Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters > Scale Projects <790
Scale Projects <790 Scale Projects <790 Discussion
Old 10-09-2017, 04:59 PM   #1 (permalink)
Default Roban AS-350 Superscale -Motor Fitment
Last night I purchased an AS350 Superscale helicopter from RC Aerodyne and have my first question. I currently have an Align 800MX 530kv motor which measures ~56mm in diameter and I would like to know if it will fit the mechanics/fuselage. The shaft diameter is 6mm and I will be using it with a Castle 120V ESC.
mecha1000 is offline        Reply With Quote Quick reply to this message
Old 10-14-2017, 10:48 AM   #2 (permalink)
Yes, with almost no room to spare. This is what I used on my roban bell 429.
jazsop is offline        Reply With Quote Quick reply to this message
Old 10-15-2017, 03:10 PM   #3 (permalink)
Thank you for the reply. Should have the helicopter here this week!
Old 10-16-2017, 08:27 AM   #4 (permalink)
What flybarless are you going to use
Old 10-22-2017, 05:28 PM   #5 (permalink)
Sorry for the late reply. I am using a BD 3SX. I have no experience with it but will eventually figure it out :-). I received the helicopter this week. Will post a picture here today or tomorrow.
BTW, I am looking at buying a 440kv motor vs the 520kv that I currently have. I have read that it will be a better match for the low headspeed that I plan to run. I would like to run ~1350rpm.
Old 10-23-2017, 03:49 AM   #6 (permalink)
Does this run 700mm blades ? If 3x 700mm, I would think that you may want to go slower than 1350rpm - maybe 1250rpm. I run 1350rpm on my old Long Ranger (2x 710mm) and it flies very well.
The only reason to run a higher speed is if tail authority was lacking and you couldn't fix it with larger/longer/wider tail blades.
Also, you don't need a 800 sized motor for scale. At a guess the heli might weigh around 20lbs, so 20 x 60W/lb (on the high side for scale FF) is only 1200W for FF, maybe 1500W for hovering, and around 2500W to deal with an Oh $hit moment (and these numbers are quite high for scale - generally closer to 50W/lb), so a 4035 motor is plenty - I run a XNova 4035 300kV in my EC-145 (4x 820mm), and it has plenty of power.
Likewise the ESC - I use a Edge 80HV for my EC-145, and it only ever sees peaks of around 35-40W maximum for short spikes.
Colin
Vario Long Ranger 700e
Seahawk 600
UH-1N 500
Baumann EC-145 800+ (coming soon )
Andy01 is offline        Reply With Quote Quick reply to this message
Old 10-23-2017, 07:50 AM   #7 (permalink)
Default AS-350
Colin, thank you for the advise...
Yes, I will be running 3x 700mm blades. They are the stock blades that come with the heli. I started looking into better tail blades as I have read that the oem are not the best for low head speed.
The motor that I am looking at I can get for less than $100. I looked the one you suggest and it is a lot more $$$. I have a castle 120V which I will use to govern the speed down to the ~1250rpm that you recommend.
what flight time do you get on your EC-135?
Regards
Old 10-23-2017, 02:27 PM   #8 (permalink)
Default Roban Sheriff
Here is the photo....this heli is pretty big!!!
sorry for the setting, was home for lunch and no time to make it pretty .
Old 10-24-2017, 08:50 PM   #9 (permalink)
I'm dying to get the medevac version of the AS350, but it looks like RC Aerodyne isn't ordering any new kits. It looks like nearly 50% of their kits have been out of stock for quite some time, with no new ones or replenishment in sight.
Enjoy that ship. It's a beautiful bird.
WhopperChopper is offline        Reply With Quote Quick reply to this message
Old 12-24-2017, 10:02 AM   #10 (permalink)
Default Battery
Hello,
I am in the process of buying a few batteries for my Roban AS350 tri-blade 700 size heli. I have read that the average amps on 12S is ~30-35amps with peaks of ~42amps. If i buy 6S 6600mah 10C batteries for a 12S setup, in theory i will be "okay" since normal amperage requirement is much less than the standard discharge capacity of the battery (6.6 x 10=66amps).
What do you guys think?
Old 12-24-2017, 03:58 PM   #11 (permalink)
While your math is correct, I would not push it to that extreme. I don't know where you found those 10C batteries, but if it were me I would get 30C.
getsuyoubi is offline        Reply With Quote Quick reply to this message
Old 12-24-2017, 06:19 PM   #12 (permalink)
Hobbyking has 10C batteries....i was aiming to increase amperage and sacrifice the discharge rate which does not seem to be a requirement for scale flying...
