P380 power train... - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > MSH Protos > Protos 380
Like Tree1Likes
  • 1 Post By Colin Broughton
Old 10-06-2017, 10:06 AM   #1 (permalink)
Default P380 power train...
Hi,
I'm going to outfit a Protos 380, and wanted to get some opinions on components.
I have a KDE XF500 925kV, YGE 60, and Gens Ace 2200 packs that I would like to use, but those batteries appear from the specs to be on the heavier end. Will those COG well? There appears to be room to adjust balance with the pack, but will this power combo increase the disk loading significantly? (They appear to be about as light as you can run on a Goblin 380 without adding lead.)
What motor/esc/battery combo(s) are you using that weigh less than mine will?
Another question. Is there a weight penalty for the beautiful Evo boom, or is it the same or lighter than the round one?
Thanks!
AMA 373608
Citizen #97
K2Freak is offline        Reply With Quote Quick reply to this message
Old 10-06-2017, 01:58 PM   #2 (permalink)
You probably want to stick to an 1800 pack for both cg and disk load.
Common setup is hw60, xnova 890kv, 1800 pack. Oodles of power and above avg flight time already imo.
HAPPY FLYING!
http://www.baysidercclub.com | AMA#912659 | RCHN #830
Jeti DS14 | Brain2
Protos Max V2 | Protos 380
canbarelyhover is offline        Reply With Quote Quick reply to this message
Old 10-06-2017, 02:14 PM   #3 (permalink)
As stated in the comment above that's the most common power plant setup.
As for the evo boom I never weighed the parts difference but if any I hardly doubt it's a few grams one way or the other. Nice thing about the p380 is it already comes in very light so it's of no concern at all thankfully
Team MSH USA - Cyclone Blades
MSH Prtos 380 Brain 2
MSH Prtos Max V2 Brain
vtown nick is offline        Reply With Quote Quick reply to this message
Old 10-08-2017, 09:21 AM   #4 (permalink)
My protos 380 is stretched to 420mm running the 2200mah gens ace packs and it is slightly nose heavy with the pack as far back as possible with the front canopy mounts removed so I can stretch the canopy up higher if that makes sence.
The 1800s I have no issue at all with getting cg in both 380 or 420 tho. I was just trying to add alittle weight to the 420 cause it's ridiculously floaty
B@@MER likes this.
MSH USA - MSH BRAIN - HOBBYWING - XNOVA - XPERT - PULSE
Colin Broughton is online now        Reply With Quote Quick reply to this message
Old 10-08-2017, 09:49 AM   #5 (permalink)
Thanks. I just want to be sure that I have to buy new packs. The 2200 is only ~40 grams heavier than most of the 1800, but it sounds like it's on the edge of feasibility in this case.
AMA 373608
Citizen #97
Old 10-25-2017, 11:10 AM   #6 (permalink)
You are all correct once again. The packs that I ended up with in the trade are Velocity 1900mAh and they weigh 305g each. If I mount them on their sides, I can JUST get the COG correct and the canopy on - right on the edge. Thanks for the good advice.
They are not my favorite packs. IR is about 4-4.5 per cell, and the factory solder job on the EC5 connectors was a joke. I could almost break them off by hand, and not 1 of the 4 bullets had even a hint of solder down in the cup. Just a fine line around the bullet perimeter when the wire meets it. I soldered on EC3 and fixed that up, but it was not a happy looking factory job.
AMA 373608
Citizen #97
Human Verification
