Old 10-14-2017, 11:43 AM   #1 (permalink)
Default Read/Interpret RPM--Kosmik log
My Data Explorer shows 170 -to- 200 in the "rpm/1 min" column.
My head speed should actually be around 1280-1410 (700 heli)--with optical mirror tach (if used correctly).
In K-Konfig I have "14 poles" and 9.43 gear ratio entered (Pyro 750-45, Soxos with 16 tth pinion)
Everything is current firmware (w/in 2 days)
Is anything right with this RPM log?
Thanks very much--I don't mind converting, if someone explains how
zr1100 is offline        Reply With Quote Quick reply to this message
Old 10-18-2017, 10:46 AM   #2 (permalink)
Sounds like you have a gear ratio or pole count set in data explorer. If you look at the raw log file in a text viewer does it have the correct RPM in the associated column?
Richard Zappe
Team Kontronik USA Team minicopter
Diabolo Kosmik 200, Pyro 750 - 50 Comp, Diabolo S #RZ, Diabolo 550 Jive Pro 120, Pyro 650-103 Comp
Wh1teAfr1can is offline        Reply With Quote Quick reply to this message
Old 10-18-2017, 11:28 PM   #3 (permalink)
The 'table" rpm column in DataExplorer gives the same figures as on the "graph" rpm (170-200).
Did you mean some other type of text editor?
My poles and gear ratio are in the K-Konfig program, and have supposedly been programmed into the ESC.
Does the DataExplorer program itself have a place to enter gear ratio, etc.?
Old 10-18-2017, 11:44 PM   #4 (permalink)
OK--found a text editor, and the rpm column does show normal-looking rpm numbers --ie. 1250--1460, etc.
Can the DataExplorer be configured to show those rpm numbers?
Thanks again
Old 10-19-2017, 10:19 AM   #5 (permalink)
Thanks again
ill look at it later tonight but there should be an option in data explorer to add a gear ratio or pole count that you need to disable. Its meant for people who don't configure rpm settings in k-konfig.
Richard Zappe
Old 10-19-2017, 11:25 AM   #6 (permalink)
Thanks again
Human Verification
