To Loctite or not to Loctite? - HeliFreak
Go Back   HeliFreak > R/C Helicopters > Helicopter Safety
Helicopter Safety R/C Helicopter Safety
Like Tree1Likes
  • 1 Post By ic-racer
Old 10-26-2017, 05:59 PM   #1 (permalink)
Default To Loctite or not to Loctite?
Re: To Loctite or not to Loctite?
I am not sure if this is the best place to post this enquiry, but here goes.
I have watched plenty of videos of builders assembling helis and have come to wonder if there is OVERUSE of Loctite?
I appreciate that it is good practice to Loctite the motor into position and to use it on rotating parts like feathering shafts, but is it really needed on every single metal to metal contact?
Any information gratefully received,
Tony
tony#1 is offline        Reply With Quote Quick reply to this message
Old 10-26-2017, 08:35 PM   #2 (permalink)
Not needed if there is a locknut.
Solmanbandit likes this.
HiSky HCP80 & HCP60, Trex-100, Trex-150DFC, Trex-150X, Trex-250, Trex-450L, T-rex 450 SEV2, Trex-500X, Trex-550X. Spirit FBL
ic-racer is offline        Reply With Quote Quick reply to this message
Old 10-26-2017, 09:58 PM   #3 (permalink)
I am not in favor of using so much loctite that you strip every bolt that you try to remove.
Maybe if you never have to rebuild anything it would be good practice.
sseppala is offline        Reply With Quote Quick reply to this message
Old 10-26-2017, 10:12 PM   #4 (permalink)
Small heli's don't vibrate as much and you get away without as much loctite. On big helis, any bolt/screw mating with metal threads should have loctite or you stand a good chance of paying dearly.
IMHO it is not worth the risk, if you think it possibly needs locktite then do it. A club member often forgets to locktite bolts, I have seen some very interesting near crashes and crashes on 600's and 700's from bolts backing out.
Tom
TRM Power
CAUTION - my posts are based on my experiences, yours may be different.
fastflyer20 is offline        Reply With Quote Quick reply to this message
Old 10-26-2017, 10:43 PM   #5 (permalink)
Last weekend I smacked against the building with an Oxy3+...everything from the rotor hub outward was spread over the lawn...
No damage to the tail boom / tail assembly...
But close inspection revealed 4 of the 6 screws that hold the tail assembly to the boom...were loose
Every one had (blue) Loctite..."two fingers tight" makes it easier to loosen
nCPX(2)*mCPX(30)*HCP100S*130X(3)*130X-L(6)*180CFX(12)*270CFX*300X/CFX(4)
330X*450X(4)*470L*GauiX3*nanoQX*180QX*DX9*HF180060*AMA 988253
Old 10-27-2017, 12:16 AM   #6 (permalink)
I'd turn the question around and ask why you wouldn't use Loctite on every screw (into metal)? I've seen too many helis crash due to the builder forgetting to Loctite.
Perhaps on some screws you could get away without it but figuring which screws need it and which dont would be a hit and miss affair at best, why take the chance? As long as you use the blue type, dont over-tighten and use quality wrenches they will come out ok when you need to do maintenance.
Gob 700 Speed | Gob 770 Comp | Gob 630 Comp | Trex 700X | KDS Agile 7.2 | Compass 7HV U | Trex 600Pro (626 stretch) | Kasama Dune 600 | KDS Chase 360 | Devil 420 | XLPower 520
Grumpy_Old_Man is online now        Reply With Quote Quick reply to this message
Old 10-27-2017, 04:49 AM   #7 (permalink)
Many thanks to all who have responded. As one grumpy old man to another I shall take the advice offered above and Loctite all metal to metal.
Old 10-27-2017, 06:54 AM   #8 (permalink)
Originally Posted by fastflyer20 View Post
Small heli's don't vibrate as much and you get away without as much loctite. On big helis, any bolt/screw mating with metal threads should have loctite or you stand a good chance of pay dearly.
I'm thinking the amplitude of the vibration would be less (less mass), but the frequency would be higher since things (blades, gears, motors, etc.) are rotating much faster.
Old 10-27-2017, 06:56 AM   #9 (permalink)
Sorry, duplicate.
Old 10-30-2017, 10:30 PM   #10 (permalink)
There is no hit or miss. If there is a lock nut present or screwing into plastic, you do not use loctite. If you screwing metal into metal with no lock nut, then you apply a minimal amount of loctite. Typically blue is sufficient.
Trex 700 DFC Ikon 2 / SAB Goblin 500 Sport Ikon 2 / HD Cell 500 Ikon 2 / Trex 500 - AH-1W Cobra scale
Solmanbandit is offline        Reply With Quote Quick reply to this message
Old 10-31-2017, 06:17 AM   #11 (permalink)
Which is what I said if you had quoted the whole post.
Old 12-03-2017, 03:35 AM   #12 (permalink)
Locknuts aren't actually that great at preventing unthreading due to vibrations.
While this video is a marketing piece for locking hardware, the Junker-Vibration test is valid, and the results are accurate.
https://youtu.be/IKwWu2w1gGk?t=1m30s
Various locking methods are tested.
Suitable thread locking compound is superior, and if the correct release torques are selected for the application, there's no reason for them to become excessively difficult to undo.
Lihp is offline        Reply With Quote Quick reply to this message
Old 12-24-2017, 01:51 AM   #13 (permalink)
Just use a tiny amount and use blue. Use a toothpick and just put on enough to to coat the first 3 or so threads. Locktight should be used all the time on any size heli.
MSH Protos 770 EVO, MSH Protos 700, Protos EVO 380, Trex 700X--Trex 700DFC-----Goblin 570-------Goblin 380
Mikado Vcontrol__ Scorpion Tribunus and Motors.
robertvizzo is online now        Reply With Quote Quick reply to this message
Human Verification
