Go Back   HeliFreak > R/C Helicopter Support > MSH Protos > Protos 380
Old 08-08-2017, 09:01 AM   #1 (permalink)
Default tail thrust bearings tand tail wag
I'm having trouble with tail wag on protos 380
Everything smooth on the tail, very smooth but can't get rid of the the small fast wag
Issue is ( i think) the thrust bearings
I am putting the bigger internal hole section in first and it is so tight in the grip that i have to force it and with a large ish hex key. Problem is that is is so tight that i am getting shards of plastic from the inside of the grip stuck in there with it! hence the wag i would suspect.
I measured the inside diameter of the thrust washer and bigger hole is labelled "o" which to me is the outside one but it does state in the manual bigger hole first .
tried 2 sets of tail grips and other thrust washers and they are all as tigh and getting shards of plastic!
I is usually inner and o is usually outer?
Anyone else had this or am i just not getting something
justjustin is offline        Reply With Quote Quick reply to this message
Old 08-08-2017, 09:04 AM   #2 (permalink)
and i have tried the thrust washers the other way round and i got the slow wide wag which would say that way is wrong
Old 08-08-2017, 04:16 PM   #3 (permalink)
With the large ID thrust bearing Rae to the outside you will have induced a mechanical wag that no amount of tuning will get rid of.
What is your gyro gain setting?
Paul
Agile 5.5 - Q 4125-1100, YEP 120, Brain2 HD FBL / Outrage 550 - HK4020-1390, Edge 120, Brain2 HD
Rave Ballistic FSO - Q 4530-500, Edge 160HV, Brain2 HD / Protos Max V2 - MSH 4530-500, Edge 160HV, Brain2 HD
pctomlin is offline        Reply With Quote Quick reply to this message
Old 08-08-2017, 04:23 PM   #4 (permalink)
That doesn't sound right. The one labeled "o" should be the one with the smaller hole and go on the outside. Is the other one labeled "i"? Maybe something is mixed up?
Michael
Diabolo 600, Prôtos 380; Oxy 3 Tareq Edition 2018; 230S Night
mulchi is online now        Reply With Quote Quick reply to this message
Old 08-08-2017, 04:59 PM   #5 (permalink)
Not sure how to post the image capture. page 50 of manual shows picture of blade grip and above picture of thrust bearing assembly as large internal hole first then roller bearing then the smaller diameter washer.thats how i have it via measuring i d's
even though first one is o and outer is I which i agree sounds opposite.
I think the problem is the bits getting in the race from the blade grip so i assembled all the bearings and washers on a screwdriver and installed them as one so as to eliminate hopefully the bits of plastic getting in between. I can all ways swap them again
rain here today so hope to test tomorrow. I did try the other way with I in first and o for outer but got a slow wide wag. Tail gain from 30 up to 45 (too high) in the Brain and no change. Will post when i have tested. Perhaps i'm just chasing my tail ! Looking forward to getting this sorted so I can fly It and see what it's like.
Thanks for replies
Old 08-09-2017, 05:13 AM   #6 (permalink)
The picture shows the orientation in order from large to small with the tail grip in the same orientation onto the tail rotor hub.
Team Only Fine Helis
Rave ENV Nitro, Protos 380 Evoluzione, Protos Max v2, VBar Control
https://www.onlyfinehelis.com/
mystar60 is offline        Reply With Quote Quick reply to this message
Old 08-09-2017, 05:36 AM   #7 (permalink)
If you tried two sets like that with the same result I would forget the ID measurements and put the o and I in the proper order and try it that way again. Then try to dial out the slow wag by adding a little gain.
I didn't measure anything, just went off the o and I and everything worked great.
Hope you get it squared away. You're going to love this heli once you do
Mini Protos 6s stretch/Rochobby Nemesis NXT/RareBear funfighter620mm
~Problem Child~
learnedthehardway is offline        Reply With Quote Quick reply to this message
Old 08-09-2017, 05:54 AM   #8 (permalink)
I just put each one on the shaft individually without grip and rock them. The small one won't rock as much noticeably.
tshelby73 is online now        Reply With Quote Quick reply to this message
Old 08-09-2017, 12:18 PM   #9 (permalink)
I have a wag I can't dial out as well. I noticed recently that my tail blade grips have a little play along the shaft. With the bolts fully seated, I can push/pull the grips along the shaft about a millimeter. If I remember correctly, the whole assembly comes prebuilt from the factory.
I've pulled the grips off but did not pull any bearing out since they were extremely hard to push out. I didn't try with more force than I felt was necessary. When reassembled, it did look like there was a little bit of the shaft sticking out from the bearing. Looked like a washer was missing.
Pulled out all the remaining bags from the build and did not find any washers that would fit. Ordered a tail grip kit and will try using a washer from it to take up the space.
It is the same on both sides.
vhuang168 is offline        Reply With Quote Quick reply to this message
Old 08-10-2017, 03:54 PM   #10 (permalink)
perhaps i should try the o and i as per normal and dial out the slow wag. tried another set of the thrust bearings tonight (the msh part that is just the thrust bearings) and they had no markings still the same though( installed via measuring) all shafts polished including pitch slider bush and still no good
The only resistance is probably from the pins in the blade grip arms.
So turned off the brain gov and as im using the hobbywing v4 -i enabled gov on that.
Now im getting loose tail (hovering) and quick tight wags on stops!. Increased p gain with stock brain settings still the same lowered and raised i and similar stuff. I have all ready lowered d because of the stop behaviour.
I'm a bit out of my depth with p.i.d gains
anyway I've got another mini brain I'm gonna swap over tomorrow and see how that goes.
I've still got high hopes for this little Heli when i get this sorted out !
Old 08-10-2017, 03:56 PM   #11 (permalink)
i think there is a little play on the blade grips and the shaft does stick out a bit when you look in the grip.
Probably not a good idea to listen to what i say about tail grip assembly at the moment though
I'll be an expert soon though!
Old 08-11-2017, 07:16 AM   #12 (permalink)
Well It's not mechanical.
Reset the esc end points with the sticks tried it out in heli linear mode spooling up gently to avoid the kick and pretty good tail, just a bit of tuning needed!
Re enabled gov in the brain and all good there, no weird wags but still a little bit of tuning.to do
I did the end point calibration when i set up the heli but perhaps i altered something after doing so,who knows?
Thank F&@% for that. I was really questioning my self!
Fingers crossed that's it!
Tags
protos 380, tail wag
Human Verification
