X110 Batteries - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > V977/K110/K120
Old 08-04-2017, 01:38 PM   #1 (permalink)
Default X110 Batteries
What are the preferred batteries for the XK110.
Rocketman777 is offline        Reply With Quote Quick reply to this message
Old 08-04-2017, 04:53 PM   #2 (permalink)
LikeYou will hear different opinions, some like the Goo that Banggood sells, some others the Graphene from hobbyking, I do prefer the Glaciers.
I own Graphene, Glaciers and the stock ones.
The ones that gives me more punch and never bogs, Glacier.
The last 2 that came with the BNF helis were good packs, odd, but good packs.
http://www.buddyrc.com/glacier-25c-600mah-1s.html
It depends on your $ and your flying style.
Edit,
Forgot to mention, don't use the charger that came with the heli, guess you already know that
salrica is offline        Reply With Quote Quick reply to this message
Old 08-04-2017, 05:16 PM   #3 (permalink)
The charger that comes with the batteries ...... is that one ok? What balance charger do you recommend - I am in the market. Thanks!
Old 08-04-2017, 05:36 PM   #4 (permalink)
Change the connector to a JST or make/buy an adapter. It will open up a lot more battery options. Just trim the nubs off the battery holder for them.
BrokeDad is offline        Reply With Quote Quick reply to this message
Old 08-04-2017, 08:14 PM   #5 (permalink)
Charger from hobby King or in the classifieds.
Icharger
http://www.buddyrc.com/icharger-106b.html
And the power supply, you can get the combo or going cheap the Imax.
It depends if you want to stick with the hobby, get a good charger, you would not spend twice.
https://hobbyking.com/en_us/imax-b6a...___store=en_us
Old 08-13-2017, 08:57 AM   #6 (permalink)
Default JST
When you change the losi (or are they molex?) connector on the ESC, is it just a matter of carefully removing the pins from the losi K110 esc connector and sliding them into the appropriate JST housing? Sorry don't own any losi style batteries to compare.
Goblin 570(12s),Trex 500Pro,Trex 450Pro.
MD500E(600), Airwolf(500),Agusta A109(Blade450X)
Thtasher is offline        Reply With Quote Quick reply to this message
Old 08-13-2017, 01:38 PM   #7 (permalink)
Hi!
I'm new to the forum and Heli's, but have an XK K110 on its way. I'd like to buy some quality extra batteries from the US so they can be here within a week, but I'm not sure where to get the JST connectors - and if there's a reasonably priced charger that will charge multiple batteries at a time - and do it in a way that preserves the life of the batteries.
So, in short - is there a place where I could order the JST connectors, quality batteries, and a good/healthy multiple battery charger ... in the US (preferably all from the same place)?
Thanks in advance!
Chuck
Ringo1079 is offline        Reply With Quote Quick reply to this message
Old 08-13-2017, 01:47 PM   #8 (permalink)
I just bought a bag of male/female JST connectors with wires and soldered the new one to the board after removing the original.
Old 08-13-2017, 08:37 PM   #9 (permalink)
Thanks, with a bit more research I realized those losi/molex connectors are basically a sealed unit. New to micros
Old 08-14-2017, 07:26 AM   #10 (permalink)
Change the connector to a JST or make/buy an adapter. ...
+1
After swapping out the connector, I'm really liking the HobbyKing 600mAh Graphenes
ridge-runner is offline        Reply With Quote Quick reply to this message
Old 08-14-2017, 09:58 AM   #11 (permalink)
[....HobbyKing 600mAh Graphenes[/QUOTE]
Unfortunately out of stock here in Australia
Old 08-14-2017, 09:14 PM   #12 (permalink)
Icharger
iCharger 106B+ 250W 10A 6S Balance Charger
Is this charger capable of charging multiple batteries simultaneously? If so, what is needed to do so?
Thanks!
Chuck
Old 08-15-2017, 12:31 AM   #13 (permalink)
Thanks!
Chuck
I really like my Q6 charger. It can easily charge several k110 batteries at once. It also has enough power if you decide to go bigger someday. I also use it to charge my 6S batteries for my Trex 470L. This charger, like most chargers in this hobby, won't just plug into your wall socket, it will need a DC power supply. You need something with at least the wattage and amp rating of your charger.
Power Supply - Charging Systems
iSDT Q6 Plus 300W 14A 6S Battery ChargeriSDT Q6 Plus 300W 14A 6S Battery Charger
To charge multiple 1S batteries like we use on the k110, you only need a parallel charge cable. Since these are only 1S batteries you don't need to worry about a balance adapter just yet. Wired in parallel, the charger just sees all the batteries as one big 1S battery. The Q6 uses XT60 connectors so you need a parallel cable with male XT60 to female JST. Here is the one I made. You just connect all the positives together and all the negatives together.
XT60 connectors Genuine XT60 Connectors (2 Pairs, Yellow)
JST female Pigtail Male JST Connectors (5 Pieces, ESC / Charger Side) These are what you also us to replace the connector on the ESC of the helicopter.
And here are the Glacier batteries.
Glacier 25C 600mAh 1S 3.7V LiPo Battery
brian2kgt is offline        Reply With Quote Quick reply to this message
Old 08-15-2017, 08:47 AM   #14 (permalink)
Brian2kgt... this was SO helpful; thank you very much for taking the time to thoughtfully school me on what's what!
I have a couple higher end PSUs, so I like the idea of the Q6. Is there a learning curve with the charger, or is it pretty much automated?
Again, thank you so much for such a thorough and helpful response!
Chuck
Old 08-15-2017, 09:19 AM   #15 (permalink)
Chuck
Old 08-15-2017, 12:08 PM   #16 (permalink)
I just realized that the link I posted for the JST connectors is confusing. The picture shows female connectors and the description says "ESC/Charger side" which is correct for female but it also says Male in the title? I don't know what is going on there, I ordered mine from Amazon and got the male/female set.
https://www.amazon.com/dp/B01JUDP5NY/
Old 08-15-2017, 06:08 PM   #17 (permalink)
Chuck
It's pretty easy to use and automated. Just select the battery type(Lipo) and cell count(1S) then select your charge current(Amps). The recommended charge rate for the Glacier 600mah batteries is 1.2A each or what is known as a 2C rate. If you for example hook up 3 at once in parallel like I do, you can then charge at 3.6A because the charger thinks it is just charging one 1800mah battery.
The Q6 actually doesn't come with any wires, just some extra male XT60 connectors. You have to either build your own input lead and charging lead or you have to find what you need prebuilt from somewhere.
Old 08-15-2017, 08:51 PM   #18 (permalink)
This combo
"The Starter" 350W Combo - ProgressiveRC
The squid
Parallel (6x) JST Charge Cable - ProgressiveRC
I charge 6s 4400mah with this charger, been serving for years, not a problem.
Something to chew on
How-To: Parallel Charging - TJinTech
Old 08-16-2017, 01:50 PM   #19 (permalink)
Thanks again, very much - very helpful!
Chuck
Insurance
Human Verification
