Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade mCPS
Blade mCPS Blade mCPS Helicopters Information and Help
Like Tree13Likes
Old 05-19-2018, 07:50 PM   #61 (permalink)
Well, guys, I've decided to sell mCPS--just too many helis and I haven't been flying this one all that much. Right now, my ad is at RCGroups:
Brushless Blade mCPS Package
Thanks!
navigator2011
Oxy2 190 FE / Oxy2 190 Sport / Fusion 180 / Blade 150S / Trex 150X / Blade mCPX BL2 / Brushless Nano S2 / Spektrum DX9.
navigator2011 is online now        Reply With Quote Quick reply to this message
Old 05-31-2018, 03:43 PM   #62 (permalink)
Default it's not the mcps but the v2 stock
i drop this video here since its practically all the same part
mcpx v2 stock indoor (1 min 28 sec)
CrashyCrashy likes this.
Lynx Heli Innovations Field Rep!
OXY 4 !!
Goblin 500 sport- Goblin 700 competition
Extreme Flight MXS 94'' , DA-70, MKS HV 777
jean-michael is offline        Reply With Quote Quick reply to this message
Old 05-31-2018, 08:22 PM   #63 (permalink)
Great flying in such a confined area! Awesome control of that machine.
FR4-Pilot is offline        Reply With Quote Quick reply to this message
Old 06-01-2018, 12:48 AM   #64 (permalink)
Dang, that's great! No tail blow outs, either.
navigator2011
Old 06-01-2018, 01:39 AM   #65 (permalink)
Thanks ! I very like this heli. Its relax you need to remove the pitch when you hear the motor bog. It prevent tail blow-out I also set my pitch curve to 0-17-50-83-100%
OXY 4 !!
Old 07-02-2018, 12:27 PM   #66 (permalink)
Great flying! I subbed. What battery?
CrashyCrashy
CrashyCrashy is offline        Reply With Quote Quick reply to this message
Old 07-02-2018, 12:34 PM   #67 (permalink)
I very like the nano tech 300 mah 45c. But I only fly 3min because more than that the motor start to bog. I land at 3.8.
FR4-Pilot and CrashyCrashy like this.
OXY 4 !!
Old 07-10-2018, 11:21 PM   #68 (permalink)
I purchased one last week. Flew it today. 8-9 flights total. It needs more break-in. My batteries might be a bit weak. May need some more cycles, not sure. So far it has potential in OEM form. I might order some Pulse batteries. Absolutely no tail blow outs and I have the pitch in the 90's. It definitely holds better than the V1 or V2's I had.
Hopefully the power picks up. I also have some KBDD main blades and tail rotors to try.
Crashycrashy
Old 07-11-2018, 07:49 AM   #69 (permalink)
Cool - Congrats on your new heli !
Mine needed 20 or so flights to 'break in'. It was pretty sluggish at first - I thought I got a dud. Even the stock lipos ended up being fine - I thought they were duds too. I did get a bunch of NanoTech 300s - they work great. Maybe re-evaluate around flight 30 or so.
I tried KBDD blades too. Mains worked fine (they are lighter than stock). I had major problems with the KBDD tail blade (it's twice as heavy as stock). Poor tail performance, constant blowouts and shortened battery life. Put stock tail blades back on and everything was fine. Let us know how they work out for you ...
Old 07-13-2018, 12:04 AM   #70 (permalink)
Yep the included Eflite batteries are trash! I have never had a good 1S eflite pack! Voltage sag for days after 30-40 seconds! Heli flies great, it just needs some good batteries.
I sold my mCPX BL a month or so ago.... missing it. Anyway I would trade my mCPS for one.
I haven't tried the KBDD blades. Everything is still stock.
Crashycrashy
Old 07-17-2018, 02:13 AM   #71 (permalink)
I ordered some Pulse batteries. Installed the solid tail boom. The KBDD tail rotor performance was poor with the hollow boom. I'll try one on the solid long boom. I suppose the KBDD rotor would be fine for sport flight. I was getting excessive TBO flying 3D. I expect the same results with the solid long boom. I really don't want to comment on main blade performance until I have flown the Pulse packs.
The KBDD skids seem to be fragile compared to OEM also. They are not deformed an any way and look very good. I can't say that about the OEM skids.
Crashycrashy
Old 07-17-2018, 11:12 AM   #72 (permalink)
Seems like the slightest little crack in the hollow boom greatly exacerbates the TBO likelyhood. Also, current drain by the main motor seems to be a factor as well, starves the tail motor and causes TBO.
navigator2011
Old 07-17-2018, 02:46 PM   #73 (permalink)
All true.... The Pulse packs will be here tomorrow. I'm thinking about ordering the factory brushless kit after the motor starts to go.
Crashycrashy
Old 07-17-2018, 04:15 PM   #74 (permalink)
I know for a fact that heavier blades make the TBO problem worse. I had a hell of a time with the bulleted blades causing TBOs, and then found the non-bulleted blades to be much more forgiving (assuming the boom wasn't cracked, of course).
Basically, anything that contributes to increasing main motor torque and current draw will exacerbate the TBO tendencies of the mcps. With this said, if you do get the HH brushless, I recommend running stock, non-bulleted main blades and reducing your servo travel to 80/80 to keep the TBOs under control.
navigator2011
Old 07-17-2018, 08:48 PM   #75 (permalink)
I'm not having TBO problems with the OEM rotor. Lol. The hollow boom lasted a week before it cracked. The KBDD caused TBO were the OEM would hold. I'm having a motor bog problem caused by crap packs though. I've been flying 3D with mCPX helis for many years. My setup is good, and pitch management is... lets say above average.
The bullet blades are harder to fly 3D with. The heli tracks better with them though. Other blades are quicker and more forgiving on pitch. In my opinion there isn't a perfect blade for micro helis. Even with the 180CFX. Carbon blades are pretty precise but, do not have the pop of plastic blades. Even with the pitch increased. I do like both blades.
Crashycrashy
Old 07-22-2018, 02:24 PM   #76 (permalink)
Default Angry bird
Installed a Microheli angry bird canopy, green tail blade, and a set of red micro heli main blades. Looks great in the air and very visible.
ID:	751361   Click image for larger version
Name:	angry bird 2.png
DX6e / Trex 550X / Trex 500 XT/ Blade 180 fusion / Blade 270 Fusion
mingledorffw is online now        Reply With Quote Quick reply to this message
Old 07-22-2018, 03:01 PM   #77 (permalink)
Looks good.
CrashyCrashy
Old 07-22-2018, 03:37 PM   #78 (permalink)
Default ...
Thanks, I use the sling shot to launch it now.....
Old 08-03-2018, 08:17 PM   #79 (permalink)
Put a few flights yesterday and today..(first of the season)...It fly's so good and is perfect for my back yard. It is a blast to fool around without the risk.
Cman likes this.
Tom
Blade 230s V2, mCPs, 360 Fusion, Losi 3xl-e and iX12
Nytro97 is offline        Reply With Quote Quick reply to this message
Old 08-24-2018, 08:55 AM   #80 (permalink)
I finally took mine outdoors, been hovering indoors sense I got it shortly after it was released. did some sloppy flips then they got better, then it pitched nose up and fell, i hit hold and did the short walk of shame, no damage noted. I let it cool off put a battery in and decided it was time to do some forward flight, wow this thing flies great i was F-mode 2 and it handled like it was on rails. then it lost power and returned to mother earth, after just over 2 min of flying i hit LVC. When i got home i checked the batteries one was 3.78 the other 4.19 I put the first battery back in
still had fun and it will fly again
C
Blade 230S, Nano cpx, nano qx/3dqx/fpv, 200qx MCPX V2, Align Trex 250, 250 DFCplus, Trex 450 plus,Trex 500, JR Forza 450, and more I retired
Cman is online now        Reply With Quote Quick reply to this message
