Evolution Rush 750 V2 stretch to 800 - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > 800 Class Helicopters
800 Class Helicopters 800 Class Helicopters
Old 07-21-2017, 12:40 AM   #1 (permalink)
Default Evolution Rush 750 V2 stretch to 800
Hey guys, couple of questions.
I have 2 Evolution Rush 750 airframes and I want to turn 1 into an air beating 800.
So I have found out the align 700 main gear bolts straight on, so that’s sorted, a lot of comments that the rush gear is soft. Soo possibly going to go KDE for this. I’ll be running a Kontronic Comp 800-48. Not over the top but plenty of power.
The downside to that motor is, it has an 8mm shaft… Evolution don’t make an 8mm pinion and the stock one is alloy. If I machine it out the spigot for the bearing is super thin. So was looking at the align 700X 13T pinion, does anyone know if this is 8 or 6mm? I could just change the bearing for the new spigot size on the align pinion. Plus its steel.
Now I’ve seen a couple of threads on stretching to 800. Apparently the align 700 upgrade boom fits and the trekker does not. Confirmed this is true. Is it a simple bolt in with the rush tail box? Can only find the 700 stretch boom in kit form with TT and struts (H80001), cannot find just the boom by itself (crash kit).
Or is there a rush boom to stretch the 750 to 800. I have heaps of 750 booms, but I will use them for the second air frame.
I think that’s it for now…
Goblin 650 BT | Goblin 380 | Rush 750 V2 Stretch | Goblin 500 V1
Vcontrol
Citizen 709
higham83 is offline        Reply With Quote Quick reply to this message
Old 07-29-2017, 01:16 AM   #2 (permalink)
I used to run a Suzi Hans custom frame with align mechanics for years as a stretched 800. Using the align main gear and stretch boom etc... the only thing I can say is I stripped MANY main gears! I tried everything I could get my hands on including KDE main gears... I could go through 5-6 in a Funfly weekend... perhaps it's just my flying style and collective management skills, but just keep that in mind if running align drivetrain.
MD8, MD7.5, MD7, MD6, MD5.5, Gaui NX4Gasser
Hot Apple Pie Guy is offline        Reply With Quote Quick reply to this message
Old 07-30-2017, 09:24 PM   #3 (permalink)
I have run the Align and Rush main gears on my 766 and 780mm Rush helis with zero issues. A friend with a big power KDE motor killed a stock gear but once we set it up with zero backlash on the high spot it has been flawless. Keep your backlash to a minimum but do not run the mesh tight , just absolute minimum back lash. This goes for most gears and high power or load. Have seen guys with the KDE gear and I am not really sure if it is any better than the newer Align and then there is the latest wider contact Align gear.The Align 800 kits seem to survive fine and it is the same gears! I do run Align steel pinions on my Rush as does my friend. The Evolution (Rush) stretch kit has been on back order for along time so the Align kit would be your only option presently. There is a Evolution forum on Heli Freak also.
Team Renegade R/C Heli Flyers
Old 08-11-2017, 05:30 PM   #4 (permalink)
Thanks for the input guys, I will probably use the align stretch kit boom and the new wider fatter gears.
Vcontrol
Citizen 709
Old 12-12-2017, 07:04 PM   #5 (permalink)
An Align boom is tight in the tail unit and boom holder on the Rush but it will fit. The Align boom is 885mm and Rush boom is 904mm so you might be limited to 780mm blades as with a stretched Trex 700E.
Tags
800, rush, stretch
Human Verification
