Jeti Max Current as Displayed Telemetry - HeliFreak
Like Tree1Likes
Old 09-11-2017, 02:39 PM   #1 (permalink)
Default Jeti Max Current as Displayed Telemetry
Is there a way to have a single size displayed telemetry value for the max current?
I can see the max current draw if I use a double size control. That will show the max, min and current amp draw values. I'd love to be able to have a single size control display the max current draw.
I'm currently using a Brain 2 with Scorpion ESC.
GravityJunkie is offline        Reply With Quote Quick reply to this message
Old 09-11-2017, 10:27 PM   #2 (permalink)
Only if the telemetry source reports it as an independent value. JLog for example reports Imot Max. But in your case I don’t think either the Tribunus or the Brain report this way.
A\ziz - Citizen 672
Minicopter Diabolo 700 Black, Minicopter Triabolo 700 Black, Minicopter Diabolo 600, Minicopter Diabolo 550, Henseleit TDR Mark II, Henseleit TDR
Jeti DS24
aziz76 is offline        Reply With Quote Quick reply to this message
Old 09-12-2017, 10:41 AM   #3 (permalink)
They don't. Which is why I asking/hoping for a possible way to do this.
In reality, I had my fingers crossed that Tero had a LUA app that does this already. If not, I might go and try to write one myself.
Old 09-13-2017, 03:18 AM   #4 (permalink)
If you use a Unisens-E, you can connect an additional signal wire to the sensor and get the max value instead of the current value transmitted if the signal wire is active.
https://www.sm-modellbau.de/UniSens-E-und-Zubehoer
english manual: http://www.f5b.co.uk/wp-content/uplo...13-english.pdf
Walkera 4G6 2S Flybarless µBrain
Align T-Rex 250 SE Flybarless Microbeast
Oxy 3 Spirit Pro
W.W. is offline        Reply With Quote Quick reply to this message
Old 09-14-2017, 01:20 PM   #5 (permalink)
I guess this would be relative easy to achieve by LUA script.
dkpodder is offline        Reply With Quote Quick reply to this message
Old 09-15-2017, 01:46 AM   #6 (permalink)
Sure Lua, but ds 14 and ds 16 don't have much head room for Lua.
And running a Lua app for this Dno.
Why couldn't this be in the stock jeti firmware?
So many options to set the telemetry but no option to display the max for a sensor/telemetry item , hell they could even make max for the flight or with moving window, a delayed activation, etc....
zomaar is offline        Reply With Quote Quick reply to this message
Old 09-15-2017, 02:46 AM   #7 (permalink)
This isn't a fix for your problem but a possible work-around. You could add a second double sized current display on another page of the telemetry display. Max current only really needs to be seen after the flight so putting it on another page should work ok.
Alternatively you could use the Jeti log graphing facility to see the same thing.
Otherwise, LUA may currently be the only way.
Mark
So many heli's, so little time.
Crashalotjoe is online now        Reply With Quote Quick reply to this message
Old 09-15-2017, 05:56 AM   #8 (permalink)
Do you want the telemetry-window as small or big? Let’s make it for you
Woops. Looks like you like small window. Ok.
TeroS is online now        Reply With Quote Quick reply to this message
Old 09-15-2017, 07:12 AM   #9 (permalink)
As a LUA app it would be useful for it to speak the new value anytime the max is exceeded.
Old 09-15-2017, 08:29 AM   #10 (permalink)
There you go https://www.rc-thoughts.com/2017/09/...lay-lua-added/
RC-Thoughts.com - TeroS formerly known as CP-Geek
Old 09-15-2017, 02:00 PM   #11 (permalink)
Tero, you freaking rule. I was going to look into attempting to do this tonight. Now, I'll load it on my TX and see how it works.
I wanted my main screen to be filled with things I want to review every flight, either data before, after or during a flight. On my main, I have timer, mah consumed, current esc temp, rx voltage, pack voltage and now max current. It gives me all the data I'd like to see without having to change screens (cause I'm lazy). Max current allows me to see how much headroom I have on the ESC and/or how heavy I was on the collective.
Love the flexibility of this Jeti.
Old 09-16-2017, 05:57 AM   #12 (permalink)
I was wondering why you wanted max current
But now that I get it, I like this idea of a screen for after flight review instead of going in the graphs
I already had flightime from throttle lock to throttle lock, I will look into it and Add some more.
TDR-IIto build, Triabolo, 2 X TDR, Kasama Srimok,90e FAIFA, T-Rex 700Dominator, Goblin700, Axon Spirit, Jeti DC-24, Mezon,HW,Kosmik
[B]Extreme Flight MXS 3W110, Ultimate Aeroworks 20-300, DA 170, CB200, Cortex, Q80-8M in a 91" EF Extra ++
Old 09-16-2017, 08:22 PM   #13 (permalink)
I generally turn out mostly back to back flights. I like to get some flights before work or at lunch, so I like to keep it quick. Unless I'm specifically looking for an issue, I prefer not to go into the logs.
I love having the ability to customize the telem data displayed. Especially putting everything I want to see every flight on the main screen. The data on the first screen is everything I want to see on a pre or post flight check for every flight. No unnecessary button clicks. Everything is right there in plain sight. It allows me to track of the things I care about easily.
Its just so freaking awesome to be able to set this radio up EXACTLY how you want it. I'm also glad Tero gives both the code and a compiled version. He gave me a great starting point so that I can code up the screen widget exactly how I want.
Old 09-17-2017, 09:50 AM   #14 (permalink)
Originally Posted by TeroS View Post
Awesome! Would it be possible to also create a LUA for max temp, lowest voltage dip for both the main pack(s) and BEC, and lowest antenna signal strength?
Protos 770 Evoluzione Leggero, Synergy E5, Logo 700/550SX V2, SAB Comet/700 KSE/380 KSE/miniComet; Spirit Pro/Brain2 BT;Jeti DS-24/DX8 Gen 2
Mac sims: neXt, Heli-X, AccuRC, RF8, Phoenix, AeroFly RC7 Ultimate
Citizen 259
curmudgeon is offline        Reply With Quote Quick reply to this message
Old 09-17-2017, 10:16 AM   #15 (permalink)
Max is easy, lowest dip is not. Lowest is pretty much always zero
For the lowest you need logs since lowest is, as said, pretty much always zero. One could of course do a "start counting when" and "stop when" but quite a lot of if-then things in that. I don't see the point?
In my opinion app memory usage would become an issue to think off too since let's face it, these values are already available via log-screens. Especially 14/16 users could spare the Lua-memory to something that gives functions beyond "normal" operation.
Old 09-17-2017, 10:34 AM   #16 (permalink)
Why is the DS24 taking so long to release?
Citizen 259
Old 09-17-2017, 10:39 AM   #17 (permalink)
It's shipping as we speak: https://www.facebook.com/jetimodel/p...36140553100447
"DS-24 day is here. Today we started selling and send out first batch. Next pieces will follow...
Ask your dealer for availability."
Old 09-18-2017, 12:59 PM   #18 (permalink)
I doubt many heli pilots have LUA apps running, so I wouldn't be too worried about hitting the limit of 2 running apps...
I wish LUA apps could see when the user resets the telem data. Or it would be great if the min/max telem values that are on the sensor actually worked correctly.
I have the app showing the current value along with the max. Now it works just like a standard control, however it also displays the max value. It can either be a single or double size. If its double, it shows 2 sensors with current values and max. If its a single, it shows one value with both the current and max value. All I need for me to be 100% happy is have it clear like the other telem boxes.
Old 10-02-2017, 10:35 PM   #19 (permalink)
Finally took the time to finish up the app. Thanks Tero for providing me the basics of Telemetry sensors.
The new control shows both the current and max telemetry values (shows two values if double size). The max values reset after unplugging in a pack and plugging in a new pack (max values are kept while unplugged). Its exactly what I was looking for.
In the pic, the new control is in the lower right.
iscripter likes this.
Old 10-02-2017, 10:36 PM   #20 (permalink)
Or apparently in the upper left with the upside down pic. Dunno why that happened as it looks correct in my album. Oh well...
Human Verification
