Blown Fuses on MPA Board - HeliFreak
Old 08-14-2017, 06:41 PM   #1 (permalink)
Default Blown Fuses on MPA Board
As the title says, so how how do I change them out? They seem to be soldered in
gtrsteele is offline        Reply With Quote Quick reply to this message
Old 08-15-2017, 07:54 AM   #2 (permalink)
Easiest method is to use solder wick to remove the solder, then fuse is easily replaced.
Fyi - they are soldered because none of the fuse holders can handle 40A without significant voltage which affects charging accuracy.
RevoKelly is offline        Reply With Quote Quick reply to this message
Old 08-15-2017, 02:34 PM   #3 (permalink)
Thank you. Do you if there's a particular type of 40 amp blade fuse I should get?
Old 08-15-2017, 02:56 PM   #4 (permalink)
When replacing fuses, carefully break the plastic off. This will allow removal of one fuse blade at a time. Less heat to the board. Then wick excess solder.
Gaui x5, x5, Rush 750 - Ikons, x7 - CGY750, 14SG
FAA Reg # "DRONESSUK"
DanMcN is offline        Reply With Quote Quick reply to this message
Old 08-15-2017, 03:40 PM   #5 (permalink)
Good idea
Old 08-15-2017, 08:01 PM   #6 (permalink)
Does anybody know what spec fuse I need? I found these on Amazon.
Old 09-11-2017, 01:28 PM   #7 (permalink)
Pretty much a automotive 40a for this use. I have one board that has the ATC (usa) fuse and another with MTA euro fuses that I can't find in the states.
Fuse 40a 32v
Old 09-15-2017, 09:42 PM   #8 (permalink)
Thank you
Insurance
Human Verification
Copyright © VerticalScope Inc. All rights reserved.
