Align 150x bluetooth not found - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > 150 Class Electric Helicopters
150 Class Electric Helicopters 150 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Like Tree1Likes
  • 1 Post By LogafHeli
Old 07-11-2017, 02:30 PM   #1 (permalink)
Default Align 150x bluetooth not found
Hi,
i just godt my Align 150x, and at first everything was smooth. I tried to do a firmware update and initial settings. firmware update went ok, and after i did a stick calibration i must have enabled a function as i entered some setup where you use the controller and throttle stick to say yes/no after beeps. i did not understand that i was in this settings after a while as i tried to throttle up to fly so i probably changed a lot of settings to what they should not be. and now after this, i cannot connect to the bluetooth. My phone just does not find the unit and therefor cannot connect. i have tried to install the app on my ipad, but there is an issue downloading it, it just tries to download and nothing happens. I have uninstalled the app from my phone(android) and reistalled it, restarted my phone, turned bluetooth on and off. Nothing seams to do the trick...
does anybody have some tips? Thank you in advance!
Align T-rex 150x
Align/Futaba T6
Stefan Bahrawy
JR XG8 - Align T-Rex 450L Dominator
First Heli has never flown... Still buying parts!
fesan is offline        Reply With Quote Quick reply to this message
Old 07-11-2017, 02:56 PM   #2 (permalink)
You tried everything I would suggest. I haven't heard anything about the stick movement and beeps thing. Sorry I can't help.
jazsop is offline        Reply With Quote Quick reply to this message
Old 07-12-2017, 09:59 AM   #3 (permalink)
My guess is that maybe you came across some sort of hidden configuration menu. I've heard nothing about this kind of configuration in 150X, but if I'm not wrong, the ESC firmware is based on MSHeli. My guess is that maybe accidentally you have entered a ESC configuration mode. I'm not clear if your GRS arms when you plug the battery and or not. You don't ear the tones indicating that the system is ready to fly, do you?
I don't know about MSHeli, but perhaps you may want to perform some searches on the web about MSHeli firmware configuration from the transmitter. Maybe you can find something useful. Otherwise, I'm afraid that your only choice would be contacting your local Align dealer.
Good luck!
ALZRC TRex 450 Pro DFC
ALIGN TRex 500 ESP DFC
ALIGN TRex 600E PRO DFC (Power booster)
Goblin 500
joanpeca is offline        Reply With Quote Quick reply to this message
Old 07-12-2017, 10:32 AM   #4 (permalink)
i came across this video that explains the kind of configuration as i mentioned.
Align TRex 150 DFC RC Helicopter- Programming Using Setup Mode (3 min 38 sec)
The chopper flies now as i managed to configure my controller, but i would like to be able to adjust the configuration as the chopper is quite aggressive compared to my flight knowledge and experience
the app will not download to my ipad, so i have some difficulties to try the app from a different phone/tablet. but in general the bluetooth works fine on my phone, i have a watch connected that syncs quite fine.
iŽll do some searching on the MSHeli. Thank you for the tip!
Could it be that the bluetooth just stopped working? e.g. a fault?
Stefan Bahrawy
Old 07-12-2017, 10:48 AM   #5 (permalink)
Didn't know that way of configuration was possible. In fact, did you notice that the video title reads "150 DFC RC Helicopter...". This is the old model, which uses a different FBL system. I don't have my 150X to make a check, but at least my manual doesn't say anything about this setup procedure.
And yes, unfortunately, it could also be that your GRS board, which embeds a Bluetooth controller, have given up working. That's why I said that as a last resource perhaps you would need to contact your local Align distributor.
Goblin 500
Old 07-12-2017, 12:58 PM   #6 (permalink)
Yes, i noticed the video mentioned this was a DFC, but i saw this video before this happened, and when i tried to fly it gave the same confirmation sounds etc.
contacted my local Align dealer, so ill hear what they say.
i had a flight, and chipped a huge piece of wood of my living room table, so now i need to re-calibrate, as it seams like the swash plate no longer are leveled. Still flies ok though
Stefan Bahrawy
Old 08-11-2017, 12:24 PM   #7 (permalink)
Question Interested if anyone has solved blootooth problem
I lost bluetooth connection with my 150X, I think when I was calibrating the trottle in the app and restarting after that.
Tried emailing the manufacturer but only got instructions on how to connect to bluetooth connection from the app when all is working well.
Seems like the heli is stuck in some calibration and has turned the bluetooth off.
Anybody know how to recover or reset the heli to factory default ???
DIX2014 likes this.
LogafHeli is offline        Reply With Quote Quick reply to this message
Old 09-10-2017, 02:12 AM   #8 (permalink)
Exclamation 150X Lost Bluetooth connection
I just bought the latest version of 150 x (wide body). Have only flown 4 four test flights with it and now it has suddenly lost the Bluetooth connection. Means no possibility for adjustment via. app. But I can still get in touch with the via Align T6 transmitter. I'll try to contact Align for help.
DIX2014 is offline        Reply With Quote Quick reply to this message
Old 09-10-2017, 02:25 AM   #9 (permalink)
Exclamation Align 150x bluetooth not found
I just bought the latest version of 150 x (wide body). Have only flown 4 four test flights with it and now it has suddenly lost the Bluetooth connection. Means no possibility for adjustment via. app. But I can still get in touch with the via Align T6 transmitter. I'll try to contact Align.
Old 11-06-2017, 06:07 PM   #10 (permalink)
Anyone get a resolution on this. My bluetooth won't connect though everything else works just fine. Flys fine except that it's pretty much impossible to get level swash without the app. Not excited about having to buy a new board for the bluetooth only.
-Tom
XK K110(s), Align 150X, Align 500XT, Align 550E/DFC, Goblin 280, Goblin 500 Sport, Leviathan Goblin 700 TRM gasser --- FrSky/OpenTX controlled.
Oh, and GO HOGS!
tvoth3 is online now        Reply With Quote Quick reply to this message
Old 11-24-2017, 10:56 PM   #11 (permalink)
I suddenly can connect to blue tooth but when I go to settings it never loads then I lose blue tooth connection...and the app crashes
I uninstalled the app and reloaded it...same thing
anyone find a solution to getting things back to working order with blue tooth?
what can I say....I'm "that guy"
Voted by my Club as: "Most Likely To Crash"
PTFlyer is online now        Reply With Quote Quick reply to this message
Old 11-24-2017, 11:44 PM   #12 (permalink)
try the app on another phone, put a fresh battery in the heli, place phone 2 feet away from heli and give it about 40 seconds then try to bind with the Bluetooth in the app. is the phone bluetooth picking it up?
T-Rex 150x //DEVO 10//SFHSS/DSMX/FrSky
OXY 2 FE 210-BA-8-1,H0988UH, 250MX HW 25a
470LP HW 60A v4, 3xGlaciers 1.8
Danker16 is offline        Reply With Quote Quick reply to this message
Old 11-25-2017, 12:49 AM   #13 (permalink)
yes it sees it and loads it as I see the heli's software version.
It's when I go to the setup it locks up and the heli loses the blue tooth connection and the app locks up.
I tried reloading the app and then running it in demo mode and the app locks up,
So there must be a problem with the app on my phone..
I will try it tomorrow on a different phone as I can't even find the app when I look for it on my ipad..
Old 11-29-2017, 08:43 PM   #14 (permalink)
ok...well this is very strange...
I fired up the app and linked up with the heli and everything worked fine...
I am able to make changes and everything...
I didn't nothing except wait a few days and tried again...
The app even ran in "off line" mode which it wouldn't even do before...
the moral of this story I guess is , if it doesn't connect today...wait til tomorrow
...huh?
Old 12-21-2017, 07:28 PM   #15 (permalink)
-Tom
Just wanted to follow-up on this. Contacted Enterprise Hobby and they replaced the board for me gratis. Awesome customer service IMHO.
Tom
Oh, and GO HOGS!
Human Verification
