Go Back   HeliFreak > Multi Rotor Support > Flight Controllers (NAZA, Wookong, A2, etc...)
Flight Controllers (NAZA, Wookong, A2, etc...) Flight Controllers (NAZA, Wookong, A2, etc...)
Old 08-18-2017, 11:04 PM   #1 (permalink)
Default SP Racing F3 EVO, HELP PLEASE!!!!
Got the above flight controller and for the life of me cant get it to show receiver in cleanflight or betaflight.. I've tried 4 different receivers and 2 different radios with the same outcome NOTHING!! I've tried wiring the receiver straight to the board and have tried using the URT connector. I've tried it in Ibus, Sbus, PPM and NOTHING, got it to work one time for about 5 min and rebooted and all it does when i go into receiver tab is flash the bars for the channels real fast then vanishes. Please help before i decide to stomp the whole thing to bits.... been trying to get it to work now for 3 days......... image shows how i wired it to the board not including the blue wire...
Beating the air into submission!!!!
3d-wanna-b is offline        Reply With Quote Quick reply to this message
Old 08-20-2017, 02:06 PM   #2 (permalink)
you must supply an external 5v power source to get the receiver to power up. only 3v receivers will power from the usb.
I give up on signatures.
Cpl Woody is offline        Reply With Quote Quick reply to this message
Old 08-20-2017, 11:42 PM   #3 (permalink)
I should have mentioned I had my flight pack hooked up at the time, 3s lipo?? do i still need an external for the receiver??
Old 08-21-2017, 11:30 AM   #4 (permalink)
Just to verify, the quad is standing unplugged from the pc, powered up via the flight pack, and the flight controller is on? If you have the quad powered via the flight battery and still no 5v supply to the flight controller/receiver other than the USB, it still will not power on the receiver.
My second question then is have you bound the receiver and the transmitter? even with the wrong settings on beta/clean flight you will get the LED on the receiver lit when connected.
Old 08-21-2017, 02:09 PM   #5 (permalink)
Yes, with the quad powered up with the lipo the flight controller is powered on along with the receiver, i can leave all as is and hook a 4.8v pack up to the receiver and still no change.
Yes the radio and receiver are bound, solid red led on receiver.
Old 08-21-2017, 04:55 PM   #6 (permalink)
ok if you are trying to wire via sbus, connect the sbus cable to the uart 3 rx port, then go into beta/cleanflight and go to the ports tab. On UART3 enable SerialRx, Hit save, drop to the configuration tab, then find the receiver box, select serial rx on the drop down and sbus on the next one, save, then head to the receiver tab and you should be functional
Old 08-22-2017, 02:12 PM   #7 (permalink)
Tried everything above, same outcome tried it in sbus, ibus, ppm. I hooked up a cc3d board and all works fine.. I didn't really want to use it on a new build, i dont know if the sp racing board was bad or i just missed something..
Old 08-22-2017, 02:51 PM   #8 (permalink)
Its sound like there might be something defective. At this point youve pretty much exhausted all your options....
Old 08-22-2017, 11:18 PM   #9 (permalink)
Yep it looks that way, any recommendations on a new board?? Also thank you for all the help
Old 08-23-2017, 05:34 PM   #10 (permalink)
really depends what you want. Ironically since they all run the same firmware, the choice comes down to a few details.... if you are looking for something similar, the MRM Mantis works great. I also like the X-Racer F303. Cant go wrong with the Omnibus F3 or F4 on the higher price end.
