Old 08-17-2017, 01:28 AM   #1 (permalink)
Default jive pro vbar neo throttle issue
might be missing something simple here, but my last vbar and jives all worked fine but can not get this new version to work as i want, so motor arms at 0% throttle, but wont spin until past 65% throttle meaning can not use idle up less than 65%, also it will arm at any value when i try to calibrate the end points, ive plugged it into a standard receiver and got it all working fine but not with the vbar neo
ive read that i can put throttle into aux3 and then run a mix, but do i mix aux3 to throttle or mix throttle to aux 3
stocksy27 is offline        Reply With Quote Quick reply to this message
Old 08-17-2017, 04:49 AM   #2 (permalink)
Neo does not have standard throttle output and does not use your TX throttle or throttle curves at all. Throttle output via standard ESC port is controlled by settings in each bank.
VBar NEO FAQ | VStabi
If you want to use your TX to control the ESC then you use AUX3 as output to ESC and in the Neo PC software choose throttle channel to output at AUX3. Take note you would still need the motor switch to be set up as the Neo control loop needs to know when the motor is running.
Gaui R5, Henseleit TDR, TDR2, TDF, Banshee
Kontronik, Scorpion ESC, iChargers, VBar, VControl, JR XG11
Old hand at Planks
Old 08-17-2017, 02:11 PM   #3 (permalink)
thanks, i have swapped to aux 3 and vbar software shows that its all working as it should off idle and run but the esc wont arm, plugged back into esc port and arms straight away, dx8 gen2 never had such hard work before
Old 08-17-2017, 11:52 PM   #4 (permalink)
If throttle controls the AUX3 channel in the pc software, then you need to program the endpoints of the ESC, mode one first and then mode 4 or any of the other governor modes. Follow Kontronik's manual on stick programming while ensuring that you have a 0-100% throttle curve.
If you want to use the normal way of controlling the ESC then you need to still stick program the ESC by switching on direct throttle control in PC software and upon reboot you can stick program the ESC, this direct throttle control will stay on until you switch it off again. Step 4: Programming the ESC | VStabi
Old hand at Planks
Human Verification
