Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > V977/K110/K120
Like Tree39Likes
Old 08-22-2020, 11:21 AM   #161 (permalink)
You don't happen to have throttle hold on do you?
Have you selected the correct flight mode that you programmed with the linear curve?
Don't quote me to answer please, just add a comment.
Andy from Sandy is offline        Reply With Quote Quick reply to this message
Old 08-22-2020, 11:56 AM   #162 (permalink)
No throttle hold and throttle output is verified to be at 100% (2012 us) through the transmitter screen (output monitor).
I did change the max throttle to 1980 within BLHeli Suite. So my guess is that I'm not hitting that threshold and therefore the ESC doesn't recognise that my throttle stick is at 100%. There must be some conversion between the transmitter and the receiver causing the 2012 not to be recognised.
Should I lower this to something way below maximum in BLHeli Suite (e.g. 1200) and then set the range through the transmitter? Is that the purpose of this exercise?
TedAud is offline        Reply With Quote Quick reply to this message
Old 08-23-2020, 04:07 PM   #163 (permalink)
Originally Posted by TedAud View Post
Hi Mikej,
I've tried your instructions but don't get the confirmation beeps other than the usual start up beeps. What I did was turn on the transmitter, using a linear 0-100 throttle curve, move the throttle stick to the highest position, then connect the battery to the ESC (as per usual when flying). I then get the usual startup sequence of beeps, but nothing beyond that.
Any advice would be appreciated.
Also, what's the difference setting the throttle this way to setting the min and max throttle in BLHeli Suite?
Thanks.
You will need to have "Programming by Tx" box ticked. I found that it gave better calibration (more resolution, and more HS) than doing it via the software
Old 08-23-2020, 04:13 PM   #164 (permalink)
Thanks for sharing this guide e92.M3. Have you tried connecting only two wires (ground and signal, without connecting the 5V) for an even cleaner mod? I've seen ESCs that only need ground and signal, so just wondering if that applies to this ESC.
Cheers
Without the red wire you won't have any power going to the Flight Contorller / servos etc. with this ESC, some ESCs for quads etc use only 2 wires - but they generally have separate power for the FC etc.
Old 08-24-2020, 10:25 AM   #165 (permalink)
Thanks Mike. I've managed to flash BLHeli and then remove the wires I soldered as the cable to the receiver (ground and signal only) can be used for programming once BLHeli bootloader is installed (as part of the BLHeli firmware). I power the ESC through the existing battery connector.
Old 08-24-2020, 04:26 PM   #166 (permalink)
That's what I do with most of mine Ted - works a treat. I have left the programming wires on some of them (but I always solder on a short lead with a small plug on the end) purely because the first toolstick that I bought only handled 4-wire comms. I subsequently bought another toolstick that does 4-wire and the servo lead comms.
I've now got about 6 or 7 ESC's using BLHeli - it gave a new life to ESCs that I had given up on due to the lack of a decent Governer.
Have you managed to calibrate your throttle OK?
Old 08-25-2020, 12:48 AM   #167 (permalink)
Unfortunately not. I broke my Arduino (long story!) so have to wait for a new one to arrive in the mail before I can get back into BLHeli to lower the max throttle point. I think 1980 is too high, causing the ESC to not recognise the throttle high point when I power it up. So I can't get into calibration mode at the moment.
On a separate but related matter, what do you guys seek to achieve with the BLHeli tweaks? Is it just to set a fixed head speed so that
collective, cyclic and tail behave more consistently? Any other performance tweaks?
Also, I know that throttle curve and governor % are different. What I'm not clear about is how they interact. Does the governor dictate the maximum allowed head speed, with the throttle % acting as a multiplier? E.g. Governor set to 90% and throttle set to 50% = 45% of max possible motor speed?
Thanks.
Old 09-02-2020, 11:23 AM   #168 (permalink)
Hi Mike
I've reset the PPM Min Throttle and PPM Max Throttle to default values and attempted to calibrate the ESC again. Unfortunately, still no luck.
Mind taking a look at this short video to see where I'm going wrong?
Unsuccessful ESC calibration (0 min 56 sec)
Old 09-02-2020, 03:03 PM   #169 (permalink)
Can you check that you had "Programming by Tx" box ticked when you check the BLHeli config - if not it will ignore the throttle completely, you needed this enabled to calibrate the end points
Old 09-02-2020, 08:01 PM   #170 (permalink)
Hi Mike, yes I did check that and it's definitely ticked.
I presume channel 6 output is irrelevant to this process?
Old 09-05-2020, 03:29 AM   #171 (permalink)
Sorry, I don't know what Channel 6 output is...
I'm stumped now - it has always worked for me - with a little messing about with end points etc. occassionally
Old 09-05-2020, 04:25 AM   #172 (permalink)
No worries Mike. I've just set the min and max to default in BLHeli suite. Thanks.
Old 09-05-2020, 06:35 AM   #173 (permalink)
... attempted to calibrate the ESC again. Unfortunately, still no luck.
Mind taking a look at this short video to see where I'm going wrong? ...
You can't simply power up the heli at full throttle - you need to power up and initialize the FBL/RX before sending the 100% Thr signal to the ESC. This requires powering up the FBL/RX with the ESC signal line disconnected (and the Thr channel from the Tx @0%), and then apply 100% throttle, and then connect the signal line to the ESC. The FBL/RX will not send out any signal to the ESC until it sees 0% from the Tx (and that is why your technique is not working). Its all explained in the following post by BirdBarber...
K110 ESC Calibration and Programming
Here's the pertinant part:
Originally Posted by BirdBarber View Post
-- How to Enter Calibration Mode --
The sequence to calibrate the ESC to match your transmitter's throttle range is:
1 Remove white ESC wire pin from the ESC to receiver plug by lifting the plastic pin retaining tab with a safety pin, or use the modified cable mentioned above.
2.Unplug tail motor wire and REMOVE THE MAIN GEAR for safety.
3 Power on TX, 0% throttle, throttle hold off.
4 Power on V977, wait until it initializes and you can move the servos with the TX stick.
5 ESC should beep every second or so.
6 Raise throttle to 100% - Throttle hold still off
7 Plug in white wire - a double beep will play
8 Wait about 2 seconds and no more, then lower the throttle to 0%.
9 Let it set for a few seconds until it beeps then unplug the heli battery, it should now be calibrated.
To accomplish this, he manually removes the signal wire from the connector, which is kinda fiddly/difficuly - I built myself a custom adapter with an in-line switch on the signal line to make this process much easier.
Hope this helps!
ridge-runner is offline        Reply With Quote Quick reply to this message
Old 09-06-2020, 04:13 AM   #174 (permalink)
Hope this helps! [IMG class=inlineimg]https://www.helifreak.com/images/smilies/icon_biggrin.gif[/IMG]
Thank you! I got both my K110s calibrated now.
Cheers.
Old 05-13-2021, 05:41 PM   #175 (permalink)
Can somebody help me figure out how to connect my arduino nano to the speed controller?
Last week I flashed it with blheli, i soldered the 3 wires and used my arduino uno to flash without any problems, i read so many times on this thread that once you flash it with blheli you can take the three small wires off which I did,
I decided to try and save some weight by soldering the motors wires directly to the esc wires, afterwards I realized I switched two of the wires because the rotor was spinning backwards, I dont want to flip two motors wires, makes a lot more sense to just reverse it in blheli and would be nice to alter other settings as well.
I am trying to connect with my arduino nano, i followed instructions from last page, i connect white wire to d2 pin and ground wire to ground pin. I load up blhelisuite and I select SILABS BLheli Bootloader (4way-if), i have the correct com port selected and click connect, it has no problem connecting to the arduino nano, but once I click read setup it says
"connection to esc #1 failed! please check data- und power-connections to the ESC"
I make sure to connect the battery before trying to connect, it just doesn't want to work
Am i missing a step? Do i need to create a new interface? in make interface tab I chose arduino 4-way interface and flashed it with the MULTI file.
Any help is appreciated
dinsum is offline        Reply With Quote Quick reply to this message
Old 05-13-2021, 05:42 PM   #176 (permalink)
Took me a good part of the day to figure out, but finally sorted.
Once you've flashed BLHeli (revision 13.2 and above), the bootloader will automatically be installed. Once you have the bootloader installed, you can then remove the connectors/wires you've soldered on.
To connect to BLHeli in the future (using BLHeli Suite), you just need to use the existing connector that plugs into the flight controller, utilising only two pins (black = ground, and white = signal).
Within BLHeli Suite, select the SILABS BLHeli 4-way interface (this is using an Arduino board) and away you go. I'm using an Arduino Nano board, so the signal pin from the ESC goes to Digital pin 2, and ground to ground.
The attached manual shows how to use the different programming connectors you may have in your toolbox.
Old 05-15-2021, 09:34 AM   #177 (permalink)
Sorry for the double post,
I figured it out, that post was wrong saying to use pin D2 and ground, its actually pin D3 and ground, I figured the post was correct because nobody corrected it.... all good now
