Old 04-24-2017, 12:02 PM   #1 (permalink)
Default Can I run a 4035 scorpion motor on my trex 600 dfc pro
Can I run a scorpion mk3 4035 560kv on my trex 600 dfc pro?
Banburen is offline        Reply With Quote Quick reply to this message
Old 04-24-2017, 04:28 PM   #2 (permalink)
Too wide I think but 4025 will definitely work.
Blade400
pril250 is offline        Reply With Quote Quick reply to this message
Old 04-24-2017, 08:35 PM   #3 (permalink)
HF Scale Support
As long as you are using stock gearing, it will have enough clearance, but just barely. I ran a 4035 450kv motor for well over three years and didn't have an issue with stock servos. I did change servos and did have a bit of rub but that was caused by a hard contact hit with the ground. I switched back to the original 510 600MX motor and it has lots of clearance with the new servos. Have fun.
Don
Old 05-04-2017, 11:27 PM   #4 (permalink)
Got it to fit barely with the kde motor mount. Can't post pics.
Old 05-09-2017, 09:43 PM   #5 (permalink)
Turns out it fits
ID:	706938   Click image for larger version
Urukay 3 Blade Align 600L BK Servos
Microbeast Plus Graupner MZ-24
A VOLAR!!!
Old 05-11-2017, 03:03 AM   #6 (permalink)
I would recommend the Performance Booster kit if you don't have it already. The kit comes with a new motor mount that shifts the motor position a bit more forward to give more servo clearance and provides you with a new main gear to make the conversion work. I would hate to see those nice servo cases get scratched up by the motor bell under hard loads.
Andreas M.
Compass 7HVU
Logo 600SX V2
Blade 450X
Heli.Maniac is offline        Reply With Quote Quick reply to this message
Old 05-22-2017, 08:16 PM   #7 (permalink)
It has the performance booster kit alongside the kde adjustable motor mount.
A VOLAR!!!
Old 05-23-2017, 02:21 AM   #8 (permalink)
I always wondered if one could fit the KDE mount with the new bigger main gear. I guess it is possible after all, which is quite surprising for me.
Andreas M.
Compass 7HVU
Logo 600SX V2
Blade 450X
Old 05-23-2017, 06:49 AM   #9 (permalink)
I've been running the HKIII 4035-530Kv in my 600 Pro for years, no problem at all providing you use the performance booster kit. With the 560Kv version you would want to drop a tooth off the pinion.
Old 05-24-2017, 01:30 AM   #10 (permalink)
i glued some aluminium foil no my servo's, to reflect some heat from of the rewound 700mx
apper001 is offline        Reply With Quote Quick reply to this message
Old 05-24-2017, 06:45 AM   #11 (permalink)
I'm not sure that's a good idea, as it keeps the heat the servos generate themselves from dissipating.
getsuyoubi is offline        Reply With Quote Quick reply to this message
