Go Back   HeliFreak > R/C Helicopters > Rotor Blades
Rotor Blades R/C Helicopter Rotor Blade Discussions
Old 09-28-2017, 03:26 PM   #1 (permalink)
Default edge and edge-se whats the difference
anyone know what the difference is between
edge and edge se blades ? both sets I have are fbl versions.
also anyone know which blades on the market are known to be softer (more flexible). I am flying a ridged head want to try some more flexible blades as I have vibration problem.
thanks
chris-green is offline        Reply With Quote Quick reply to this message
Old 09-28-2017, 04:10 PM   #2 (permalink)
EDGE SE 693/713 vs EDGE FBL 693/713 differ in weight and CG.
SEs are about 10g heavier with the CG 30mm further inboard.
EDGE SE 603 vs EDGE FBL 603 only differ in CG.
SEs have their CG about 40mm further inboard.
Jonas
LOGO 700 - LOGO 690 SX - Protos 380 Evoluzione - Oblivion 300 - OXY2
AccuRC 2.0 Developer | Oblivion Chief Destructor
YouTube - AccuRC - Oblivion
Johnny31297 is online now        Reply With Quote Quick reply to this message
Old 09-28-2017, 11:37 PM   #3 (permalink)
CHC Benefactor
DH blades are softer. They're used on the Triabolo to partner with its rigid head.
Raptorapture is online now        Reply With Quote Quick reply to this message
Old 09-29-2017, 12:13 AM   #4 (permalink)
Many thanks guys
Best I get some dh blades for my diabolo 600
It flys ok on the edge blades but gets the shakes spooled up on the ground, and shows high vibrations in the logs.
Old 09-29-2017, 12:21 AM   #5 (permalink)
How does the difference in cg affect how they fly .
Btw Johnny thanks for all the great stuff in accurc 👍
Old 09-29-2017, 03:05 AM   #6 (permalink)
CG further out makes them more stable but less agile. Obviously vice versa for CG further in.
Gob 700 Speed | Gob 770 Comp | Gob 630 Comp | Trex 700X | KDS Agile 7.2 | Compass 7HV U | Trex 600Pro (626 stretch) | Kasama Dune 600 | KDS Chase 360 | Devil 420 | XLPower 520
Grumpy_Old_Man is online now        Reply With Quote Quick reply to this message
Old 09-29-2017, 03:53 AM   #7 (permalink)
CHC Benefactor
Sounds like they increased agility and then compensated for reduced stability by adding more weight. Net result more agility without loss of stability, just a bit more load on the drivetrain.
Old 09-29-2017, 09:52 AM   #8 (permalink)
No, load on the drivetrain remains identical for the same AOA as the molds are exactly identical. If at all the load decreases a bit as you need less cyclic.
Jonas
Old 09-29-2017, 11:22 AM   #9 (permalink)
CHC Benefactor
Not sure about that.
Old 09-29-2017, 11:28 AM   #10 (permalink)
I am
Jonas
Old 09-29-2017, 12:03 PM   #11 (permalink)
Default softer blades
any other main blades than dh that are suited to ridged head heli's ?
Old 09-29-2017, 12:05 PM   #12 (permalink)
All blades from Fun-Key are similarly stiff.
Vibrations should not originate from stiff blades.
Jonas
Old 09-29-2017, 12:40 PM   #13 (permalink)
I read that stiff blades on a ridged head could trigger resonant vibes to go back through the heli rather then absorbed by the dampers.
my diabolo 600 got the shakes on the ground but is ok in the air with a high head gain, on a mini vbar and vcontrol @1400rpm head gain 95.
turn head gain down even a little and the heli shake in the air too
vibe logs show high vibrations, but nothing on the bench blades off. blades(edge)well balanced
Old 09-29-2017, 02:25 PM   #14 (permalink)
CHC Benefactor
I am
You'll have to forgive my lack of education. That and I forgot about the impact of CG
Old 09-30-2017, 12:23 AM   #15 (permalink)
CHC Benefactor
NHP's - The DH's were for speed. NHP's are for the regular Triabolo and also used in the Diabolo.
Old 09-30-2017, 12:32 AM   #16 (permalink)
CHC Benefactor
A bit of hunting around - here's something that suggests non SE's are softer but you never know that CG might bite again
https://www.helifreak.com/showthread...42#post5413638
Old 09-30-2017, 12:51 PM   #17 (permalink)
Riiiiight, totally forgot about that! EDGE FBL 693 and 713 utilize only one layer of prepreg per blade skin. Corresponding EDGE SE blades have two layers each. Increases weight and rigidity.
Jonas
Old 09-30-2017, 12:54 PM   #18 (permalink)
many thanks for the info, I checked them, and the se's are quite a bit stiffer the non se's.
I will give the softer ones a go before buying any thing else.
as for the nhp blades anyone which are the softer one razor pro or aggressor ??
Human Verification
