Go Back   HeliFreak > R/C Helicopter Support > Gasser Helicopters
Gasser Helicopters Gasser Specific Discussion
Like Tree1Likes
Old 05-15-2017, 09:06 AM   #21 (permalink)
We are working from new kits.. will have a few leftover parts like the frame and electric motor mount etc.
doug
TRM Power - RC Racing Engines - - Blackout Mods Conversions - - VP Racing / Powermaster Fuels - - Gas-Powered-Helicopters.com
Doug Darby is offline        Reply With Quote Quick reply to this message
Old 05-15-2017, 10:37 AM   #22 (permalink)
Maybe see if Compass could put together a could minus the parts not needed to complete the build as Helidirect did for the Goblin.
~Jim~
Goblin700 Gasser TRM-300, BD Axon,
Align700E w/HC3SX, and a Goblin 380 w/BD3SX, using Futaba 14SGH
KSHeli is offline        Reply With Quote Quick reply to this message
Old 05-15-2017, 10:40 AM   #23 (permalink)
What engine does this use RC or PUH?
We had a great country once. You know what made it great? “I can.” Then the weak came along, “the I cant’s” and destroyed it.
Rudy is offline        Reply With Quote Quick reply to this message
Old 05-15-2017, 12:15 PM   #24 (permalink)
The best way to build this would be to get a donor electric? Or Buy individual parts from protos Like the head and tail?
Its possible that there may be "short" kits offered as are done for the Goblin, Agile and Synergy conversions. Since the model hasn't flown yet, a little too soon to go down that path
Neither, this is a different format (name to be determined), very similar to the CRRC engine however with a better mounting system and machined in TRM performance improvements
Carey Shurley
Proprietor - Gas Powered Helicopters
carey shurley is offline        Reply With Quote Quick reply to this message
Old 05-15-2017, 02:29 PM   #25 (permalink)
Will this engine only fit the Max, or would it fit for example the Hirobo Freya (instead of the GT15HZ)?
bbrc77 is offline        Reply With Quote Quick reply to this message
Old 05-15-2017, 02:46 PM   #26 (permalink)
Initially only for the Protos, however over time there may be an option to use it in some of the other JCD conversions.
It would NOT fit in the Freya without making several parts.
Carey Shurley
Old 05-15-2017, 03:48 PM   #27 (permalink)
Old 05-15-2017, 11:28 PM   #28 (permalink)
Rudy,
It's a new crankcase design with fan on top similar to a Nitro setup and closer to a PUH but with a fan that works!! Makes great power as compared to my newest TRM 300! The upper end is 300 based but many changes for the lighter crank etc.
doug
Old 05-16-2017, 03:56 AM   #29 (permalink)
Originally Posted by rbort View Post
Just a note the muffler/engine look low, maybe you want to make the landing gear taller to help with the balanced look and ground clearance?
Also Mike use an air filter, I realize maybe there isn't much room to the ground now but if you raise it up then should be OK. Never fly without a filter, the engine won't last.
-=>Raja.
I suggested adding mounting holes for Synergy skids a while back. That way you could either use the stock slanted MSH skids or the taller "flat" Synergy ones as you prefer.
Old 05-19-2017, 10:08 AM   #30 (permalink)
One of you has to have a completed build by now right?
Can we get a dirty pic
Whiplash Gasser l Goblin Gasser
in2deep is offline        Reply With Quote Quick reply to this message
Old 05-20-2017, 05:37 PM   #31 (permalink)
It is in the air! Can't wait to get the engine fully broken in and the FBL dialed in. Next is to log lots of flights for durability testing. It is very agile.
Protos prototype 700 Gasser (2 min 52 sec)
ID:	708264   Click image for larger version
Tom
TRM Power
CAUTION - my posts are based on my experiences, yours may be different.
fastflyer20 is offline        Reply With Quote Quick reply to this message
Old 05-20-2017, 05:46 PM   #32 (permalink)
Looks really good! What sort of weight is it coming in at now with everything on it?
HD Cell 750, RJX Vector, TDR, TDSF, Kasama Dune and Faifa, Minicopter Triabolo 700, Beam Avantgarde, JR E8 leggero, Suzi Laos, Shape 9, Shape S8, Rave 450, TRex 500, Raptor E700, Compass Warp, Steam 700, Spirit, Spartan, Jeti.
trillian is online now        Reply With Quote Quick reply to this message
Old 05-20-2017, 06:11 PM   #33 (permalink)
Compared to the RC format this motor is ~15.5oz lighter.
While the setup has a few flights on it now, there is still some work to do. We have identified some areas to pull more weight out of the setup, but it's all a little premature, as no one has started pushing the model to really test the cooling system.
So far, no show stoppers. I'm hoping to start breaking my motor in tomorrow.
XL Power 700v2 Nitro NME - OS 105HZR - Power Tune - Rail 716/106 - Brain2 HD
Sowa is offline        Reply With Quote Quick reply to this message
Old 05-20-2017, 08:57 PM   #34 (permalink)
You guys got it done just in time for the hot weather to really test out the cooling system. looks sweet guys.
joecass2 is offline        Reply With Quote Quick reply to this message
Old 05-20-2017, 10:12 PM   #35 (permalink)
Looks great
ChuckL is offline        Reply With Quote Quick reply to this message
Old 05-21-2017, 04:30 AM   #36 (permalink)
Looks great!!
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 05-21-2017, 09:52 AM   #37 (permalink)
Shaving a pound off the overall weight is pretty remarkable.
Old 05-23-2017, 11:02 PM   #38 (permalink)
Under the hood
ID:	708575   Click image for larger version
doug
Old 05-23-2017, 11:08 PM   #39 (permalink)
Default Engine Comparison
Here are a few photos with a conventional RC format engine out of one of my Goblins versus the new engine in the Protos that Mike and Joey developed.
A much more compact and lightweight version of the TRM 300.
ID:	708577   Click image for larger version
ID:	708578   Click image for larger version
doug
Old 05-24-2017, 12:04 AM   #40 (permalink)
Wow that heli is a lot more compact vertically than my T rex/Helibug conversion
combine that with the lighter weight and I bet it rolls and flies a lot better
I think I want on the waiting list for when it becomes available
banshee rider is offline        Reply With Quote Quick reply to this message
