was thinking of pulling the trigger on one of these - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > eXo
Old 07-26-2017, 12:54 AM   #1 (permalink)
Default was thinking of pulling the trigger on one of these
contemplating adding one of these to the fleet, mainly due to the fact I have a motor, ESC, battens, and FBL controller. The kit ,blades, and servos are needed at checkout. I'm new to this site per say but have been around on others and have noticed not too much on this heli and a lot of gripes. I think this is a very good looking heli and have a curiosity on rigid heads and a wife not willing to approve a Hen. In your option is this heli something I could fly without a lot of non pilot induced issues. Just a little backround on me been RC for 35+ years mainlky planks but have fooled with helis for many years, the past 13 years helis have been more in the picture due to the 3 square feet needed to fly from, I have mainly Align products 250, 450,500,a new to me 550 perched off this site from a VERY top notch guy, a 600 MD 500 scale heli and a stretched 700 ie 760 PLEASE give me your thoughts and if not in a reply a PM would be great
Thanks Rick
and no snide remarks on my last name the answer is no
Richard J. Szabo is offline        Reply With Quote Quick reply to this message
Old 07-26-2017, 09:05 AM   #2 (permalink)
Thanks Rick
I would get it. The issues you have read about in this forum are mostly build issues. There have been manufacturing issues, but they have been taken care of. You will also get top notch support in this forum for any issue you may encounter.
Scott
Team Compass USA--Team Pilot
KBDD Team Pilot ):>
http://www.experiencerc.com : Making Helicopters Great Again!
Old 07-26-2017, 10:07 AM   #3 (permalink)
I haven't flown the eXo, but the Atom (stretch) has been very relaxed and forgiving at lower HS. I'm sure the eXo has a similarly broad flight envelope.
It's a small community, but excellent and friendly support.
Compass Atom 5.5; Oxy 2/3
XK K110 K120
Wargamer is online now        Reply With Quote Quick reply to this message
Old 07-26-2017, 10:22 AM   #4 (permalink)
I would go for it (in fact I did).
It's probably not the easiest build but it's not the hardest either and everything is really nice quality. Some people complain that the canopy is hard to remove but I got over that by fitting the magnetic canopy mounts from the Protos Max.
Otherwise, the heli is great. It looks superb and flies brilliantly - the damperless head and the stiffness of the exoskeleton frame seem to give it a really locked-in feel. It feels really solid in the air. Maybe a little like a lighter weight Goblin? Not sure if that is a good analogy but these things are tough to explain.
Most of my heli's are Logos, Protos or Goblins but the Exo fits in really nicely.
Mark
So many heli's, so little time.
Crashalotjoe is online now        Reply With Quote Quick reply to this message
Old 07-26-2017, 12:49 PM   #5 (permalink)
Hi,
This is not to challenge you, but I would sincerely like to know what you found difficult about the build so we can perhaps address this with future products?
Thanks!
Scott
KBDD Team Pilot ):>
Old 07-26-2017, 01:08 PM   #6 (permalink)
I assembled two of them in the space of about three weeks. They have a low parts count and go together quite easily. It take longer to clean the fasteners and the holes they thread into than it does to do the actual building (this is the case with every helicopter I have ever built, except for scale models).
The eXo is the first, new, truly innovative design on the market that I have seen in several years. As a result, the assembly process is different from anything else out there.
dunkonu23 has an excellent build thread here om HF. Follow that exactly and you will have no issues.
Old 07-26-2017, 01:25 PM   #7 (permalink)
Originally Posted by dunkonu23 View Post
Hi,
Thanks!
Scott
It was nothing really, it's a while ago now but from memory the inner tray assembly was awkward to assemble with multiple pulleys, studs and bearings all making a bid for freedom whilst trying to fit the bottom plate.
The electronics layout is a little tricky because the exoskeleton takes up some of the space for mounting receivers etc. It's not bad and I've ended up with a nice clean build so I'm definitely not complaining.
I had a couple of issues with mismatched tail grips which I had to get replaced but it was an early model so this has undoubtedly been fixed now.
I'm not one of those who subscribes to the theories about laying the heli on its side to change the pack with the canopy on as I am not an experienced gynaecologist so I elected to make the canopy easier to remove with the Protos magnetic mounts on the front supports.
I had a few other issues but these were mainly user error so I won't mention them
As I said, not the easiest build but not the hardest either. Now it's built and has 50+ flights under its belt, I love the way it looks and flies and it's up there amongst my favourite heli's.
Mark
Old 07-26-2017, 06:22 PM   #8 (permalink)
Thanks, Mark! The electronics is one of the things I made sure I went over in the build thread. Actually, the manual shows a great layout, but that's only for a Spartan. Me being a Spartan guy, well...
Once you do the inner frames once, it's easy. I had the advantage of building the test model for the United States.
Thanks for the post! It's really cool.
Scott
KBDD Team Pilot ):>
Human Verification
