rubber on pulleys - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > eXo
Old 08-13-2017, 03:57 AM   #1 (permalink)
Default rubber on pulleys
hey guys.is it normal to have quite a bit of rubber left on the motor and tail pulley guides?my belts are not overly tight or loose,pulleys seem to spin freely.there just coated in what looks like melted rubber from the belts.heli flies good,just dont know if i need to worry about this or not.
biffo is online now        Reply With Quote Quick reply to this message
Old 08-13-2017, 09:48 AM   #2 (permalink)
It's completely normal to have some residue on the idlers. You're good to go! If it bothers you, clean it off. I clean mine sometimes.
Scott
Team Compass USA--Team Pilot
KBDD Team Pilot ):>
http://www.experiencerc.com : Making Helicopters Great Again!
Old 08-13-2017, 10:02 AM   #3 (permalink)
Do you run yout belts dry?
My belted helis have weary litle recidues on the pulleys but i lube my belts with cilicone spray and have done so for many years.
Logo 600SX
Warp 360
Chase 360
Exo 500
Mr.Andersen is offline        Reply With Quote Quick reply to this message
Old 08-13-2017, 12:07 PM   #4 (permalink)
Good point! Always lube belts with food grade silicone. This will keep the belts supple and increase life.
Scott
KBDD Team Pilot ):>
Old 08-13-2017, 02:52 PM   #5 (permalink)
I'm curious, what exactly is "food grade" silicone?
tsoebirk is offline        Reply With Quote Quick reply to this message
Old 08-13-2017, 04:07 PM   #6 (permalink)
It means in case of a Zombie Apocalypse, once you treat your belts, they can be eaten.
Seriously, it's just a grade of spray that does not harm rubber or plastic and is safe for incidental food contact. That it doesn't harm rubber means it's safe for belts and won't accelerate rotting by breaking down the belt's rubber.
I use the CRC stuff.
Scott
KBDD Team Pilot ):>
Old 08-13-2017, 04:24 PM   #7 (permalink)
Please do not lube our belts the small rubber particles on idlers are normal as we are using neopren belts. The belt isnt wearing at all just keep flying it.
Team Compass Model - Kontronik - Rapicon - MTTEC - KBDD - MKS
Sebastian Zajonz is offline        Reply With Quote Quick reply to this message
Old 08-13-2017, 04:36 PM   #8 (permalink)
Will lubing them dammage then in any way?
I do it not only for lubrication but allso to kill staticks.
Logo 600SX
Warp 360
Chase 360
Exo 500
Old 08-13-2017, 05:25 PM   #9 (permalink)
Thanks for the replies.I had a look last night,I also get quite a bit of rubber build up in the tail pulley teeth.it seems a couple of teeth have more build up then others and make the belt run a bit distorted or tight in that area.anyone else notice this?
Old 08-13-2017, 07:17 PM   #10 (permalink)
Seb,
Why? I've always used food grade silicone spray on belts with no detrimental effects and so has Ah Clem. Is there a specific reason?
Scott
KBDD Team Pilot ):>
Old 08-13-2017, 11:41 PM   #11 (permalink)
I just found out the CRC stuff I've been using has a petroleum based propellant in it. While everything except the spec sheet my teammate Saje sent me said it was safe for "most" plastic and rubber, I'm stopping its use.
Thanks to Saje!!!
Scott
KBDD Team Pilot ):>
Old 08-14-2017, 08:05 AM   #12 (permalink)
I used to have a mark or two a while ago. Send me a pic Biffo on messenger please.
Lighty is offline        Reply With Quote Quick reply to this message
Old 08-14-2017, 08:21 AM   #13 (permalink)
Do you find that you have to run the belt tighter after lubricating it?
beltfedbrowning is online now        Reply With Quote Quick reply to this message
Old 08-14-2017, 10:45 AM   #14 (permalink)
I have to go with Scott on this one. With the deepest respect to Sebastian, I have been lubing belts for years with no issues.
The reduction in friction and lowering of static are the reasons I do it.
A small amount of rubber residue on the idler pulleys is normal-a large amount is not.
A large amount would indicate a pulley that is not rotating freely or a belt which is too tight.
The belt does not require tightening after lubrication (remember, a cog-belt is actually a gear of infinitely variable shape). The belt usually requires tightening a bit after break-in (usually 5-6 flights and then almost never after that,with the exception of extreme temperature changes).
Properly lubed and tensioned tail belts have no more drag than properly set up gear-driven tails:
Compass 6HV U Proper Belt Tension (1 min 3 sec)
Old 08-14-2017, 11:08 AM   #15 (permalink)
No problem Scott. I would recommend the Trident brand stuff that comes in a non-aersol pump spray bottle. This is the only spray I know of that contains no petroleum in the propellant...
I think that the aersol guys get away with using petroleum propellants because the petroleum chemical will likely evaporate off of any non-porous substance very quickly leaving no resudue. If placed directly on a belt though it will likely soak in a bit before it can all properly flash off.
*Chronos*7HV Nitro*EXO*Warp 360*
Compass Models Field Rep
Raz0rSh4rp is online now        Reply With Quote Quick reply to this message
Old 08-15-2017, 07:23 AM   #16 (permalink)
With respect to the guys that lube their belts that's very old school. Too much lube on a belt can cause it to slip and creates a mess.
I've got over 500 flights on my BT700 and never lubed the belt once, much less for any of my other machines. As long as you keep them out of direct sunlight they'll last virtually for ever
DarkSyd3D is offline        Reply With Quote Quick reply to this message
Old 08-15-2017, 11:57 AM   #17 (permalink)
You should put "Your mileage may vary". I've had belts on my old Gaui 425/500/550's slathered with silicone and had no slips.
Scott
KBDD Team Pilot ):>
Old 08-15-2017, 01:55 PM   #18 (permalink)
" I've had belts on my old Gaui 425/500/550's slathered with silicone and had no slips.
Same here with Compass, Align, SAB, Kyosho, Mikado, Hirobo, Velos, EXI, Thunder Tiger, MA, and others.
Human Verification
