Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > V977/K110/K120
Old 03-12-2018, 02:57 AM   #21 (permalink)
Hey Guys, FPV "quadder" here, I currently use a taranis and am thinking about using it for my soon to arrive k110 as well. But do you need to have the throttle stick centering as well? That might be a problem going back and forth.
hotdogwater is offline        Reply With Quote Quick reply to this message
Old 03-13-2018, 04:02 AM   #22 (permalink)
Normal mode has zero throttle at zero stick, hover just above half stick, so may be easier for you to get started.
However once you want to move onto anything more advanced than forward flight you'll want to get used to an "Idle up" set-up. Hovering would still be slightly above centre in Idle up, but if you drop throttle to zero you slam into the ground...
Old 03-17-2018, 11:11 PM   #23 (permalink)
I understand 3D/6G is channel 5. Is it as simple as assigning a value of 75 for 6G and a value of 25 for 3D?
natedg200202 is offline        Reply With Quote Quick reply to this message
Old 03-18-2018, 07:15 AM   #24 (permalink)
Originally Posted by natedg200202 View Post
I understand 3D/6G is channel 5. Is it as simple as assigning a value of 75 for 6G and a value of 25 for 3D? ...
Yes, (but you have the numbers bassackwards).
For radios that go from 0 to 100, its 75% (or anything above 50) for 3D and 25% (or anything below 50) for 6G.
Note that I am on a Taranis, (which goes from -100 to +100). I use +75 for 3D and -75 for 6G.
ridge-runner is online now        Reply With Quote Quick reply to this message
Old 03-22-2018, 10:24 AM   #25 (permalink)
Thanks so much. I donít fully understand but I used your numbers and now my 6G / 3D switch is working. By the way, opentx is awesome. Iím only a week into this but already have a really nice model file going for my two birds. Iím down to one last wish list item, which is setting up the potentiometers to adjust expo on the fly. If anyone knows of a good instructional please pass along.
Old 03-23-2018, 10:43 AM   #26 (permalink)
... setting up the potentiometers to adjust expo on the fly. If anyone knows of a good instructional please pass along. ...
I can help. Which radio do you have and which version of OpenTX are you running?
Old 03-23-2018, 02:21 PM   #27 (permalink)
Default Expo-on-a-Pot
Here is one way to setup Cyclic Expo-on-a-potentiometer (S2); it uses three INPUTs, one GLOBAL VARIABLE, and one SPECIAL FUNCTION (screenshots are from the X9DP simulator running OTX 2.2.1):
  • INPUT IExpo: Create a new INPUT with name = "Expo", Source = S2 (Right side potentiometer), with weight and offset defining the desired range of expo values. This example uses WEIGHT and OFFSET both equal to 40. As the S2 potentiometer is moved clockwise from minimum to maximum positions, the value varies proportionally from 0 to 80.
  • SPECIAL FUNCTION: Create a new SPECIAL FUNCTION that adjusts GLOBAL VARIABLE GV1 using the IExpo INPUT as the adjustment source. The activation switch is the special value: "ON".
  • INPUTs IAil and IEle: Edit the IAil and IEle INPUTs and set the Curve to be Expo and value to GV1. (To change the value from a number to a GV, press and hold the ENTER button.) As the S2 potentiometer is moved clockwise from minimum to maximum positions, the shape of the plotted graph on the right varies proportionally from no expo to maximum = 80.
  • INPUTs: Once the above steps are completed, the INPUTS setup screen should look something like this:
  • GLOBAL VARIABLE: No need to do anything on this page. Just note that as the S2 potentiometer is moved clockwise from minimum to maximum positions, the chosen GLOBAL VARIABLE (GV1) value varies through the range defined by IExpo (from 0 to 80).
Hope this helps!
ID:	740919   Click image for larger version
ID:	740920   Click image for larger version
ID:	740921   Click image for larger version
ID:	740922   Click image for larger version
Old 03-23-2018, 08:43 PM   #28 (permalink)
It does help. Iíll start experimenting this weekend. Iím using a new Horus X10, with opentx-x10-2.2.1.
Old 09-11-2018, 08:35 AM   #29 (permalink)
I think this is the latest and greatest module.
https://www.banggood.com/IRangeX-IRX...SABEgJMyfD_BwE
I found a good video that describes it. If setup right you don't have to use the little yellow switch. You can change settings with the radio. This is something I could not find info on very easy.
iRangeX IRX4 Plus STM32 4 IN 1 Multiprotocol module for transmitter (14 min 1 sec)
There is a link on the bang good page with a spreadsheet that lists all the models and protocols.
jevs is offline        Reply With Quote Quick reply to this message
Human Verification
