Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 330X
Blade 330X Blade 330X Helicopters Information and Help
Old 01-20-2018, 07:25 PM   #1 (permalink)
Default Gyro Gain on DX6i
Well, I finally got to Maiden my 330X today, and overall I am impressed. The 450XV2 was my first larger heli, but I had a lot of problems with the FBL and tail issues with that heli. Recently the motor started to go and I lost a servo so I replaced it with the 330X.
Anyway, wondering if anyone out there has the 330 paired to a DX6i and what gyro gain you are using. The manual recommends 60 for normal and 50 for IU. I tried mine at 60 and the tail had a prominent slow wag. I adjusted to near 90 on normal mode and it's a lot better, but not perfect. It was breezy today, so maybe tomorrow I will see with no wind how it is.
Might try IU as well.
Anyone else?
BladesinMD is offline        Reply With Quote Quick reply to this message
Old 01-20-2018, 08:43 PM   #2 (permalink)
Adjust the gain in IU only...
If needed, turn down the Throttle Curve for a headspeed you are comfortable with and adjust to that headspeed...
Each time you increase the TC you need to make any gain adjustments needed to keep the tail solid
Trying to adjust tail gain in normal mode with constant RPM changes is a lesson in futility
nCPX(3)*mCPX(25)*130X(10)*130X-L(6)*180CFX(3)*300X/CFX(3)
450X(7)*470LP*GauiX3*nanoQX*180QX*DX9*HF180060*AMA 988253
Old 01-21-2018, 01:04 AM   #3 (permalink)
One thing to remember is that on the DX6i the gryo heading hold gain starts at 50, so 60 is essentially 20% 70 is 40% gain and so on. Anything under 50 is rate mode (if applicable)
Compass Chronos, Logo 550sx,Logo 400se Jeti
Protos Max Leggero Evoluzione 800
Pygmaeus is offline        Reply With Quote Quick reply to this message
Old 01-21-2018, 05:40 PM   #4 (permalink)
Think I've got it figured out. The throttle curve is nearly flat at 50% for normal mode per the manual, this low head speed requires a lot of gyro gain - about 91%.
The IU recommendation is 75% throttle, which I may adjust higher. This requires about 77% gain.
I had my 450X on the same TX but the normal mode there was about 70% TH, so it seemed like I was having to really jack up the gain on this, but now I get it. Thanks.
BTW, I'm finding the new AR6336A FBL on the 330X much more stable than the AR7200BX ever was on my 450X. I had to replace two of those on the 450X, hopefully this one will hold out. Great little 3S machine thus far...
Old 01-21-2018, 05:43 PM   #5 (permalink)
Glad you got it sorted out...and congrats on the maiden flights
I haven't spooled My 330X up yet...the AFC Championship got in the way and darkness has fallen
Happy to hear about the FBL too...
All My 450X's are on iKON FBL units so I'm curious about the new AR636A
Old 03-27-2018, 08:05 AM   #6 (permalink)
Think I've got it figured out. The throttle curve is nearly flat at 50% for normal mode (TX N!!!) per the manual, this low head speed requires a lot of gyro gain - about 91%.
Be very careful with TX N flight-mode values vs gyro normal-/rate mode (Dx6i: below 50, DX8/9: <0) vs gyro heading hold (>50, >0).
HH staff seem to be a fan of copy and pasting values from different TXes and different Blade heli models across different language manuals (e.g English vs German). Doing so will NOT produce better output or get things right....actually this pretty much corrupts manual numbers as I can verify by myself.
If you check e.g the older Blade 450X (AR7200BX) or 360CFX EN manuals you can see, that about 54% gyro gain (HH) =may much better match a newer Airware DX6-DX9/18 TX which have a -100..0..+100 range.
Calculation: (54 + 100) / 2 = 77% (Dx6i) in gyro heading hold mode (HH)
The 330X EN manual values
60% (N with 50% TC) / 50% (ST1 with 65% TC) for Dx6i
vs
85% (N with 50% TC) / 75% (ST2 with 65% TC) / 80% (ST 1 with 55% TC) for DX6G2-DX9/DX18
50% Dx6i = 0 gyro.
a) do not match each other and are pretty much illogical
b) Dx6i section more likely uses Dx6-DX9 Airware value
c) 85/75/80 gyro numbers probably are meant for the DX6i
My downloaded 360CFX (6s, BLH4750) EN manual also shows(ed) a quite gyro wrong 20% Dx6i value (should be re-calculated 70% for 100% TC).
Calculation example:
75% gyro gain (Dx6i) x 2 = 150 - 100 = 50%
This better matches with 360CFX (6s) manuals Dx6-DX9/DX18 illustrations or 450X ~54% (HH):
NORMAL/POS 0 58% (30% TC)
STUNT 1/POS 1 48% (75% TC)
STUNT 2/POS 2 40% (100% TC)
48% (DX9) + 100 = 148 / 2 = 74% (Dx6i)
Summary:
The best probably is to simply ignore newer Blade manuals and test out the values all for yourself.
You can e.g put gyro normal/rate mode and heading hold on a switch, use the poti or trim switches to fine-tune (HH) gyro values.
Once the gyro gain HH value is to high, the tail will quickly bounce on ground back and forth and you need a 2nd normal/rate mode setting to de-escalate the situation.
I was successful in doing so even with my Blade 4503D while hovering.
Just make sure before that the tail holds (mechnical pre-pitch) in normal-/rate mode and you use a suitable gyro gain value for the rate mode. If you did not, you can not use this trick as the tail quickly will spin 90-180 degree.
Walkera Devo 10/DeviationTX (12CH DSMx & telemetry)...Ex-DX8...Blade 4503D...Walkera V120D02s...Blade 200QX BL Quad...StrykerQ (LEDs, M2 tuning)...Ex-NanoCPX...Ex-120SR...Ex-MPX EGP...PPZ P51-D Mustang...PZ Wildcat (searching fuselage-firewall)
Thomas.Heiss is online now        Reply With Quote Quick reply to this message
