Looking for rubber padding on side of Gaui - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X3
X3 Discussion and support for the Gaui X3
Like Tree1Likes
  • 1 Post By chuteopn
Old 10-21-2017, 06:33 PM   #1 (permalink)
Default Looking for rubber padding on side of Gaui
In order to run the motor wires out the side instead of over the top. Is there a place I can purchase it, to protect the wires from getting cut on the side of the carbon fiber? Like was done on the pic above.
jason
jasond1979 is offline        Reply With Quote Quick reply to this message
Old 10-21-2017, 08:06 PM   #2 (permalink)
McMaster Carr will have what you are looking for.
Paul
Agile 5.5 - Q 4125-1100, YEP 120, Brain2 HD FBL / Outrage 550 - HK4020-1390, Edge 120, Brain2 HD
Rave Ballistic FSO - Q 4530-500, Edge 160HV, Brain2 HD / Protos Max V2 - MSH 4530-500, Edge 160HV, Brain2 HD
pctomlin is offline        Reply With Quote Quick reply to this message
Old 10-21-2017, 08:35 PM   #3 (permalink)
https://www.amainhobbies.com/fourmos...rq1748/p259597
jasond1979 likes this.
180CFX (uIkon), 300X (2208, Ikon), 300X (2213, Ikon), X3 Brain2, X3 stretch Brain2, X5 Brain2, DX9, DPL8 w/ Bump
chuteopn is offline        Reply With Quote Quick reply to this message
Old 10-21-2017, 10:43 PM   #4 (permalink)
Thanks guys, save my wiring for sure!
jason
Old 10-21-2017, 11:12 PM   #5 (permalink)
I wired mine this way. ...so my motor wires are between the battery mount plate and ESC plate and my battery wires hook up right in front...
fits into the canopy better for me...
ID:	726661   Click image for larger version
ID:	726662   Click image for larger version
what can I say....I'm "that guy"
Voted by my Club as: "Most Likely To Crash"
PTFlyer is offline        Reply With Quote Quick reply to this message
Old 10-22-2017, 05:01 PM   #6 (permalink)
PTFlyer,
I see from the pictures you have magnetic canopy mounts, what are you using and were did you get them from? I've been wanting to do that for some time, just didn't want to buy parts that I didn't know would work or not.
KDS Agile 5.5, Ikon, KST, KDE motor/Gaui X4ii, BK servos, Brain / Gaui X3, Ikon, KST, Scorpion 1580Kv
Frsky Taranis plus
PhoenixRC upgraded to wireless
Larryu is offline        Reply With Quote Quick reply to this message
Old 10-22-2017, 09:22 PM   #7 (permalink)
Those magnetic canopy mounts are from a MSH Protos.
Paul
Old 10-23-2017, 01:12 PM   #8 (permalink)
that's right....I used some nylon stand offs that I cut to the extra length I need to put the mounts out far enough....I ran the long set screw that comes with the mount through the standoff to tap it....I then used a shorter set screw to screw the two pieces together but leaving enough room to insert another set screw into the other end of the standoff and screwed that into the frame (in case it breaks off in a crash I can hopefully still get the set screws out.)
I had to tap the plastic boom block insert to take the bigger set screw..
the other end that mounts to the canopy I did just like I show in this thread....might help to explain what I wast talking out here as well .....Post #12 (with pictures) https://www.helifreak.com/showthread.php?t=749351
these are the mounts I use for the x3 I use the bigger ones on the g500's
Old 10-27-2017, 06:32 PM   #9 (permalink)
Thank you for the info I've got them ordered.
Frsky Taranis plus
Insurance
Human Verification
