Go Back   HeliFreak > R/C Electronics Support > Scorpion ESC and Motor Support
Scorpion ESC and Motor Support Scorpion Power Systems ESC and Motor Factory Support Forum
Like Tree18Likes
Old 09-05-2017, 02:44 PM   #21 (permalink)
For those thinking of the 200 be careful depending on what you need because the only version available is "opto" so no BEC.
The 160 and 130 have a BEC
TDR-IIto build, Triabolo, 2 X TDR, Kasama Srimok,90e FAIFA, T-Rex 700Dominator, Goblin700, Axon Spirit, Jeti DC-24, Mezon,HW,Kosmik
[B]Extreme Flight MXS 3W110, Ultimate Aeroworks 20-300, DA 170, CB200, Cortex, Q80-8M in a 91" EF Extra ++
Old 09-05-2017, 03:26 PM   #22 (permalink)
on HW but the tribunus comes with BEC and I'm assuming even the 130A when it comes out it will be with the BEC
| Atom 6HV : Spirit pro | Goblin 700 : Brain2HD | HD Cell 500 : brain2 |
ragge1 is offline        Reply With Quote Quick reply to this message
Old 09-07-2017, 02:02 PM   #23 (permalink)
Originally Posted by PJing View Post
I need a new ESC to finish my Compass Chronos build... do you think the 130A will be enough or is it better to invest in a 200A ... with a Scorpion 4525-520 Ultimate (first generation) ? Anybody has an idea of the price difference ? Thanks
I would just use the 200 amp esc on a 700. It is light and compact and then no need to worry. I have one on my Synergy E7SE with the Scorpion 4525-520 motor. Works great. No regrets.
PJing and newbheliusr like this.
Synergy 766, E7SE, E5SS, E5S, 516, V Control, Neo, Tribunus
Freeskiken is offline        Reply With Quote Quick reply to this message
Old 09-07-2017, 02:53 PM   #24 (permalink)
Yea, I was really close to doing that myself but decided to wait and see the specs on the 130.
I'm a low head speed guy and want to keep the machine as light as possible, pretty sure a 130 would be fine?
PJing likes this.
Futaba 14SG / Synergy E6 / CGY750
f8fbc is offline        Reply With Quote Quick reply to this message
Old 10-08-2017, 10:02 PM   #25 (permalink)
Any news on this bad boy? Much need...
Freeskiken and Airagitator like this.
Protos 380: Hyperion G7HV, HobbyWing 60, Xnova, KST & MKS, Switch & RotorTech
Goblin 570: 12s Revo 40c HV, Tribunus 130, Scorpion 4025, KST minis, SAB TB's
Thunder T: 14s Hyperion G7HV, Tribunus 200, Xnova L 4530, Vbar Neo, MKS, 717 VTX
Martinshelis is offline        Reply With Quote Quick reply to this message
Old 10-15-2017, 04:21 PM   #26 (permalink)
2 weeks for you can order according Facebook
Sent from my AOSP on Manta using Tapatalk
Martinshelis and Freeskiken like this.
MrEmail is offline        Reply With Quote Quick reply to this message
Old 12-11-2017, 10:32 AM   #27 (permalink)
which retailers have these in stock?
i looked at helidirect and amain but neither one has them.
BrunkBird is offline        Reply With Quote Quick reply to this message
Old 12-11-2017, 09:44 PM   #28 (permalink)
Scorpion if want it right away. They ship right to you.
https://www.scorpionsystem.com/catal...tribunus_sbec/
Old 12-11-2017, 09:49 PM   #29 (permalink)
I see you are in Canada. Try Rotorquest.
https://www.rotorquest.com/categorie...-130A-ESC-SBEC
I am not in a hurry...I ordered mine through "The Heli Hanger & Hobby" Paul is going to get me one.
https://www.thehelihangar.ca/
Old 12-12-2017, 02:29 PM   #30 (permalink)
got mine last thursday but not tested it yet , hope to try it on sonday
ID:	731333   Click image for larger version
Old 12-12-2017, 08:23 PM   #31 (permalink)
I won a gift certificate from Scorpion at my last FF, and decided to pull the plug on the 130, and ordered it from Scorpion Power Systems on Friday. It arrived from China on Monday @ 10:30 am. Can't get much better service than that.
Now I have to just get it set up.
Edit: Just finished doing the setup with my VBC and NEO. It was a breeze. Just selected Logo 690 setup with Vbar gov and Tribunus ESC and all the data was there. All in all, it was as easy as anything I have ever done. Oh, I did have to reverse the motor direction and set the BEC voltage, but that was all.
Specter 700, Logo 700, Logo 690SX, Goblin 700, Trex 700DFC, Gaui X7, Trex600EFL Pro, Trex 600 ESP, Trex 500 ESP, DJI 550
Amain Team
Rep
rcflyerheli is offline        Reply With Quote Quick reply to this message
Old 12-12-2017, 10:11 PM   #32 (permalink)
I donít have mine yet. But it looks like the capacitors can move around a bit like the 200. If so I would put some hot glue or I use shoe goo to secure them a little better. Keeps them from vibrating or shock if you have a hard or extremely hard landing.
Old 12-12-2017, 10:24 PM   #33 (permalink)
One thing I noticed on mine. Where the BEC and telemetry plugs go, all of the other units I own or have set up have the plug orientations, master/slave diagrams printed on the end of the esc just under the caps, but this one doesn't.
Are all the 130s like that?
Never mind, I found it. It's on the bottom of the case.
Amain Team
Rep
Old 12-13-2017, 02:05 PM   #34 (permalink)
thanks , will take a look , but wondering will this affect the cooling of the capacitors
Old 01-10-2018, 10:28 PM   #35 (permalink)
Anyone with the new 130 running futaba and telemetry? ( I guess the 200 as well)..
Is there any chance an option is rpm? Or mah capacity used that feeds back to the 14sg?
Steve
smittylube is offline        Reply With Quote Quick reply to this message
Old 01-11-2018, 12:00 AM   #36 (permalink)
We finally got some decent flying weather and was able to test the 12-130. It worked as it should. No issues at all. It was 60 degrees, and the 690SX and VTX 697s only pulled a max of 105 amps and I didn't see a temp higher than 90.
I like it.
Freeskiken likes this.
Amain Team
Rep
Old 01-29-2018, 01:29 PM   #37 (permalink)
I got a Tribunus 130 for my Banshee to run a small Rage 4129 Motor (Exo 500 Motor). It is rewound to 560kV to work with 12S. It was a tough decision between 130/200A, but because of the small, not so powerful motor I went with 130 - smaller, lighter, cheaper. With a standard 700 class motors I would better take the 200A. If you are interested more about the setup, I created a separate thread here.
After trimming the cables, Tribunus 130 comes at 163g only, here I'm saving around 100g in comparison to Kosmik.
I use internal Tribunus Governor, didn't change a thing, all at default values, and it runs very well. Telemetry with VBC is nice.
I got one of the first Tribunus 120A when they came out, and even when it works, it gets very hot, sometimes I reach limit 120įC in my synergy 516. So I was a bit pessimistic about the Tribunus initially. But here it works very well and I'm very happy with the current setup. Max temperature around 65įC, current peaks according to VBC at 154A.
I would wish I can change the timing, because the motor gets quite hot. This is very unfortunate that Tribunus doesn't allow us to change any settings.
Martinshelis likes this.
benko is offline        Reply With Quote Quick reply to this message
Old 02-12-2018, 01:32 PM   #38 (permalink)
Just ordered a 12s 130 for my 600 night ship.
Heli's I have:
Goblin 500 (Vbar Neo), Gaui X5(Vbar Neo), X7(Vbar Neo), Innova 600 Night heli (Vbar Neo Vbar Vcontrol
I'm the not so newbheliusr as I have been here a while. But I like this name.
newbheliusr is offline        Reply With Quote Quick reply to this message
Human Verification
