Go Back   HeliFreak > R/C Simulators Support > AccuRC Flight Sim
AccuRC Flight Sim AccuRC Flight Sim Discussion
Like Tree2Likes
  • 1 Post By Ade_Law
  • 1 Post By shizack
Old 11-18-2017, 04:38 AM   #1 (permalink)
Default List of 3rd party dongles for AccuRC
Hi Guys,
Here is a list of dongles known to work with AccuRC, please comment if I have missed any and I will add to the list
https://docs.google.com/document/d/1...it?usp=sharing
[email protected] Direct Email
[email protected] AccuRC Support
https://discord.gg/ftCKT8U AccuRC Discord Server
Ade_Law is offline        Reply With Quote Quick reply to this message
Old 08-10-2018, 02:50 AM   #2 (permalink)
added new Frsky wireless dongle.
I admit im a bit of an frsky fanboy, they are awesome transmitters, sure the software takes a bit of learning but there are plenty of guide videos out there.
this caught my eye because it has no less than *8* proportional channels and 8 switched channels. I have not seen another dongle support that many channels I can finally assign all the switches to all the things in AccuRC!!!
https://www.frsky-rc.com/frsky-xsr-sim/
Old 01-18-2019, 02:21 PM   #3 (permalink)
I started using AccuRC on my MacBook Pro last night with the dongle below and it seemed to be working well. I hooked up a Graupner GR-12 received to it and was able to control the sim wirelessly. It should work with any receiver that outputs a PPM signal.
IKARUS USB-Interfaceset #3031020 for sumsignal receiver https://www.amazon.com/dp/B00JUQMV70/
I discovered a Function assignment bug in the Mac version of AccuRC in the process; the Axis sliders were responding normally. I reported it on Discord and there's a new version available for me to test out this evening.
UPDATE: The fix appears to work. I was able to fly a heli for a minute or two to test it out.
Old 04-07-2019, 08:26 AM   #4 (permalink)
Are there any wired USB interfaces that support more than 4 analogue channels?
I have Futaba FASST.
I not interested in solution that involves using a receiver.
Cheers,
Nigel
nheather is offline        Reply With Quote Quick reply to this message
Old 04-08-2019, 02:51 AM   #5 (permalink)
the blue hobbyking one does.
Old 04-15-2019, 08:57 AM   #6 (permalink)
Just to clarify. I recently bought the blue Hobby King and it only supports four analog channels. Ade has since looked as his HK interface and confirmed that too only supports four analog channels - honest mistake.
So appreciating that you can use the simulator perfectly well with four analog channels but if possible would like one with more. So is anyone aware of a hard-wired USB interface that supports more than four analog channels?
Cheers,
Nigel
Old 04-16-2020, 04:30 PM   #7 (permalink)
Does anyone know of a vendor in Canada for the XSR-SIM wireless?
And thank you ADE for the Steam help yesterday.
I fight Gravity
300x,4503d converted to x
(2) Trex 550's stretched
Build in progress Tarot 450 Pro V2
franknsled is offline        Reply With Quote Quick reply to this message
Old 04-18-2020, 06:38 PM   #8 (permalink)
This works as well, using a Leonardo Arduino
Arduino as wireless RC simulator dongle
XLPower 520 - Brain
OMP M2 Explore - HeliFlight-3d
TX: Fr-Sky X9 Lite S
P.I.Engineer is online now        Reply With Quote Quick reply to this message
Old 05-01-2020, 03:45 AM   #9 (permalink)
as far as i can tell this is PPM only? The issue with this is that its analogue which is quite slow and can suffer from jitter, do you know if there any plans to support SBUS and other digital serial connections?
Ade
theriddick45 likes this.
Old 05-01-2020, 03:56 AM   #10 (permalink)
Hi,
I use a very old Esky usb dongle with AccuRC 2 and works fine. Ok, simple PPM signal, but I personaly don't need more to train.
Rgds
TheLover3 is offline        Reply With Quote Quick reply to this message
Old 05-01-2020, 06:16 AM   #11 (permalink)
Hello Ade!
The FrSky XSR-SIM has an SBUS input on the side according to the manual.
Could you tell me for sure if I can solder a futaba sbus receiver it will work?
Gaui X3 - Gaui X5
Lumberjackbr is offline        Reply With Quote Quick reply to this message
Old 05-13-2020, 06:11 AM   #12 (permalink)
sorry for the slow reply, missed this somehow,
That is the s-port which is probably used for firmware updates rather than sbus in.
so it probably wont work for sbus in.
this however will work
https://www.banggood.com/DroneMesh-V...r_warehouse=CN
Ade
Old 08-12-2020, 06:48 AM   #13 (permalink)
Need help I checked with Ade before ordering, buying the Hobby king 9 in1 dongle that it would work. I also bought the sim from steam.. After a pulling my hair out full day I finally got the heli sim working..
. Today powered it up and no MEMORIES of Sim and DX9 stored in Steam...which I believe AccuRC is aware of...No problem, as I had noted the Axis data.from yesterday . However, no matter what I do I can not get my DX9 to work on this sim today..... Its driving me nuts..
Going round in circles any ideas
al
alistair watt is offline        Reply With Quote Quick reply to this message
Old 08-12-2020, 07:56 AM   #14 (permalink)
Well after three more hours got the sim to work..So Ade was right the dongle works...Thanks Ade but it is a pain to have to re enter all my TX controls as if a new flyer...If I had known this would have bought it direct and not used Steam as a supplier
Still have to work out that RPM section...Come on Accurc could have done with a little instructions /notes on the various pages/menu on the sim..Half of the stuff not sure what it is, like two sets of Axis data and sseeting idle up properly al
Old 08-12-2020, 09:05 AM   #15 (permalink)
Just to point out for those that don't know, the RX2SIM interface not only works well with AccuRC, it is also is a BeastX programming interface.
So if one is using BeastX and in the market for an AccuRC dongle, the RX2SIM does double duty.
I use my RX2SIM with an inexpensive, tiny FHSS-Sbus receiver and any of my Futaba transmitters, including a steering wheel transmitter.
Micros: Hisky HCP80, ESKY 150x,K110, Trex-150X x 2 Mid: Oxy 3 T New Version, Oxy 4 360 Big: Trex-500X, Oxy 5, Trex-550X, Trex-700X Scale: MD500 TOW Defender (Trex 500 size) Vintage: Trex 450 SE V2
ic-racer is offline        Reply With Quote Quick reply to this message
Old 01-07-2021, 09:00 PM   #16 (permalink)
The dongle that came with the not-so-legit 4-in-one simulator from ebay (or HK?) called KDEMODEL simulator or something like that works with all the functions on the "G3-G7 Above" setting. With my DX6 anyway.
The assignments are kind of screwy/mis-assigned in windows joystick calibration but assigning the axes in Accurc isn't too mind-bendy.
Ade_Law likes this.
TREX 470LP (iKon2), TREX 450 Pro EFL (OG iKon), Nano S2, DX6 G3
Retired: mCPX, 130X, mSR
shizack is online now        Reply With Quote Quick reply to this message
