Go Back   HeliFreak > R/C Electronics Support > Scorpion ESC and Motor Support
Scorpion ESC and Motor Support Scorpion Power Systems ESC and Motor Factory Support Forum
Old 08-16-2017, 03:02 AM   #1 (permalink)
Default V52 Firmware Tribunus
From Facebook
[qoute]
Tribunus ESC firmware V52 test completed! Ready for public release.... that was long to do!!!
- for 14S ESC increased measurement precision on phases (better starting, better sync)
- Added additional start up calibration (increased power on time)
- Added one more protection for maximum ESC temeperature (2s delay, 130 for mosfet, 110 for control)
- added event flag for sync loose (after 2s of sync error, power will be cut to 40A for14S and 12S, to 30A for 6S)
- added short circuit protection
- set default BEC voltage to 5V
- fixed bailout and restart mistake for Vbar mode
- added RPM output signal for all modes
- added writing instant error code to the log
- Added time for unsolicited telemetry mode. Added additional check for false switch to PC mode.
- Changed maximum allowed current for 14S to 280A.
[/quote]
Gaui R5, Henseleit TDR, TDR2, TDF, Banshee
Kontronik, Scorpion ESC, iChargers, VBar, VControl, JR XG11
Old hand at Planks
Old 08-17-2017, 07:32 AM   #2 (permalink)
Thanks for the heads up. I'll have to update.
Anyone else noticed..... If you fly lower head speed or have a lower amp draw, the accuracy of the MAH used goes down? I actually needed to tweak the battery app settings in my VControl to avoid over discharging when flying a whole flight in bank 1 (1600) on my L700 because it didn't warn me soon enough I had reached the desired charge level.
Hopefully the "accuracy" talked about in the update will help this.
I've only noticed this on my Tribunus200. My 120s don't seem to have the issue.....although I don't spend much time at the lower head speeds with my 550sx/550se so maybe I just haven't noticed it?
KevinB
KevinB is offline        Reply With Quote Quick reply to this message
Old 08-17-2017, 01:47 PM   #3 (permalink)
Your quoted accurcy statement has to do with measuring where the magnets are in relation to the stator.
mAh consumed has so many variables and the age of your packs will be the biggest factor in errors.
Old hand at Planks
Old 08-17-2017, 02:08 PM   #4 (permalink)
What I'm saying is that on the same heli and using the same packs, the same alarm for the MAHs consumed will come later if flying very gently compared to when flying hard.....and this results in taking too much out of the pack, albeit great flight times. Hard on packs though.
It's like when flying easy, some MAHs slip through without being counted. So even though a hard (shorter) flight says you used the same capacity as the easy (longer) flight, the cell voltages are lower after the easy flight and more goes back into the pack. I could understand this happening if the capacity alarm just looked at pack voltage. An older pack with more voltage sag would trip the alarm sooner on the harder flight with more load. But if it's supposed to be measuring actual MAH taken from the lipo, shouldn't that be the same no matter how quickly you remove it?
KevinB
Old 08-17-2017, 11:54 PM   #5 (permalink)
I was setting up a new 200 amp esc and I downloaded firmware #52.
Now I need to update the others. Is this only for the 200 amp or does it include the 120 amp as well ?
I have not noticed a inaccuracy in Mah consumption for low head speed to high head speed. I set my battery Mah in the battery app to a 10% lower than the pack actually is. So for a 4400 Mah pack I set it as a 4000 Mah battery. I set it for 65% / 35% and they come down with 3.75 volts per cell. Seems to work.
Synergy 766, E7SE, E5SS, E5S, 516, V Control, Neo, Tribunus
Freeskiken is online now        Reply With Quote Quick reply to this message
Old 08-18-2017, 02:12 PM   #6 (permalink)
It shows version 52 for the 06-120, 14-200, and 16-300 ESCs.
Old 08-18-2017, 05:04 PM   #7 (permalink)
I'll have to actually record what the VControl says I took out vs what the charger is saying I'm putting back in for high and low load flights.
KevinB
Old 08-18-2017, 05:36 PM   #8 (permalink)
Unhappy
I cant find version 52 for the 06-120
I do see the version 52 for the 200 amp
Charlie R
Charlie R is offline        Reply With Quote Quick reply to this message
Old 08-18-2017, 10:56 PM   #9 (permalink)
KevinB
Every charger will vary on mAh charged and are not that accurate as there are internal losses in the charger.
The best practise is to fly your normal flights and keep an eye on your packs and adjust the % warning in the VBC for each pack.
Old hand at Planks
Old 08-19-2017, 12:31 AM   #10 (permalink)
Yes. I realize the charger results will be different due to balancing losses, etc. I meant it more as a relative comparison. To see how much I'm actually putting back in a pack after flying to the capacity alarm on a low speed flight vs a high speed flight.
I look at my ending cell voltages on every pack as I start the charge cycle and adjust the individual pack capacity in the VBC if I see I'm discharging too far........ie: any cell is below 3.77V. My point at the beginning of my posts was that I have found I'm needing to tweak the recorded pack capacity in the VBC even lower after low current flights. Then after doing a harder flight, I'm well above the 3.77V target. Which is ok. Just an observation.
KevinB
Old 08-19-2017, 12:33 AM   #11 (permalink)
Scorpion Team. Tribunus 06-120A FW v.52
| Atom 6HV : Spirit pro | Goblin 700 : Brain2HD | HD Cell 500 : brain2 |
ragge1 is online now        Reply With Quote Quick reply to this message
Old 08-19-2017, 12:39 AM   #12 (permalink)
Or here: Scorpion Team. Tribunus Firmwares
This link will sort on date posted so all the newest firmware versions are at the start of the list.
KevinB
Old 08-19-2017, 06:33 AM   #13 (permalink)
KevinB
It's really a limitation of the hardware. It uses a very small value shunt resistor and measures a tiny voltage drop to measure the current flow. This has a limited sensitivity range. And since it's sized for 200A continuous the value has to be really small limiting how well it can detect small currents.
So no matter what on all escs flying really low headspeed with an easy style has poor accuracy. You will see the same problem on any esc used for mAh measurement.
MSH USA
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 08-19-2017, 09:09 AM   #14 (permalink)
Thumbs up
Thank you ragge1 and KevinB
Charlie R
Old 08-20-2017, 05:37 AM   #15 (permalink)
I have found my 200 to accurate at low or high head speed. Maybe you mean really low. I fly my 780 at 1550ish and sometimes 1950ish. Both flights will take back almost the same mah.
Team MSHUSA
Switch Blades BK Servos
Michaelinpr is offline        Reply With Quote Quick reply to this message
Human Verification
