Old 06-13-2008, 12:17 AM   #41 (permalink)
The Capi
Time is relative, what seems very quick to us is a lifetime to a microcontroller.
Old 06-13-2008, 04:41 AM   #42 (permalink)
Team Taco VP
Originally Posted by creightoncarr View Post
Using the backplate sensor, as I spin the crankshaft by hand slowly, the sensor light on the receiver flashes twice as the rod goes by. I assume its sensing one side of the standoff on the crank for the rod, then the hollow in the middle of the standoff and then the other side. Is this what others are seeing? I would guess that when the engine is running at speed it goes by quickly enough it only registers once each revolution?
Turning the unit by hand sometimes you will see an anomaly like this. In fact I have seen the light stay ON and turn off when the crank goes buy. I especially noticed this when first powering up and turning the motor the opposite way! Take a few minutes to rotate the motor a few extra times and this weirdness will go away AND make sure to turn the motor the right diection.
Bob
Old 06-13-2008, 08:57 AM   #43 (permalink)
do you guys know if the backplate sensor will work with the align G600 gov, if so that would be sweet, its my first nitro build and I don't want to fuss about with magnets.
600N 8917HV's spartan 760/8900G OS 55HZ/hatori SAB-55 AR7100r switchglow
700N 8717HV's spartan 760/8900G OS 91HZ/hatori SB-20 AR7100r switchglow, 690 slick V2 V's
90SG 8717HVs spartan 760/8900G OS 91HZ/hatori SB-20 AR7100r switchglow, 710 slick V2 V's
LoveMyTrex is offline        Reply With Quote Quick reply to this message
Old 06-13-2008, 12:55 PM   #44 (permalink)
Anyone tried to power the reciever with 6V from regulator ?
Does the 5.2V regulator for the tail works ?
I would like to power the AR7100R unit from a 6V regulator and use the 5.2V regulator built in for tha tail.
I afraid it will be too limited.
~Roei~
TooLy is offline        Reply With Quote Quick reply to this message
Old 06-13-2008, 01:00 PM   #45 (permalink)
Team Taco VP
Here is what the manual says for power requirements.
IMPORTANT: Do not use a 4-cell 4.8-volt battery to power
the AR7100/AR7100R. Because of the built-in regulator the
AR7100/AR7100R has a minimum recommended operational battery
voltage of 5.5 volts and is designed to use 6-volt 5-cell NiMH,
7.2-volts 7-cell NiMH or 7.4-volt 2-cell LiPo batteries. (Higher
voltage should be used only if the servos are compatible.) While
the AR7100 will continue to operate down to 3.5 volts, the AR7100/
AR7100R features a built-in 5.2-volt regulator for the Rudder, Aux
2, Gear 2, Throttle 2 channels output. A 4-cell 4.8-volt battery will
not provide sufficient head room (voltage margin) to maintain a 5.2
regulated voltage. Regulated outputs are provided to allow the gyro,
gyro gain and throttle to be operated at the necessary lower voltage
while the cyclic servos (aileron, elevator and pitch) are powered
directly by the pack voltage (typically 5-cell 6-volt NiMH or if high
voltage compatible servos are used 2-cell 7.4-volt LiPo batteries).
So yes a 6 volt regulator can be used in front of the RX hooked to the LIPO. Just make sure it is a REGULATED 6V as if it can drop below 5.5 volts it could be a problem.
Bob
Old 06-13-2008, 01:09 PM   #46 (permalink)
Good to hear that.
I just found that info from their VR-3 regulator.
Thanks Bob.
~Roei~
Old 06-13-2008, 03:52 PM   #47 (permalink)
you might want to use this badass looking reg from spektrum
http://www.spektrumrc.com/Products/D...odID=SPMVR6010
Old 06-13-2008, 07:08 PM   #48 (permalink)
Team Taco VP
Naaa... that is totally over kill for a heli! It's made for giant scale stuff tha runs WAY more servos than we use...
Bob
Old 06-13-2008, 07:13 PM   #49 (permalink)
But it looks soo cool!
I would run one in mine!
Representing:
AMain Hobbies, XNova Motors
Jason Bell is offline        Reply With Quote Quick reply to this message
Old 06-13-2008, 07:26 PM   #50 (permalink)
Team Tostada Member
Wait a minute... are you saying we're going to have to run nimh rx packs? A 2s pack is too much for oh, say a 9452 someone may be planning to run in his oh, say Freya.
Not that it's a big deal to me, but I'm kinda used to my little foil covered fire bombs.
The name's Doug. I carry a gun 'cuz a cop is too heavy
warpspeed is offline        Reply With Quote Quick reply to this message
Old 06-13-2008, 07:30 PM   #51 (permalink)
Team Taco VP
Huh? Nimh? Where did I say that? I guess you didnt watch the video?
Jason... that thing is BIG with a fan... You sure you would want to run that extra weight on a heli?
Bob
Old 06-13-2008, 07:35 PM   #52 (permalink)
Team Tostada Member
Bob
Right there, in the above quote! Unless you're using the high voltage JR's, most servos are only rated for 6v. (Or 5.8 or whatever) If the 7100r passes rx voltage right thru, aren't you then running your servos at 7.4? (If using 2s lipo)
And OF COURSE I watched the vids Bob! I get Finless withdrawals if I don't get to see that grinning mug of yours every now and then!
Old 06-13-2008, 07:35 PM   #53 (permalink)
Bob
Its not that big....But come on, you know the fan is super cool! (pun intended)
Representing:
Old 06-13-2008, 07:42 PM   #54 (permalink)
I don't think it weights too much more than a fremco arizona 10A reg, plus it will run cooler, and look cooler, and it has the proper connections presoldered on.
warpspeed, if you only want 6v to go to your servos you can run a reg like that big spektrum one between the lipo and the RX
and do you guys know if you can use the backlate sensor with the align G600 gov?
Old 06-14-2008, 07:24 AM   #55 (permalink)
I read it will work
~Roei~
Old 06-14-2008, 08:27 AM   #56 (permalink)
Gyro will have to be on AUX2 and you will have to use travel adjust.
Bob
If I remember correct from my DX7, you can use the AUX2 for the gyro with the gyro sense menu, you just have to select it in the input select, choose "GYRO" under AUX2.
~Roei~
Old 06-14-2008, 09:22 AM   #57 (permalink)
Team Taco VP
Yep... my mistake! But I prefer end points anyway as the gyro menu requires some math to get real gain....
Bob
Old 06-14-2008, 06:26 PM   #58 (permalink)
Smile
dam you bob,you just keep costin me more money,thanks for the great info just ordered 2
JR NUT is offline        Reply With Quote Quick reply to this message
Old 06-15-2008, 05:43 PM   #59 (permalink)
Default servo's, spektrum ar7100
so can anyone actually tell me which servo's we can and can't use, what about futaba 9451's iv'e loads of these and there rated at 6v just like the jr 8717 shown in the vids, by the way i'm talking cyclic servos here, any help appreciated
david.
slinky is offline        Reply With Quote Quick reply to this message
Old 06-15-2008, 07:10 PM   #60 (permalink)
Hey Bob,
The supplied switch that comes with the AR7100/R. Is there anything special about it?
On my 600N I used a Pin Flag Switch and it works great, but I was reading the manual for the hell of it and it says the following:
Note: The AR7100/AR7100R uses a
specifically designed switch. Conventionally wired switches are not
compatible with the AR7100.
Thanks,
Jody J.
JodyJ is offline        Reply With Quote Quick reply to this message
