Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Compass 7HV, 7HVU and Chronos
Compass 7HV, 7HVU and Chronos Compass Compass 7HV, 7HVU and Chronos Model Helicopter Discussion
Old 07-03-2017, 12:30 AM   #1 (permalink)
Default New Chronos Build electrics advice?
Looking for advice on electrics setup for Chronos build.
I am keeping an eye on the F/S section, but if I decide to go new, I am thinking of the ProTek Servos,.. https://www.amainhobbies.com/protek-...WQXhoCBhfw_wcB , as I absolutely loved the one I had in my SCT back in the racing days.
This will be my first 700,.. so I am looking for advice on using ESC BEC,..(why do they make them, if they are not good to use?) , external BEC,. or is a seperate battery the best option? I am running a CC BEC Pro on my 570, and that seems to work well.
Going to go with an Ikon 2, as I have 3 others, and I am very familiar w the system, and flight characteristics.
Looking like 5000mah Pulse 12s will be my choice for packs.
ESC is still up in the air as well,.. Thinking 160a or 200a,.. as I've already got the motor, which calls for a 200a peak(3 secs) RAGE SZ4928 - 505KV
I will be running Futaba S-Bus RX (T-FHSS)
Any other thoughts and or advice is welcome, Thank you for any infos!!!!
- VultAge -
450Pro, 470LT, G420, G570, Chronos, T-Rex 700n
vultage is offline        Reply With Quote Quick reply to this message
Old 07-03-2017, 01:07 AM   #2 (permalink)
Can't speak for servos, many are good.
For 12s,14s 700 esc bec is good IMO and plenty are good. Tribunus 200, Hw 130 and 160, Kontronik, maybe more. CC bec pro I have 0 experience with.
I did the rx pack thing, eventually it becomes a pain to keep up in my opinion and I will not be going that route again unless it's with gas or nitro.
Protos Max Leggero 700, Logo 600SE, Logo 550sx, Trex 250, Blade 230s
DX9
flint723 is online now        Reply With Quote Quick reply to this message
Old 07-03-2017, 05:19 AM   #3 (permalink)
I'm running the mttec keto bec, superb holding power and allows you to run 2s bec along side of it. Nice safeguard solution!
Sent from my HTC 2PZC100 using Tapatalk
Lighty is offline        Reply With Quote Quick reply to this message
Old 07-03-2017, 05:28 AM   #4 (permalink)
Do you run that to one side of 12s(6s) or the full 12s?
how do you set it up with a 2s bec along side of it? Looking it up doesn't say anything about that.
- VultAge -
Old 07-03-2017, 05:46 AM   #5 (permalink)
Follow this link to see what I have in mine.
https://www.helifreak.com/showthread.php?t=739362
I run my regulator off one side of the battery. It works great.
Scott
Team Rage-RC USA--Team Pilot
KBDD Team Pilot ):>
Old 07-03-2017, 10:16 AM   #6 (permalink)
Thanks Scott! I been reading through your build thread, what an awesome job you have done!
- VultAge -
Old 07-03-2017, 10:28 AM   #7 (permalink)
You're very welcome, and thank you! Don't hesitate to ask any questions!
Scott
KBDD Team Pilot ):>
Old 07-03-2017, 11:50 AM   #8 (permalink)
I am going with the HW 160a V4 ESC,.. which has a built in BEC. I've always heard that is a good idea to stay away from built in BECs, on large models. I am curious, if that is not the case anymore? The HW "Super BEC" has the same specs as most external BECs,..
Thoughts on using the HW BEC w HV servos? What would my options be for redundancy?
- VultAge -
Old 07-03-2017, 11:53 AM   #9 (permalink)
I am using the Hobbywing 130 with internal bec for the Rage motor. I also have a backup guard on the way though. I am flying it harder, and the esc with the fan on it never gets hot surprisingly. The build thread is incredibly helpful to have out for a reference when building. Enjoy the Chronos, it flies amazing!
Team Synergy
Dylan Hudock is offline        Reply With Quote Quick reply to this message
Old 07-04-2017, 02:25 AM   #10 (permalink)
I use a Hobbywing 160A and an Optiguard. Works well.
Sent from my SM-G920I using Tapatalk
allen james is offline        Reply With Quote Quick reply to this message
Old 07-04-2017, 05:19 AM   #11 (permalink)
I run my bec on 6s but will do 12s. The 2s 450gens ace I run with a switch and plug it in to a spare port which is my Futaba sbus ex. Plug in you main packs first the switch the 2s on. Once you land power off the 2s and then your packs.
Old 07-04-2017, 02:34 PM   #12 (permalink)
So you can have 2 power sources going to the Radio system? I was always wondering about that. Do they have to be the exact same voltage? ie: BEC needs to be set for same voltage as 2s pack, ect?
- VultAge -
Old 07-04-2017, 03:42 PM   #13 (permalink)
I have JR servos on both of my Chronos.
I think the first Chronos has a Talon 120 on it (been quite a while since I installed it).
The second one has an O.S. 800 size motor and a HobbyWing 200 Amp. ESC. This one is three-bladed and using KBDD 690's.
Western Robotics BEC's are excellent products. The BEC's on both of my Chronos' are Western Robotics Hercules Super BEC Pro's (bus technology) delivering 16 amps continuous and capable of 22 amp peaks. As this BEC uses a power bus, there is no current bottleneck with only one or two servo type connectors delivering power to the on-board electronics. The BEC's are running from one of the two, 6S packs on each machine.
As far as BEC voltage goes, it needs to be set for whatever your servos are rated at.
KBDD-Team Captain/Compass Team Manager/Experience R/C/ Western Robotics Field Representative
Old 07-04-2017, 08:21 PM   #14 (permalink)
I was refering to when you are using 2 power sources.
That BEC looks awesome! Going to look into that!
- VultAge -
Old 07-05-2017, 01:53 PM   #15 (permalink)
"I was refering to when you are using 2 power sources."
In general, you would not run a BEC from two power sources. Nor do you run two BEC's in parallel.
I also run this monster on just the Western Robotics Hercules Super BEC Pro:
"That BEC looks awesome! Going to look into that!"
OUTSTANDING!
Old 07-05-2017, 02:14 PM   #16 (permalink)
Yeah, we were discussing redundancy,. ie: Optigaurd,.. 2s pack+ BEC combo,.. (above),.. as I didn't think that you could have 2 power sources.
so,. I'm guessing, that these devices have a Capacitor,. or something to keep from backfeeding power?
- VultAge -
Old 07-05-2017, 07:52 PM   #17 (permalink)
According to Western Robotics (and I have asked them directly) you should not install any device that will apply voltage to the output side of their BEC's, as it may damage or shorten the life of the BEC. This includes Optiguards and other backup devices.
I have never used any backup device with a WR BEC (and I have about 17 of them in service right now-some of which have been in use for years).
Old 07-13-2017, 10:05 AM   #18 (permalink)
Default Motor Wires
Anyone else running a Rage Motor,. and or HW Platnum ESC on their Chronos?
I am trying to decide how I want to run the motor wires. The motor and ESC are so close together,.(1") Not sure If I want to cut the ESC and motor wires to an 1.5" or so,.. and make an S, or try to wrap them down under the ESC mount,.. Wish they all had mounting screws like Kony,..
Too many desicions! haha
- VultAge -
Old 07-13-2017, 11:03 AM   #19 (permalink)
I just curled mine over the ESC and used a tie wrap/velcro.
Scott
KBDD Team Pilot ):>
Old 07-17-2017, 10:18 AM   #20 (permalink)
I am running that setup. I folded them and have them secured next to the esc. Not the prettiest, but it is super easy to unplug a them if needed for maintenance, etc.
Team Synergy
Human Verification
