Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters > Heads and Rotor Blades
Heads and Rotor Blades Heads and Rotor Blades Discussion
Like Tree1Likes
  • 1 Post By Trooper7
Old 03-12-2019, 11:11 PM   #1 (permalink)
Default 600 Size 4 blade Rotor Head Setup
Where can I buy a 4 Blade Head for a EC145 scale build? Also, i would like to learn how to install the four bladed head. Any tips appreciated. Thanks.
Morad67 is offline        Reply With Quote Quick reply to this message
Old 03-12-2019, 11:23 PM   #2 (permalink)
Default Multi Blade Rotor Heads
Where can I buy a four blade rotor head for my 600 EC145 scale build? Also, I would need a 3 blade and a 5 bladed head later for my AS350 and MD500E scale builds. I would also appreciate any tips or where I should go to find out more setup and build information on the multi blade rotor heads. I have been building and flying helis for 7 years, but never built or setup a multi bladed heli.
Old 03-13-2019, 07:49 AM   #3 (permalink)
Have a look here:
https://www.double-cats.com/
https://www.sk-rotorkopf.de/
https://www.vario-helicopter.biz/us1/
getsuyoubi is offline        Reply With Quote Quick reply to this message
Old 03-14-2019, 12:23 AM   #4 (permalink)
Thank you.
Old 03-24-2019, 08:53 PM   #5 (permalink)
Default Multi Blade Main Rotor Heads
I would like to know where multi blade heads are sold? I see one or two outlets but often times they are out of stock. Where can I find these multblades heads? I need a few sets for my 600 AS350, EC 145 and MD500 helis. Thanks
Old 03-24-2019, 09:19 PM   #6 (permalink)
Check out Double Cats: https://www.double-cats.com
And Motion RC: https://www.motionrc.com/pages/searc...e?q=Rotor+head
450 Twinrexx HUP Retriever
500 size UH-1C Huey, AH-6 Little Bird, AH-64 Apache, HO3S-1, UH-34D, 3D printed Gazelle
600 size OH-58A Kiowa, SH-3 Sea King
700 AH-1W Super Cobra, MH-60 Blackhawk
EnstromPilot is online now        Reply With Quote Quick reply to this message
Old 03-25-2019, 01:04 AM   #7 (permalink)
HF Scale Support
Hi:
You can check with [email protected] to see if Phil can help you out. They carried 3,4, and 5 blade heads, drivers, and swash plates. Hope you find what you need.
Don
Old 03-26-2019, 01:41 AM   #8 (permalink)
https://scaleflying.de/?cat=c145_Rot...d-600size.html
When the wife asks "How many helicopters do you need?"
The answer is always "Just one more!"
BlackTitanium is offline        Reply With Quote Quick reply to this message
Old 07-10-2019, 04:30 PM   #9 (permalink)
Spinblades.com
Roberto Melo is offline        Reply With Quote Quick reply to this message
Old 07-11-2019, 04:20 AM   #10 (permalink)
Originally Posted by Roberto Melo View Post
Spinblades.com
I wasn't aware that Spinblades started selling heads as well as blades - I must check them out.
Colin
Vario Long Ranger 700e
Seahawk 600
UH-1N 500
Baumann EC-145 800+ (coming soon )
Andy01 is offline        Reply With Quote Quick reply to this message
Old 07-12-2019, 03:20 AM   #11 (permalink)
I have a Double Cats 5 Blade head 700 size available.
Send PM if interested.
Cheers
1:5 BK-117 - 1:4 MD500E - 700 MD500E - 700 B222
- TREX 600ESP
Trooper7 is offline        Reply With Quote Quick reply to this message
Old 07-12-2019, 04:09 AM   #12 (permalink)
Two key items for multiblades
(forgive me for covering things you may already know)
PHASING:
Simply stated, you want your blades to reach max deflection 90deg before the requested resultant force.
On a two blade set up the control links are rigged mechanically at 90deg to the blades. For example, if the swash is tipped straight forward, when the link rods get to the 12 o'clock and 6 o'clock positions the blades will be at the 3 and 9 positions which facilitates the phenomenon of phase lag where the force applied comes out 90 degrees later (which is why for forward flight the blades are at max pitch at the 3 o'clock position on a ClockWise rotating rotor disc)
For a multiblade head you have two choices:
1) Keep the link rods oriented straight up down between the swash and the grip links and use FBL phasing adjustment to achieve the correct phasing (there is typically an option in their programming to do this). Example, for forward flight you may need to tell the FBL to tilt the swash 28deg off center, i.e. it may be tipped toward the approximate 1o'clock position in order to get the blades to the 90 deg phasing
or
2) turn the upper swash (which angles the links) until the blades achieve the 90 deg difference relative to the lower swash angle. ie with the swash tipped straight forward, turn the upper swash until the blade at the 3 o'clock position (like in the example above) reaches max pitch.
In some case, often with the 5 blades, there simply isn't room to angle the links without running into issues with the links binding at certain swash angles and collective inputs.
Option No.1 would be preferred for more direct link rod force to the grip and avoiding the aforementioned binding of the linkages that may come from using No.2
There are some heads that have link rods called "J arms" that have this adjustment built in so you don't need to do either. The swash operates as if it was a two blade system. I have one on my MD500 from www.scaleflying.de and it works great.
The other key item is BALANCE.
As long as you have a good quality head and blades you should have close CG's on your blades and then only need to balance them to each other. I use a digital scale that gets them within .01 grams and have had excellent results.
Hope that all made sense.
It sounds more complex than it is
TED25 likes this.
- TREX 600ESP
