Go Back   HeliFreak > R/C Electronics Support > Spirit FBL system
Spirit FBL system Spirit FBL System Discussion
Old 11-09-2017, 10:25 PM   #1 (permalink)
Default New to Spirit - Setup Question
Just received my 2 new Spirits and I am going to start the process of switching my Mini Comet and putting the second one in a new G380.
My question is, aside from the normal control surface checks to make sure everything moves properly with the sticks & by FBL correction and verifying the mount of pitch, is there anything that HAS to be adjusted after using the "Model Preset" on step 2 / 10 of the wizard?
I feel like I read somewhere that the presets work pretty good for a maiden, and then some people like to tweak it a little more. I have read through the Wiki so if I need to walk through every step I can.
Goblin Speed | X10S | Spirit | Hobbywing | XNova | KST
treys1 is offline        Reply With Quote Quick reply to this message
Old 11-09-2017, 11:16 PM   #2 (permalink)
In my experience, Spirit is good to go after preset / intiial setup. (probably the best "default" settings of the units I've tried)
Do a bunch of runs on the bench, without blades, making sure everything moves correctly, check to see if any of the connections get hot etc, after which it is ready.
Dawiev is offline        Reply With Quote Quick reply to this message
Old 11-10-2017, 12:03 AM   #3 (permalink)
The first 'other' adjustments I'd recommend making:
Under advanced, set your 'rudder delay' value up based on the manual's recommendation for your servo type. If it's not low enough and your servo is super fast, the tail will feel sloppy.
Other than that most of the rest is just getting the model to fly the way you want it to feel; rudder dynamic for tail stop hardness, rotational rates, flight style, feed forward, etc. And of course governor gains if you're going to use the spirit governor.
Trex 700L spirit pro / Trex 700n spirit pro/ Trex 550x spirit pro / Goblin Black Nitro 700
Thestructured is offline        Reply With Quote Quick reply to this message
Old 11-10-2017, 05:40 AM   #4 (permalink)
In my experience, cyclic and rudder rotation speed defaults are quite "conservative"...
Oxy 2X-VertWarp 360Blade 450XBlade 450X NightflyerGoblin 500 ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8 G1
Coco66 is offline        Reply With Quote Quick reply to this message
Old 11-10-2017, 07:42 PM   #5 (permalink)
Thanks for the help!
New question:
Is the bank switching fast enough that if I setup the mixes to have 2 banks for normal flying and have the 3rd bank dedicated to rescue, when I flip the switch that initiates the bank switch to bank 3, will it rescue in a reasonable amount of time?
I am coming off of Brain2's where the 3 bank switching is separate from the rescue which is layered on top of whatever bank you were in (if you have enough channels). I'm basically trying to make it act the same way but with just 2 normal banks.
Old 11-10-2017, 08:17 PM   #6 (permalink)
To clarify:
DX8G2
Banks on Switch C (Aux2)
Rescue on Switch A (Aux3)
Switch C
Pos0 (Bank3) - Normal with Acro Rescue
Pos1 (Bank2) - Normal with Normal Rescue
Pos2 (Bank1) - Auto Level
Switch A
Pos0 - Rescue Function Off
Pos1 - Rescue Function On
The mixes that allow the Gyro to be set to positive values but inverted to the same value but negative (50% becomes -50%) are below. Activating it on Switch C Pos2 only leaving the other to use the Function Switch:
Ger > Gyro Mix Rate: -100% / 100% Offset: 0% Switch C Pos2
This mix changes from Bank 1 to Bank 2 and turns the Rescue Function on when the Rescue switch is flipped (Switch A Pos1). This only functions this way while in Bank1, the other 2 Banks just activate rescue and stay in whichever bank they are already in:
-A- > Aux2 Mix Rate: 100% / 0% Offset 0% Switch C Pos2
If the bank switch was in Bank1 when rescue was activated, when it is turned off you will go back into Bank1. Bank1 and Bank2 will have identical flight characteristics settings aside from Bank1 being auto-level and Bank2 having Rescue Normal.
Old 11-11-2017, 12:50 AM   #7 (permalink)
Could not follow your programming on the last post, but the answer to the previous question is Yes, the bank switching is instantaneous.
Old 11-11-2017, 09:04 AM   #8 (permalink)
Great to know! I cleaned up my above post to see if it makes more sense. It essentially gives me 3 banks with slightly different features / flying characteristics, but still allows rescue in all 3. (Rescue when in an Auto-Level Bank was the part I couldn't find easily in the software.)
I have verified on the monitor that the mixes are doing what I want with the AUX channels and I will be setting up the first one today.
Should anyone want a similar setup, I can share actual TX screens if that would make more sense.
Old 11-11-2017, 05:49 PM   #9 (permalink)
OK. So I thought you could have 1 bank use the negative gain values for the Stabi Function and the other 2 banks use the Function switch on channel 8. Turns out if you enable the Function switch, all three banks use it (channel options only available in Bank 0 and grayed out in bank 1 & 2).
That changed my mixes.
My banks are on Switch C and my Stabi Function is on Switch A.
Switch C:
Pos0 - Bank2 (Rescue Acro Stabi Function)
Pos1 - Bank1 (Rescue Normal Stabi Function)
Pos2 - Bank0 (Stabilization Normal Stabi Function)
Switch A:
Pos0 - Function Off
Pos1 - Function On
I wanted Bank0 to have Stabilization Normal turned on when Switch A was on Pos0 as that is my "Rescue" switch. When I flip Switch A to Pos1 for "Rescue" it changes banks to Bank1 and turns the Function On.
Bank1 & Bank2 are unaffected and Switch A just functions as Rescue Function On or Off.
Human Verification
