Old 06-10-2008, 07:19 PM   #21 (permalink)
Team Taco VP
Originally Posted by gr8t1dini View Post
You forgot to mention, If you botch an auto and flick out of hold your limiter will go full bore to get the head speed up. Your gyro won't have time to react fast enough and that could make for a very interesting recovery.
This is true with ANY heli and coming out of hold in idle up! I always go into normal after I hit hold... So doesnt matter and this fact has nothing to do with a gov or limiter.
Warp speed that is a remote glow driver and is not related at all to the 7100R. The picture makes it look like it is but it is simply tie wrapped to the rev limiter wires.
I no longer have a DX7 so cant do a vid on it... Sorry ShinOBIWAN but it WONT be hard to figure out. Use GEAR channel and see my custom mix video for getting it tied to the condition switch. That is in my Trex600N videos with the Curtis ATG. Gyro will have to be on AUX2 and you will have to use travel adjust.
Bob
Old 06-10-2008, 07:23 PM   #22 (permalink)
Originally Posted by ShinOBIWAN View Post
Bob is there any chance you could do a quick video for setting the revlimit functionality on the DX7 radio?
I think that's what most people, including myself, will be using with this new receiver. I'm a bit of technical Luddite and would really appreciate any input you have.
MA has a good write up under radio tips for the DX7 on the site:
http://www.modelavionics.com/JR7202SpektrumDX7.asp
I am surprised more people do not use the rev max. It truly is simple and very effective. I set mine up on aux 2 and use the ATV to adjust.
Also: http://www.modelavionics.com/revmax.asp
http://www.modelavionics.com/revmax/...structions.doc
mlucia is offline        Reply With Quote Quick reply to this message
Old 06-10-2008, 08:05 PM   #23 (permalink)
Team Tostada Member
Ok, just got thru all 4 vids and once again you did an awesome job of making a complicated (to me) subject simple. Thanks Taco Meister! You really should get paid for these!
BTW, mlucia's links (thank you!) really do spell it out in simple terms so they'll come in handy for us DX7 users.
The name's Doug. I carry a gun 'cuz a cop is too heavy
warpspeed is offline        Reply With Quote Quick reply to this message
Old 06-10-2008, 08:16 PM   #24 (permalink)
Bob, just a thought and since no one has asked the question.
Will the AR7100R work on a gasser??? If the sensor can be set up to detect the crank that is...
Just another crappy day in Paradise.... Aloha!
CNCjunkie is offline        Reply With Quote Quick reply to this message
Old 06-10-2008, 08:26 PM   #25 (permalink)
Team Taco VP
My understanding but please I have not confirmed this yet..... is that a Model Avionics magnet sensor will also work with the AR7100... I am going to get a REAL answer to this at some point but this is what I have heard so if you cant use the crank sensor it appears you might be able to use a Revmax/TJPro sensor....
Bob
Old 06-10-2008, 09:29 PM   #26 (permalink)
Bob
Yes, I will wait for the official on that. If the Model Avionics sensor could function as the GV-1 sensor does when pointed at the flywheel on a gas engine, that would work for me, as I'm not a fan of drilling and glueing magnets to the fan hub.
On that note, I'm also wondering if the stator gator would provide the proper signal. Food for thought.
Thanks Bob.
Old 06-10-2008, 10:16 PM   #27 (permalink)
Bob
Sow does that mean that the crank sensor will work on like a multigov?
dxtarl is offline        Reply With Quote Quick reply to this message
Old 06-10-2008, 10:31 PM   #28 (permalink)
Smile Finless did a great Job on this AR7100R
Finless did a great Job on this AR7100R review.
I did read all of the four posts. My total understanding is limited. And I'll stick with Electric. But for those going up to Nitro, Bob did a great and detailed build video that should save hours for those guys who try to install a AR7100R with a JR X9303.
Keep up the good work.. !
Cheers VietVet -
VietVet is offline        Reply With Quote Quick reply to this message
Old 06-10-2008, 11:03 PM   #29 (permalink)
Should...trying it out tomorrow.
Representing:
AMain Hobbies, XNova Motors
Jason Bell is offline        Reply With Quote Quick reply to this message
Old 06-11-2008, 12:43 AM   #30 (permalink)
My Multigov sensor in my 600 is lighting the sensor light in my AR7100R when I rotate the fan. I am not sure if that means it will work since I haven't tried it, but on the bench it looks like the 7100 is reading the Mutligov sensor.
More helis than brains
Funky is offline        Reply With Quote Quick reply to this message
Old 06-11-2008, 01:59 AM   #31 (permalink)
Should work the other way around then. Confirming this tomorrow.
Funky-are you going to try the limiter or use your MG? If you use your MG let me know how you did it.
Representing:
Old 06-11-2008, 02:24 AM   #32 (permalink)
The sensor that came with the 7100R doesn't fit too good on the Redline in my 600N. I'll need to get some spacers/washers to go between the sensor mount and the motor or it won't fit. For tomorrow, I am going to try to use the built in limiter with my multigov sensor that is already mounted. Ill bring my Multigov too in case I can't get the limiter to work so I can try to bypass it. I don't know if I'll be able to use the bottom plate sensor at all unless I pick up some washers.
I am running a Multigov in my Stratus with a 7100 but it doesn't have the built in Rev limiter and it is just using a standard Multigov sensor. I'll be trying that setup tomorrow too.
Old 06-11-2008, 02:43 AM   #33 (permalink)
Based on this quick test, it looks like the Multigov will work with the backplate sensor
Old 06-11-2008, 09:15 AM   #34 (permalink)
Default Sensor will work!
Yup Mine worked to, on the Multigov Pro as well.....everything is kosher!
That also means it will work on a Revmax, TJ, and ATG as well .
Representing:
Old 06-11-2008, 10:32 AM   #35 (permalink)
Team Taco VP
Cool guys! Good detective work!
Bob
Old 06-11-2008, 11:32 AM   #36 (permalink)
Do I see a run on Spektrum backplate sensors on the horizon? I'm assuming they'll be selling replacement sensors. It's sure a lot more protected from damage than the fan sensors.
HeliFreak Support
Graupner MZ-32
Old 06-11-2008, 04:57 PM   #37 (permalink)
FYI - Just got back from Gyro Hobbies in Lake Forest, they have a few in stock
JodyJ is offline        Reply With Quote Quick reply to this message
Old 06-12-2008, 12:06 AM   #38 (permalink)
The Capi
Nice vids Bob ! Now that i've decided to go nitro i can't get enough info.
P.S. On the 9303 if your adjusting a value and you want its default value just hit the CLR button.
Old 06-12-2008, 01:14 PM   #39 (permalink)
Oh boy...I've got lots more ready to do and questions to ask.
Does this mean that magnets are no longer needed if I have the Multigov (V1) and just buy the Spekrum sensor?
tukkus is offline        Reply With Quote Quick reply to this message
Old 06-13-2008, 12:15 AM   #40 (permalink)
Using the backplate sensor, as I spin the crankshaft by hand slowly, the sensor light on the receiver flashes twice as the rod goes by. I assume its sensing one side of the standoff on the crank for the rod, then the hollow in the middle of the standoff and then the other side. Is this what others are seeing? I would guess that when the engine is running at speed it goes by quickly enough it only registers once each revolution?
creightoncarr is offline        Reply With Quote Quick reply to this message
