply With Quote Quick reply to this message
Old 03-24-2017, 01:58 AM   #3 (permalink)
I did that but did not work on the jeti
Jeti DS-14 Edition
Old 03-24-2017, 04:09 AM   #4 (permalink)
Then we have to assume a bug somewhere in tribunus sw?
Old 03-24-2017, 06:00 PM   #5 (permalink)
The "Preferences" only seems to change the readings in the software and not over ExBus.
There is also an issue with the RPM display/logging when it gets to a high value:
Looks like they are not using a large enough variable type and it is rolling over.
Gaui R5 + Tribunus + HK-4530-540KV + 14S Optipower + Bavarian Demon Axon
Gaui X3L Speed & Gaui X3 + Bavarian Demon 3SX
Jeti DS-16, Citizen 625, MHSFA 13
Member of East Fortune Aeromodellers
AlastairC is offline        Reply With Quote Quick reply to this message
Old 03-25-2017, 02:56 AM   #6 (permalink)
Attachment 700064
Sure looks like its 65535 so you have to be right on that. We've all been there
Old 03-25-2017, 04:37 AM   #7 (permalink)
Yup ;-) Well at least either of us could send them some code
Old 03-25-2017, 06:37 AM   #8 (permalink)
I gotta admit, I laughed
Old 03-27-2017, 08:06 AM   #9 (permalink)
I have passed Georges van Gansen a link to this thread. So hopefully we can get some help from the Scorpion guys.
Old 04-11-2017, 04:35 AM   #10 (permalink)
Just as an update to say that the latest firmware (v48) fixes the RPM overflow bug in Jeti. So the RPM will appear correcly. I am going to try and write a LUA app that lets you input gear ratio and poles to create a headspeed value.
yamahahoyt likes this.
Old 04-20-2017, 04:53 PM   #11 (permalink)
This is great news especially since I have a Tribunus that just came in.
I just thaught I would share some initial feedback on it:
Let me compare it with other ESC:
Hobby wing 160A which if the Tribunus had a full casing would compare in size lengthwise but is still about 2 mm thicker.
And the Kontronik 200A which is an elephant compared to the Tribunus longer and way way much thicker.
Finally the weight:
Tribunus: 190.68g with the full wires
Hobbywing: 286.28 g with wires. I guess scorpion was wise not to incase the full ESC
Kontronik: 240.40 g but without any wires or nuts and bolts to hold down the wires.
So far the Tribunus wins hands down. I hope everything else will be as impressive. Lets see how the integration will go.
im4711 likes this.
TDR-II, Triabolo, 2 X TDR, Logo 700,Protos evoluzione, T-Rex 700Dominator, Goblin700, Axon Spirit, Jeti DC-24, Mezon,HW,Kosmik,Jive Pro
Extreme Flight MXS 3W110, Ultimate Aeroworks 20-300, DA 170, CB200, Cortex, Q80-8M in a 91" EF Extra + few jets
Puttputt maru is online now        Reply With Quote Quick reply to this message
Old 10-09-2017, 04:19 PM   #12 (permalink)
Default LUA App already written
Hello,
did anyone have the LUA app to get the correct rpm of the Head?
In combination with Tribunus and Jeti Telemetrie?
Best Regards
Wieland
yamahahoyt is offline        Reply With Quote Quick reply to this message
Old 10-10-2017, 05:06 AM   #13 (permalink)
If you go here:
https://www.rc-thoughts.com/lua-hub/
and scroll down you will see the RPM to Headspeed app I wrote.
It does not save to the jeti log. So I assigned a switch to read out the value if you dont want to look at the screen.
Originally Posted by yamahahoyt View Post
Hello,
Best Regards
Wieland
Old 10-22-2017, 06:10 AM   #14 (permalink)
Updated version of my RPM to Head speed application that now logs into a jeti log file on the SD card and you can use the Jeti Data Analyzer on the transmitter to view the log
https://github.com/AlCormack/JetiLua
vasylp likes this.
Old 10-22-2017, 12:02 PM   #15 (permalink)
Am I missing something here? Why would someone need an app to view and/or record headspeed? The Brain and Scorpion do this very well without anything extra needed?
GravityJunkie is offline        Reply With Quote Quick reply to this message
Old 10-22-2017, 12:29 PM   #16 (permalink)
The Scorpion only outputs motor rpm in real-time direct to a Jeti RX. So to display headspeed you need an app to do it.
If you have a jlog or a brain that does the conversation you are ok.... but not without an intermediary.
Old 06-23-2019, 05:20 AM   #17 (permalink)
AlastairC
good work
Thank you
vasylp is offline        Reply With Quote Quick reply to this message
Old 06-23-2019, 11:29 AM   #18 (permalink)
Originally Posted by vasylp View Post
AlastairC
good work
Thank you
No problem. Happy it helps! My apps are available on the Jeti app store (from the Jeti Studio Application) So you can try my speed and drag racing ones, if you have a GPS.
I am on the V5 firmware beta team. So will be working on some new apps to take advantage of the new features it gives.
