Old 09-23-2017, 05:00 PM   #1 (permalink)
Default Gyro Setting Screen
Hi,
I have been having a play with the jeti tonight on the BD axon, and I have been setting up the bank switching.
So on the photo attached, adjusting the number on the far left (-65%) for each switch position changes the gain value in the axon, which is exactly what I want.
However, can anyone tell me what the two bits in the red bubble do? I cant immediately see a need for them. The manual is not clear on page 97
Kr
Craig
__________________________________________________ ___________________
Trex 700x, Goblin 570 KSE, Goblin 700 KSE
DS-16
cjm180 is offline        Reply With Quote Quick reply to this message
Old 09-23-2017, 07:34 PM   #2 (permalink)
Basically it is an option to assign a fine tuning control to adjust the value programmed that you select by switch. Typically you would assign a knob or slider for fine tuning. So say you have a 3 position switch with gains set to 20, 40, 60. Setting the tune value to 10 enables+-10% offset which then allows you to tune and cover the area between switch settings via a secondary slider, knob, or switch.
Most folks tuning a flight control won't use this feature.
Team Only Fine Helis
Flown on Jeti DS-16, Brain2, RCHN #222
MKS Servos, Scorpion Tribunus, MSH P700, Synergy 766, e5s, N5cTT, & 516
Dmaxison is offline        Reply With Quote Quick reply to this message
Old 09-24-2017, 04:48 AM   #3 (permalink)
Thanks Dmax
So if i got this right, say the main switch was set at 40% gain, and i had a knob assigned to under tuning and that knob was set at its mid point, the gain outputted would be 40%?
If i set the number to the right of the tuning know to 10%, it would set +-10% over the entire movement of the knob?
So i could move the knob all the way to the left and i would get a gain of 30, and all the way to the right and get 50?
Kr
Craig
DS-16
Old 09-24-2017, 08:35 PM   #4 (permalink)
Yes, the tuning functions just like trim. Easy to check the output on the servo monitor. 10% setting at the tuning parameter would give you a range of 36 to 44... based on center of 40.
I use a slider on the radio to trim my gyro gain.
KC8CYF is online now        Reply With Quote Quick reply to this message
Old 09-25-2017, 05:54 AM   #5 (permalink)
Originally Posted by cjm180 View Post
Thanks Dmax
Kr
Craig
You got it. To the right of the displayed percentage, is the actual output after trimming (tune input) so navigating to the servo output screen isn't needed. Most of the flight control menus, like throttle curve, pitch curve, gyro, mixing, work like this in Jeti, where the user can assign an input to trim (offset) the output.
Human Verification
