5.3 pro head wobble at certain speeds - HeliFreak
Old 11-15-2017, 04:58 PM   #1 (permalink)
Default 5.3 pro head wobble at certain speeds
550sx stretched to 550se length, silver line pro
I have futaba 9252 cyclic servos
I've recently lowered my head speeds to about 1800
600 edge blades 6s packs, but tried 4400 instead of 5000's
I swapped blades to some rails and it wobbles pretty good hovering when it wasn't before with the edge blades.
tracking looks correct.
I balanced the Rails static, didn't help, I tried tape on one blade and moved it a bit and it seemed to help, but not really.
I ran into something similar with the brain on another heli and lowered the hz for the servos and it seemed to fix it.
Do we have that option?
Also I spooled it up at 0 pitch on the skids and the tail fin is smooth making me think the balance is fine.
If I go up to 1900 it seems to run smooth.
Going to try to lower the head gain a bit to see if that helps
Steve
smittylube is online now        Reply With Quote Quick reply to this message
Old 11-15-2017, 07:05 PM   #2 (permalink)
may have been tracking. I tightened one link and loosened the other as far as I could twist without removing them.
test hover was perfect, however I used a 2 oz heavier pack since I exhausted the other light pack testing.
Steve
Old 11-15-2017, 08:47 PM   #3 (permalink)
It may have nothing to do with the FBL unit. Try using softer dampners for lower head speeds. Also switching to a stiffer blade did not help either.
If the wobble goes away with a higher speed then I would suspect the dampners.
Spending time, Paying attention
Bladefx is offline        Reply With Quote Quick reply to this message
Old 11-17-2017, 08:09 PM   #4 (permalink)
No wobble with the heavier battery pack,
Tried again today, but had a wobble no tracking solution.
Tried the edge blades with the light packs and no wobble at the same speeds.
Something is going on with the rails. Possibly due to 8 grams heavier each? Not quite sure at this point.
What I did confirm was it will hover for 5-8 seconds smooth before the wobble starts. Static balance was perfect
Steve
Old 11-18-2017, 01:15 PM   #5 (permalink)
Wobble at lower rpm are always too hard head damping, body weight also plays a part here as well as blade rigidity. The Edge blades are known to be more flexible than other blades.
Just change head damping to softer damping for lower rpm.
Gaui R5, Henseleit TDR, TDR2, TDF, Banshee
Kontronik, Scorpion ESC, iChargers, VBar, VControl, JR XG11
Old hand at Planks
Old 11-20-2017, 02:36 PM   #6 (permalink)
It ended up being failed thrust bearings. had the 550 sx head running 600 blades.
Swapped it out for the 600 head with good bearings problem solved.
Steve
Old 01-03-2018, 01:57 PM   #7 (permalink)
Bearings did not solve it for 100% of the time. Also tried lower head gains with no results.
Setup a tach and near 1550 HS is when it wobbles. Have ordered the medium dampers so I will see if this eliminates it 100% of the time.
Steve
Human Verification
