How to configure DS14 for Brain 2? - HeliFreak
Like Tree8Likes
  • 3 Post By Chippie13
  • 2 Post By Necroscope
Old 09-09-2017, 09:53 AM   #1 (permalink)
Default How to configure DS14 for Brain 2?
I have searched over many set up videos and can't find anything that refers to radio set up. Mostly my issue is how to do the Tx page in the Brain software. I am able to do the typical stuff like Aileron, Elevator, Tail, Pitch and Throttle. But when it comes to the Tail gain, Aux and Set up Switch I can't get anything to work. Nor do I really know where to begin.
Anyone?
Team MSHUSA
Scorpion Power Systems
Switch Blades BK Servos
Michaelinpr is offline        Reply With Quote Quick reply to this message
Old 09-09-2017, 11:29 AM   #2 (permalink)
It's done in functions assignment under model menu. There's already a gyro sense function built in. I've added custom functions for setup and rescue. You can assign the rx channels to use per function under servo assignment. To set the values for gyro go to flight tuning menu and gyro sense is there. All this is in pg75 of user manual.
HAPPY FLYING!
http://www.baysidercclub.com | AMA#912659 | RCHN #830
Jeti DS14 | Brain2
Protos Max V2 | Protos 380
canbarelyhover is offline        Reply With Quote Quick reply to this message
Old 09-10-2017, 02:54 PM   #3 (permalink)
If you are still struggling let me know then i can make a short video showing you how to do it
Chippie13 is offline        Reply With Quote Quick reply to this message
Old 09-10-2017, 03:16 PM   #4 (permalink)
I am good now. I understand it a bit better after going back and forth with Alex Rose yesterday. Thanks Alex.
Can you make a video anyway. I am sure it will benefit many and myself I. The future.
Team MSHUSA
Old 09-13-2017, 11:53 PM   #5 (permalink)
Hi here is the first part which explains the basics of getting the radio ready before moving into the Brain setup
Jeti - Brain - Setup Part 1 (10 min 9 sec)
Old 09-14-2017, 05:06 AM   #6 (permalink)
Great video!!
Gaui R5 Kosmik 200, Scorpion HK 4235-630
TDR (build in progress)
Raptor G4 720e xnova 4530-525 Kosmik 200
Gaui X5 Jive 100 Scorpion 910, Jeti DS-16
john2kx is offline        Reply With Quote Quick reply to this message
Old 09-14-2017, 12:58 PM   #7 (permalink)
Part 2 of the setup uploaded which explains the channel mappings and shows a little extra to figure out which channels affect what functions in the Brain.
Jeti - Brain - Setup Part 2 (13 min 20 sec)
PJing, Necroscope and BrainDev like this.
Old 09-18-2017, 04:06 PM   #8 (permalink)
Wow, great videos. I too am just setting up a DC14 to Brain. So very helpful to say the least.
My question is to do with the switches. In the switch menu, there are so many options, but it is not clear how the switches works, it is very much a game of ticks and crosses. eg, it took me all night to put my Flight modes onto a 3 position switch, and then to map that to tail gain, and my throttle curves was just plain hard work. Any simple way of understanding how the switch menu works? And how everything interacts within the Jeti, thanks
crash'n'learn Chris
If you ain't crashing you isn't learnin.
crsorrell0653 is offline        Reply With Quote Quick reply to this message
Old 09-19-2017, 03:30 AM   #9 (permalink)
Hi, I haven't watched the videos mentioned above, I am sure they are good, but here is one from Esprit Tech for basic heli setup.
Helicopter Programming: Basic Setup (12 min 53 sec)
I used that to get me started before starting on the Brain, there is another video good here that explains about setting up you trim buttons to adjust gyro gain.
Jeti Gyro trim (2 min 20 sec)
Bob1 6s with Spirit Pro.
Bob 2 with Spirit Pro.
Bob 3 waiting on Spirit Pro.
Jeti DS-16. Whovian.
Necroscope is offline        Reply With Quote Quick reply to this message
Old 09-19-2017, 03:43 PM   #10 (permalink)
@necroscope
I made those videos thinking there was no others like it Serves me right for not looking first.
Anyways i think it gives another point of view which hopefully helps someone. In any case i was amazed to see how similar their setup was to mine down to him referring to banks instead of "setup" as the MSH Brain fbl calls it.
Thanks for posting those though i am sure this thread should help someone going forward setting up a fbl controller with the Jeti system
Old 09-19-2017, 11:17 PM   #11 (permalink)
Originally Posted by Chippie13 View Post
@necroscope
I have found it useful to watch different videos relating to the same subject with Jeti, some time you will see someone do something a little different and this can help you earn the Jeti system a bit better.
Well thats been my experience anyway.
Like setting up trim buttons to adjust gyro gains, or putting your gyro on a curve and using a rotational nob to make adjustment for example.
I just like trying out different things on a wet winters day and learning more about the system.
Not sure how many people have a Jeti here in New Zealand.
Oh on a side not, sorry about the Rugby.
Old 09-20-2017, 09:58 AM   #12 (permalink)
This is the only video I needed to learn how to set up my first jeti
MSH USA - MSH BRAIN - HOBBYWING - XNOVA - XPERT - PULSE
Colin Broughton is offline        Reply With Quote Quick reply to this message
Old 09-20-2017, 10:18 AM   #13 (permalink)
https://youtu.be/CZnsAubpkVg
Yup, thats what I used.
Human Verification
